Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 4th Dec 2013, 13:11   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
AMD to drop FX CPUs, move to APUs, suggests leaked slide
AMD could be set to leave behind high-end CPUs as it chases the APU market.
http://www.bit-tech.net/news/hardwar...s-suggests-l/1
Meanmotion is offline   Reply With Quote
Old 4th Dec 2013, 13:16   #2
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
The future is Fusion...
AlienwareAndy is offline   Reply With Quote
Old 4th Dec 2013, 13:24   #3
Harlequin
I Mod, Therefore I Own
Harlequin's Avatar
Harlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming Saiyan
the slide that's been pretty much proven to be a photochop?
__________________
They shall grow not old, as we that are left grow old:
Age shall not weary them, nor the years contemn.
At the going down of the sun and in the morning
We will remember them
Harlequin is offline   Reply With Quote
Old 4th Dec 2013, 14:07   #4
Panos
Supermodder
Panos can run CrysisPanos can run CrysisPanos can run CrysisPanos can run CrysisPanos can run CrysisPanos can run CrysisPanos can run CrysisPanos can run CrysisPanos can run CrysisPanos can run CrysisPanos can run Crysis
Don't see where the problem is.
According to the tests a down clocked 2Ghz FX Vishera is getting bottlenecked by a 290X under Mantle API
With Steamroller core being stronger than the current FX cores, doesn't change much tbh. Which seems a Kaveri going to get bottlenecked by a 290X under Mantle also. So thats good news for the average user.
Panos is offline   Reply With Quote
Old 4th Dec 2013, 14:17   #5
rollo
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
As long as the game your playing supports mantle yes that would be accurate panos. BF4 patch is due this month we will see what mantle can do then id imagine.
This does not come as a shock, Do wonder though why they have bothered to make there fx 8 core chips if they are not going to continue with them. They are very good chips for the price bracket they are in.
More Intel price rises on the way it would seem.
rollo is online now   Reply With Quote
Old 4th Dec 2013, 15:59   #6
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
This could simply just be a roadmap for APUs, but that doesn't mean all CPU products. On the other hand, I'm not really sure what separates the Steamroller architecture from Piledriver - there's a possibility there are too many changes to make it work on existing chipsets, but it isn't quite worth AMD making yet another socket for DDR3. Once DDR4/5 is released, I'm sure AMD will have a non-APU model to offer.
schmidtbag is offline   Reply With Quote
Old 4th Dec 2013, 16:09   #7
Corky42
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
Got any links to the tests, my Googling didn't turn up anything
Corky42 is offline   Reply With Quote
Old 4th Dec 2013, 17:18   #8
Williz
Supermodder
Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.
I don't even know what CPU to buy anymore. I'm on am3+ and have a phenom 1090t still. What's the best upgrade I can get / is it worth waiting?
__________________
Corsair Carbide 540 / Asus Crosshair V / AMD 1090T Phenom @ 4 GHz
RAM 16Gb G.Skill RipJaws Z 1.5v DDR3 @ 1600 / Asus R9 290 / Crucial M4 64Gb / 1Tb Samsung / H100i and a boatload of Gentle Typhoons / Seasonic X760w GOLD
HP Microserver N40L / 128Gb Samsung SSD / 4x 1Tb drives / AMD 6670 / Asus Xonar DG(x?)
Williz is offline   Reply With Quote
Old 4th Dec 2013, 17:25   #9
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
I'd stick with what you've got...and wait to see exactly where AMD are going, your CPU is still good for the vast majority of apps and games.
The only CPU you could really class as an upgrade from the 1090 would be the 8320/8350, but the nature of the core design on those means it could be slower in some things.
The Phenom II X6 chips are very sought after on the auction sites BTW, if it's in good condition, you'll easily get over 100 for it.
Maybe sell it and put it towards an Intel 4670/4770K setup if you want a BIG performance increase.
Hustler is offline   Reply With Quote
Old 4th Dec 2013, 17:26   #10
Harlequin
Harlequin's Avatar
meh im going to an FX 9590 from a 1090T
__________________
Old 4th Dec 2013, 17:30   #11
Hustler
Hypermodder
Hustler's Avatar
Waste of money, but your electricity supplier will like you.
Old 4th Dec 2013, 17:36   #12
Harlequin
Harlequin's Avatar
faster than an i5 and matches an i7 so yeah lets go with that
__________________
Old 4th Dec 2013, 17:44   #13
schmidtbag
Ultramodder
Why not just go for either of the FX-8300 CPUs and overclock it? I got to 4.4GHz on my FX-6300 and still have power saving features on. I should be able to outperform just about any i5 (at stock speeds) with that and it wasn't hard to get to that speed. I could probably get to 4.5 if I pushed the voltage a little higher.
Old 4th Dec 2013, 17:55   #14
rollo
8320 can hit the same speeds as 9590 so not really sure the point in that but each there own i guess.
Old 4th Dec 2013, 19:08   #15
Hustler
Hypermodder
Hustler's Avatar
Yeah...but calling it a 9590 makes it sound sooooooo much better.
Old 5th Dec 2013, 09:49   #16
Williz
Supermodder
I thought that was the case if I''m honest but wasn't sure! Thanks Hustler. I've not any problems with my setup but just had an upgrade itch. Think I'll just stick with getting a corsair 540, a load of fans and a h100i. I might look at switching to Intel after Christmas and see if I can find a sale on the CPUs anywhere
__________________
Old 5th Dec 2013, 11:51   #17
.//TuNdRa
Resident Bulldozer Guru
.//TuNdRa's Avatar
.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan
Not entirely surprised. AMD have been neglecting AM3+ for a while, alongside refusing to release the steamroller cores for the FX platform, It's been obvious that they weren't devoted to retaining it as a platform for too much longer.
__________________
Dozy Beast: AMD FX8120 | Thermalright Archon | Asus Crosshair V Formula | 16GB (4x4GB) Corsair Vengeance LP | Asus Strix Soar | 2X SLI Gigabyte Windforce 670 | Silverstone SSTG1000W | Silverstone Raven RV-02B V1.7 | 2x Hynix SL301 250GB RAID0 | 2x WD 3TB RED RAID0 | Lite-on Blu-ray ROM
Dell U2913WM | Sennheiser HD 518s | Microlab Solo8C Speakers | Logitech G13 | Ducky Legend (MX Blues) | Func MS-3
.//TuNdRa is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
