Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th Dec 2013, 10:06   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Water-cooling the AMD Radeon R9 290X
We strap one of the first full-cover waterblocks to AMD's R9 290X.
http://www.bit-tech.net/hardware/201...deon-r9-290x/1
Meanmotion is offline   Reply With Quote
Old 10th Dec 2013, 10:16   #2
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
Must admit I simply love Aquacomputer's blocks, if only they covered more of the PCB though. I've ended up not using this one for a 290 as there is a lot of PCB, which doesn't look so grand really.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: I Need Healing!, Parvum Argentum, Tower Level 10
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 10th Dec 2013, 11:29   #3
sandys
Mod Master
sandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpit
It covers the chip, the ram and both the VRM points, nothing else is needed, my EK blocks are much the same.
Might be worth noting that r290 and r290x use the same die and board so equally this applies to them for those who might not know.
sandys is offline   Reply With Quote
Old 10th Dec 2013, 11:45   #4
Maki role
Maki role's Avatar
Yeah my complaint isn't really about it being needed, just not looking as nice. EK sells blocks that cover a similar area, but they also sell ones that extend to cover almost all of the PCB itself, even if they offer no additional cooling (I opted for Titan XXL blocks for that reason in my rig). You can see what I mean here:
__________________
Old 10th Dec 2013, 12:11   #5
Panos
Supermodder
Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.
Guys, something is wrong with those benchmarks, and I would expected from bit-tech better job.
On 1920x1200 with 8AA the stock GTX780 has 2372 and the 290X under air 2176.
While few days back, at 2560x1600 with 0AA, the stock GTX780 had 2298 and the 290X under air 2157!
Which means that the PNY XLR8 OC or ZOTAC AMP! GTX780s which are 10% faster than the stock 780, beat here a water cooled 290X @ 1155?
(Before someone calls me a AMD fanboy, I have a PNY GTX780 XLR8 and i7 4820K, just stating the obvious)
Panos is offline   Reply With Quote
Old 10th Dec 2013, 12:42   #6
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Hi Panos. I'm not entirely sure what you mean but you do know that if you run Unigene at different settings, you get different scores? So if you run it at 1,920 x 1,200 with 8x AA, you'll get a different score in the same card as if you tested at ,2560 x 1,600 with 0AA. This is why a few days back we got different results, and in addition, the water-cooled tests were re-done on an entirely different system.
As such, you can't really compare like-for-like these tests in this article with all our other graphics benchmarks as it wasn't conducted in our usual graphics test system due to practical reasons. I hope this explains why the results are different!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 10th Dec 2013, 12:49   #7
Seb.F
Supermodder
Seb.F's Avatar
Seb.F is definitely a rep cheat.Seb.F is definitely a rep cheat.Seb.F is definitely a rep cheat.Seb.F is definitely a rep cheat.Seb.F is definitely a rep cheat.Seb.F is definitely a rep cheat.Seb.F is definitely a rep cheat.Seb.F is definitely a rep cheat.Seb.F is definitely a rep cheat.Seb.F is definitely a rep cheat.Seb.F is definitely a rep cheat.
I think what he's saying is that on the same settings, he was expecting the watercooled 290X to beat the 780, where at present, it isn't?
Seb.F is offline   Reply With Quote
Old 10th Dec 2013, 13:10   #8
Combatus
Moderator
Combatus's Avatar
Ah right okay. Well it's a pretty close call - watercooling the card does add a lot of performance compared to both 100% and 40% fan speed settings especially. However, we're testing using entirely different hardware and settings to other graphics reviews but the point of the article, really, is just to highlight the impact watercooling has on the R9 290X - here we used the same card, the same settings and the same system so I can assure everyone that these results are not wrong
__________________
Old 10th Dec 2013, 13:54   #9
Panos
Supermodder
That is great Combatus. Cheers.
Old 10th Dec 2013, 14:19   #10
TheMadDutchDude
Flying Dutchman
TheMadDutchDude's Avatar
TheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming Saiyan
I'm confused about the temperatures. How does the core get to 72c at various different settings, including slower fan speeds? There's absolutely no way a card will stay as cool at 40% as it does at 100% fan at the same clock speeds. I've heard a 290X and seen the temperature differences. Are you sure they're correct?
TheMadDutchDude is offline   Reply With Quote
Old 10th Dec 2013, 14:20   #11
law99
Custom User Title
law99's Avatar
law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.
be nice to see more wc testing... but I appreciate it is a ball ache what with leak testing etc all adding to the time and potentially expensive if you can't get the items as press items - let alone what ever you think your time is worth.
__________________
3570k WC @ 4.7giggles | 8gb Kingston 2133mhz | ASUS Sabertooth Z77 | soaking 1070 gtx | Seasonic x-660w | NZXT 810 switch | Crucial M4 128gb | 2x F3 1tb Raid 1 | NZXT Sentry 6ch 50w fan controller | BenQ bl3200pt 2560x1440p
law99 is offline   Reply With Quote
Old 10th Dec 2013, 14:47   #12
sandys
Mod Master
The card throttles clocks etc to not exceed 95c max temperature any further, the graph is delta T to ambient so ambient is probably 23c
Old 10th Dec 2013, 14:54   #13
Seb.F
Supermodder
Seb.F's Avatar
I was getting confused there too, didn't notice the delta!
Old 10th Dec 2013, 17:26   #14
Combatus
Moderator
Combatus's Avatar
Correct!
__________________
Old 10th Dec 2013, 17:34   #15
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
I'm glad someone finally benchmarked these cards under water cooling. In a multi-GPU and/or CPU overclock setup, it seems like water cooling is a must have if you want a reliable and quiet system. I'm sure the water cooling companies are thrilled, since water cooling was almost deemed unnecessary for the last couple years, except in some cases.
I also particularly like how water blocks slim down the entire GPU, allowing you easy access to more PCI-e slots. Unfortunately, some of those GPUs still use both slot compartments due to the DVI or DP ports, but, if you have any PCI-e based SSDs, RAID cards, or maybe a GPU for PhysX, you could still use those since you don't need to reach the outside with them.
schmidtbag is offline   Reply With Quote
Old 10th Dec 2013, 17:39   #16
Kovoet
I Mod, Therefore I Own
Kovoet's Avatar
Kovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming Saiyan
Damn I wish I knew how to water-cool as I'm too kak scared. Corsair H100i very easy but this and yet so damn tempting
__________________
MOBO[ Asus Maximus Formula VII ]CPU[I7 4770K]RAM[Corsair Vengeance PRO Red 2133mhz]SSD's[1TB Samsung EVO, 256GB Samsung, 128GB Mushkin, 128 GT Corsair]GPU[EVGA GTX980]PSU[Corsair AX1200i Red Cables]CASE[Corsair 540] Cooler[Corsair H100i]Screen[Dell U2913WM} Perp[Corsair K70, Logitech G502,Belkin razer N52TE,
HyperX Cloud II]
Kovoet is offline   Reply With Quote
Old 10th Dec 2013, 17:48   #17
schmidtbag
Ultramodder
I've never done liquid cooling myself but as far as I'm aware, there are fluids you can use that aren't conductive. Personally, I've considered doing a computer completely submerged in mineral oil (in a fish tank), but I'm not sure if you can use mineral oil in conventional water cooling systems. I'm guessing the viscosity might be a problem.
From what I've heard, the best way to do a water cooled system is to only power on the cooling system but disconnect everything else. Keep an eye open for leaks and if it happens to spray everywhere, you'll be fine. Contrary to what many people believe, water doesn't hurt electronics as long as they're uncharged. Every time I make an upgrade to my (desktop) computers, I take out most of the parts and clean them under a faucet and just wait a day or 2 for them to dry off. Its cheaper and sometimes more effective than air cleaners, and makes the stuff look like new when you're done.
Old 10th Dec 2013, 19:13   #18
somidiot
Multimodder
somidiot has yet to learn the way of the Dremel
I'd be curious to see the GTX 780 or 780 Ti water cooled vs this same setup across the regular benchmark suite, see how far each card can be pushed on water vs. air.
somidiot is offline   Reply With Quote
Old 10th Dec 2013, 19:21   #19
law99
Custom User Title
law99's Avatar
I've had the equivalent of a whole mother ****ing bunch of water all over my **** and all I did was dry it out. Leak test the bits separately outside the case, then move inside and leak test for a solid 12 to 24 hours powering only the pump using the paperclip method on a psu not connected to your PC... then after the green light, you can go right ahead and turn it on.
It is really simple, really, as long as you are methodical in testing and don't get carried away(add an extra trite really? Nah... ).
Only downside is it is more effort to chop and change components that are in the loop. The temp difference is a god send though. Love not worrying about overclocking... really is night and day. Can't go back. Only those all in ones could tempt me, but I'm more worried about one of those exploding than stuff I tightened up and tested myself.
I was quite lucky adopting it at such a late point in my life also as it's all been figured out by other people by now. All the fittings, hose, pumps, rads etc.... simples.
__________________
Old 11th Dec 2013, 10:36   #20
Panos
Supermodder
With that need to put a modified BIOS also that unlocks the maximum voltage, that is hard set to 1.2v to all. (but EVGA Classified)
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
