Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 27th Nov 2013, 12:36   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
NZXT G10 adapts all-in-one liquid coolers for GPU duty
Kraken G10 bracket hits the market.
http://www.bit-tech.net/news/hardwar...t-kraken-g10/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 27th Nov 2013, 12:59   #2
GaryP
RIP Tel
GaryP's Avatar
GaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming Saiyan
Looks interesting.
__________________
Intel i7 5820k @ 4.3Ghz | Corsair H110i GT | 16GB Team Elite 2400Mhz | MSI Titanium X99A | Corsair AX 760 PSU | GTX 970 AMP! Extreme Core| 240 GB Kingston HyperX SSD | 2 x 2TB Hitachi HDD | 2 x 2TB seagate HDD | Asus Xonar D2X Soundcard | NZXT 810 Case | Windows 7 Home Premium 64 bit | Dual 27" Monitors
Steam: HackneyHawks
GaryP is online now   Reply With Quote
Old 27th Nov 2013, 13:12   #3
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
I want a version that allows me to mount a separate fan where the rad is in that picture (to keep memory & VRMs cool), and then allow me to mount the rad in the roof of my Prodigy to exhaust all of the real heat out of the case. Then they'll get my money.
__________________
3770K | Z77E-ITX | Liqtech 120X | EVGA GTX 980Ti SC | 8GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 27th Nov 2013, 13:17   #4
Gareth Halfacree
WIIGII!
bit-tech Staff
That's exactly what this does. Reread the article.
__________________
Old 27th Nov 2013, 13:25   #5
Shirty
Moderator
Shirty's Avatar
I think you mean *read* the article.
In typical forum fashion I just looked at the picture and then formed my own, erroneous conclusions. Consider me suitably shamed
__________________
Old 27th Nov 2013, 13:41   #6
Slayer the Unholy
Multimodder
Slayer the Unholy's Avatar
Slayer the Unholy has yet to learn the way of the DremelSlayer the Unholy has yet to learn the way of the DremelSlayer the Unholy has yet to learn the way of the DremelSlayer the Unholy has yet to learn the way of the DremelSlayer the Unholy has yet to learn the way of the DremelSlayer the Unholy has yet to learn the way of the Dremel
looks like it just barely makes it a triple slot card. I suppose though if you are using more than 1 high end card you should just put out the extra money to build a custom loop.
__________________
Its my computer so I'll do what i want with it
26.62722% Total Geek
Slayer the Unholy is offline   Reply With Quote
Old 27th Nov 2013, 13:46   #7
stuartwood89
Please... Just call me Stu.
stuartwood89's Avatar
stuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpit
I'm pretty sure I've seen pretty much the same thing available on KustomPCs for ages now:
http://www.kustompcs.co.uk/acatalog/info_26039.html
...and they have one for the square pump-top coolers:
http://www.kustompcs.co.uk/acatalog/info_26040.html
__________________
My new blog Stu-Topia.com: because stutopia.com was already taken
Project - Storm Scout Restoration
Originally Posted by Joey Propane View Post
I thought Dragonforce were like a joke/troll rock band? Ya'know, like Nickelback?
stuartwood89 is offline   Reply With Quote
Old 27th Nov 2013, 15:15   #8
greypilgers
Supermodder
greypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysis
I like this idea ALOT... I can see this catching on in a BIG way, too. I for one would definitely shell out for something like this, especially if those claimed temps are in any way accurate... Can we get a test from BT?
__________________
Bungletron: And certainly if my house was burglarized I would phonerelize the police right away, what idiot would not?
greypilgers is offline   Reply With Quote
Old 27th Nov 2013, 15:20   #9
Tichinde
Hypermodder
Tichinde is a Super Spamming SaiyanTichinde is a Super Spamming SaiyanTichinde is a Super Spamming SaiyanTichinde is a Super Spamming SaiyanTichinde is a Super Spamming SaiyanTichinde is a Super Spamming SaiyanTichinde is a Super Spamming SaiyanTichinde is a Super Spamming SaiyanTichinde is a Super Spamming SaiyanTichinde is a Super Spamming SaiyanTichinde is a Super Spamming Saiyan
I'm sold on this.....need to find an AIO cooler to fit in my HTPC case now.....
__________________
Big: HAF 932; Asus P8P67-Pro; I5-2500K @ 4.4Ghz; Corsair H70; 8GB Corsair XMS DDR3; Gainward 560Ti 448; Samsung 830 256GB SSD.
Little: Silverstone GD05B; MSI H77MA-G43; I5-2500; 8GB Corsair XMS DDR3; EVGA GTX 960 SC ITX; Samsung 830 128GB SSD.
Tichinde is offline   Reply With Quote
Old 27th Nov 2013, 15:26   #10
PingCrosby
Supermodder
PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.
I'm going to have quite a few ' liquid coolers' myself tonight on the works xmas do
PingCrosby is offline   Reply With Quote
Old 27th Nov 2013, 15:44   #11
Shirty
Moderator
Shirty's Avatar
__________________
Old 27th Nov 2013, 16:53   #12
Almightyrastus
Rule #9
Almightyrastus's Avatar
Almightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming Saiyan
Wow, a 92mm fan, not heard about those for years. I remember when swapping one of those for the 60mm CPU heatsink fan most people were running marked you out as a proper badass.
__________________
Lo there do I see my Father. Lo there do I see my Mother, and my Sisters and my Brothers. Lo there do I see the line of my people, back to the beginning. Lo they do call to me. They bid me take my place among them, in the halls of Valhalla where the brave may live forever.
Almightyrastus is offline   Reply With Quote
Old 28th Nov 2013, 19:47   #13
Sgoaty
Supermodder
Sgoaty should be considered for presidentSgoaty should be considered for presidentSgoaty should be considered for presidentSgoaty should be considered for presidentSgoaty should be considered for presidentSgoaty should be considered for presidentSgoaty should be considered for presidentSgoaty should be considered for presidentSgoaty should be considered for presidentSgoaty should be considered for presidentSgoaty should be considered for president
Looks good I bodged an antec AIO water cooler on to a GTX 470 a while back and it worked really well.
Sgoaty is offline   Reply With Quote
Old 28th Nov 2013, 20:49   #14
Vetalar
*learning english*
Vetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming Saiyan
I like this idea for a few seconds Arctic hybrid costs a little bit more (thing+aio cooler) but one gets plenty of radiators for vrm and ram, cool external cover and pwm control from gfx...
Interesting idea but not for me. Add incompatibility with 79x0...
send from Deathstar via HAL9000
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is offline   Reply With Quote
Reply
Tags
all in one cooler, amd, cooling, gpu cooler, gpu watercooling, graphics card, kraken g10, nvidia, nzxt, nzxt kraken, nzxt kraken g10, sealed-loop, water-cooling, watercooling, watercooling gpu
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
