Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 5th Dec 2013, 15:00   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Bit-Tech Christmas Countdown Competiton - 5 December
Yoyotech is providing today's prize of an Asus Z87A motherboard.
http://www.bit-tech.net/bits/competi...competiton-5/1
Meanmotion is offline   Reply With Quote
Old 5th Dec 2013, 15:06   #2
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
Entered once again.
Perhaps I could ask that nobody else enters these to help my chances along a little bit?
__________________
6700K | Z170I | Liqtech 120X | EVGA GTX 980Ti SC | 16GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 5th Dec 2013, 15:07   #3
jinq-sea
The Double Insulates
Moderator
jinq-sea's Avatar
jinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyan
Too late, I'd already entered. Damn you for ruining my chances!
__________________
Comrade Woody: "I dunno, whores are a bit like cornflakes, you always regret buying the cheap ones."
small(ish): i7-5960X / X99E-ITX/AC - Bitspower Block / 32Gb Ballistix / Titan X (P) / 512Gb Samsung 950 Pro NVMe / 250D
tiny: i7-4790K / Max VII Impact - EK Monoblock / 16Gb Ballistix / EVGA Titan X (M) HC / 256Gb SM951 NVMe / nCase M1
htpc/vr: i7-6700K / Z170i / 16Gb Ballistix / EVGA 1080 Founders Edition / 128Gb SM951 NVMe & Sandisk 960Gb SSD / RVZ01
jinq-sea is offline   Reply With Quote
Old 5th Dec 2013, 15:09   #4
Shirty
Moderator
Shirty's Avatar
I have a really nice hacksaw at home. If I win I'll cut the board in half and I'll even let you choose your half. If you win I'll post the saw with a return envelope, and you can ship me the half you don't want plus my saw.
Fair?
__________________
Old 5th Dec 2013, 16:07   #5
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
I haven't owned a desktop Intel system since I think 2003. In some ways I'd prefer a free CPU over a motherboard since Intel is so expensive, but, this is a pretty nice board and even an overclocked i5 would still be faster and more power efficient than my current system (FX-6300 at 4.4GHz). My system is arguably close to retirement, so I think this would be a nice step up.
schmidtbag is offline   Reply With Quote
Old 5th Dec 2013, 16:28   #6
jinq-sea
Moderator
jinq-sea's Avatar
Fair?
Sounds good to me. If you want opposing corners, we could cut it into quarters if you like?
__________________
Old 5th Dec 2013, 16:29   #7
Shirty
Moderator
Shirty's Avatar
I'm willing to play
*puts on shades*
the silicon lottery.
Awwwww yeeaaahh!
__________________
Old 5th Dec 2013, 19:12   #8
demastes
What's a Dremel?
demastes has yet to learn the way of the Dremel
demastes ftw!!! ..... please?!? =)
demastes is offline   Reply With Quote
Old 5th Dec 2013, 20:27   #9
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Guys, I'll let you win one each over the next couple of days if you let me win one... OK? I mean just take a look at my specs (forum signature), I am NEED of an upgrade.
Bit-Tech, please feel free to pre select me for any Case, GPU or CPU prizes. thanks.
__________________
SchizoFrog is offline   Reply With Quote
Old 5th Dec 2013, 20:41   #10
schmidtbag
Ultramodder
An i7 4770K is almost the same value as the entirety of your current system. While I don't disagree that you would want something more modern, I'm not sure how you'll be able to afford to take advantage of this motherboard. It'll cost you at the very least $400 to put some good use to this board. With that money, you can build a complete AMD A10 system that is better than your current one (at least if you use the same tower, storage, and PSU).
BTW, I think your system is fine. Old isn't always bad. I'm not sure what you do but I figure a GPU upgrade and an overclock might be all you need to play modern games at medium-high settings.
Old 5th Dec 2013, 21:24   #11
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
I've just realised I've not been putting my phone number on any of these! NOOOO!
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 5th Dec 2013, 21:27   #12
schmidtbag
Ultramodder
Whoops I forgot to list that. Oh well, if I'm selected maybe they'll ask.
Old 5th Dec 2013, 21:57   #13
Meanmotion
bleh
Meanmotion's Avatar
Yeah, don't worry about it. We'll email back any winners to confirm details.
Old 5th Dec 2013, 23:36   #14
Redbeaver
The Other Red Meat
Redbeaver's Avatar
Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!
Ok. This would be perfect.
__________________
Ophelia
ASUS P5Q Pro Turbo - Q6600 - 4GB DDR2 - NVIDIA 8800GTS 640 - WD Black 2x320Gb RAID-0 - Silverstone TJ-06 [Modded]
Perseus
ASUS Z97i-Plus - i5 4670K - Corsair H110i GTX - 8GB DDR3 - Zotac GTX 970 - RAID-0 Crucial MX100 2x256GB - Phanteks Enthoo ITX Red
Redbeaver is offline   Reply With Quote
Old 6th Dec 2013, 00:16   #15
Otis1337
aka - Ripp3r
Otis1337's Avatar
Otis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming Saiyan
everyone can stop entering now, all xmas competition are closed. a mod told me.....
honest......
__________________
Haswell killer - Long live x58
GTX 1080 FE::Xeon X5650 Hex @ 4Ghz::H110i GT::Asus P6T SE x58::Patriot Tri DDR3 12GB
CoolerMaster 850W RealPower::Phanteks Enthoo EVOLV::Sammy F3 1TB::OCZ SSD 2x120GB::Asus Xonar - HyperX Cloud
Otis1337 is offline   Reply With Quote
Old 6th Dec 2013, 00:48   #16
SchizoFrog
I *am* a Dremel
I'd be happy to win anything. Also, just because I might win a high end prize such as this, doesn't mean I can't find a way for it to benefit me. As for my current system, trust me it is overclocked to it's maximum safe limits. Any higher and I've had random errors and issues with either CPU or GPU. I am hoping to build a completely new system in the new year though, probably based around an mATX as I don't trust the sound available with a Mini-ITX build, no matter how much I would like a system that small.
__________________
Old 29th Dec 2013, 20:15   #17
maverik-sg1
Supermodder
maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.
When can the winners expect to receive their prizes?
maverik-sg1 is offline   Reply With Quote
Old 13th Feb 2014, 10:38   #18
maverik-sg1
Supermodder
Guys - I was informed by Bit-Tech that I was the winner of this motherboard waaaay back in 2013, despite an exchange of emails to Bit-Tech and (so I am informed) from BitTech to YOYOTECH, there's still no sign of my prize.
Please advise.
Old 19th Feb 2014, 16:22   #19
maverik-sg1
Supermodder
Bump! Because I have still yet to receive my prize.
Old 19th Feb 2014, 17:01   #20
Shirty
Moderator
Shirty's Avatar
Try an email to editor@bit-tech.net, and be patient
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
