Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Dec 2013, 10:27   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Intel NUC D54250WYK / D54250WYB Review
The new Haswell version of Intel NUC is better than ever.
http://www.bit-tech.net/hardware/cpu...50wyb-review/1
Meanmotion is offline   Reply With Quote
Old 12th Dec 2013, 11:58   #2
Stanley Tweedle
NO VR NO PLAY
Stanley Tweedle's Avatar
Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.
It's not April 1st yet so why is this thing featured?
£295 is comical of course and that's the reason I'm not falling for this prank.
__________________
One of us is dumb.
Stanley Tweedle is offline   Reply With Quote
Old 12th Dec 2013, 12:31   #3
Blackshark
Multimodder
Blackshark has yet to learn the way of the Dremel
295 for the i7 variety they mentioned - would be more on par
Blackshark is offline   Reply With Quote
Old 12th Dec 2013, 13:08   #4
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Can I ask why it is that you use completely different rating categories and scores between the magazine and the website? Which then led me to check another article for comparison sake and I found that the R9 290X has the same rating categories and score break downs but the same card scored differently between the magazine and the website. So why the inconsistency?
__________________
SchizoFrog is offline   Reply With Quote
Old 12th Dec 2013, 13:08   #5
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
I'm really disapointed by the Intel HD5000.
GuilleAcoustic is offline   Reply With Quote
Old 12th Dec 2013, 14:34   #6
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
Who gives a NUC?
Really don't see the appeal of these sub-Mini-ITX form factors. Why not just buy an AIO?
Baz is offline   Reply With Quote
Old 12th Dec 2013, 16:09   #7
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
I must say I'm loving my NUC, using it as a media PC down in the living room. Can't stand those normal "media boxes" that fit even an ITX mobo, they're simply hideous. Having such a tiny form factor allows for some really interesting case designs, so I can have it on show, without it taking up the whole room like a normal tower of sorts.
I'll admit that they are definitely on the pricey side of things though. The thing is, you can't really grasp how small the NUCs are until you actually hold one, they're minuscule. I'm building an ITX rig atm and it dwarfs the NUC, and that's just through the motherboard size.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: Cheers Luv!
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 12th Dec 2013, 19:12   #8
Stanley Tweedle
NO VR NO PLAY
I've seen some really nice ITX cases.
Of course nice is subjective to some extent.
__________________
One of us is dumb.
Old 13th Dec 2013, 01:53   #9
Bede
Ultramodder
Bede's Avatar
Bede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for president
Streacom have got a nice fanless case for this. Sometime in the new year I'm getting this, or the i3 version, a fanless case and putting XBMC on it. Small, silent, lower-powered and good enough for very smooth service as an HTPC.
I'd be very interested to see what happens when the Intel 5000 graphics are pared with a CPU clocked at over 3GHz, I reckon it'll be an AMD-breaker.
__________________
Coolermaster 690 II Advanced (white edition) | i5-2500K | MSI P67-GD53 | Asus 970 Strix OC | 16gb Corsair Vengeance LP | Gelid Tranquillo
Asus Xonar DS | 700W Coolermaster Silent Pro M | Crucial M4 128GB | SanDisk Ultra II 480GB | Samsung Spinpoint F3 1TB
Bede is offline   Reply With Quote
Old 13th Dec 2013, 09:28   #10
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
The only problem with NUCs as HTPC is that there is nowhere to plug a tuner card...
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is online now   Reply With Quote
Old 13th Dec 2013, 11:00   #11
SchizoFrog
I *am* a Dremel
That kind of thinking is the start of a whole heap of issues and is a little conservative to ever say 'The only...' as the solution to your particular issue is a USB tuner card. I am still totally confused by the lack of a suitable discussions resolution to the issue on sound. So many people talk about on board sound being awful and yet you can not use a dedicated sound device (unless you go USB) for anything smaller than mATX and even with mATX you are then limited to only the sound card and can add nothing else. I really wish this issue regarding sound can be discussed completely and thoroughly as there seems to be no clear line of thinking.
__________________
Old 16th Dec 2013, 09:17   #12
Nexxo
Whatever's Geek.
Nexxo's Avatar
Who wants a USB dongle hanging off the back of a compact little case? Good point about the sound --I wonder if another standalone device would be a solution. There could be stackable modules, starting with the NUC PC and adding tuner, sound and other modules.
__________________
Old 16th Dec 2013, 09:38   #13
chimaera
Multimodder
chimaera has yet to learn the way of the Dremel
Speaking purely personally part of the appeal of HTPCs is the idea of centralising the back-end services to allow deploying multiple clients around the house (Lounge, office, bedroom etc).
So my ideal would be to have a simple XBMC terminal under each screen I needed to deliver services to and have the central database and storage elsewhere. To that I would add a MythTV backend or two to hand TV services and serve them to the client.
But that's just what I'd do
And from that point of view these boxes are pretty much ideal - a little on the pricey side and I'd probably want to look at buying the MB rather than the kit and getting one of the passive-cool cases to eliminate noise entirely.
One quick question - I know the upcoming version of XBMC (Gotham) supports full-size SBS 3D video (ie 3840 x 1080) - anyone know if these boxes can handle playback of these files?
(Bearing in mind that SBS is a lot harder on the hardware than BR3D playback)
chimaera is offline   Reply With Quote
Old 16th Dec 2013, 11:46   #14
GuilleAcoustic
Ook ? Ook !
I've been working on a concept 2 years ago, but never built it (as always) :
It was based on thin mini ITX motherboard, but with the NUC it could be reduced a lot .... maybe not the amp side though
Old 16th Dec 2013, 14:40   #15
Nexxo
Whatever's Geek.
Nexxo's Avatar
Ooh, yeah. Now that's what I'm talking about!
__________________
Old 16th Dec 2013, 14:45   #16
jinq-sea
The Double Insulates
Moderator
jinq-sea's Avatar
jinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyan
http://dvblogic.com/en/
That's my solution to this particular conundrum. It's great.
__________________
Comrade Woody: "I dunno, whores are a bit like cornflakes, you always regret buying the cheap ones."
small(ish): i7-5960X / X99E-ITX/AC - Bitspower Block / 32Gb Ballistix / Titan X (P) / 512Gb Samsung 950 Pro NVMe / 250D
tiny: i7-4790K / Max VII Impact - EK Monoblock / 16Gb Ballistix / EVGA Titan X (M) HC / 256Gb SM951 NVMe / nCase M1
htpc/vr: i7-6700K / Z170i / 16Gb Ballistix / EVGA 1080 Founders Edition / 128Gb SM951 NVMe & Sandisk 960Gb SSD / RVZ01
jinq-sea is offline   Reply With Quote
Old 16th Dec 2013, 15:06   #17
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
The new NUC, allthough it misses a PCIe x1/x2 for a tuner, is still the best solution for a HTPC imho, especially now as they've added a SATA-port.
Sound is done via USB-DAC and as most new TVs have triple-tuners anyways, there's no reason for a TV-tuner anymore, if you don't plan on recording TV-shows, which I don't.
The new NUC isn't cheap, especially compared to a mITX D2550/E350 board, but the size makes it very attractive, aswell as the more powerful CPU and the integrated IR-sensor in comparison to the two mentioned.
Oh, and Guille... look at this interesting piece of hardware and it's dimensions -> http://www.thomann.de/fi/teac_a_h01_b.htm
Build a matching box for a mITX-board and voilŠ
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 16th Dec 2013, 15:06   #18
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
Oh ye of little faith and imagination. The board has has a USB2 header, surely someone of the modding inclination could incorporate the tuner dongle into a custom case... likewise a USB DAC could be hooked up to the other header port for sound...
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is offline   Reply With Quote
Old 16th Dec 2013, 15:37   #19
GuilleAcoustic
Ook ? Ook !
Very interesting, but I'm more into things like this (too bad that it is smaller than the Streacom F1C) :
http://www.streacom.com/products/tl1-tube-amplifier/
But with it's 2x 2.5W it's only for ultra efficient speakers (97db and above I'd say)
Old 17th Dec 2013, 19:44   #20
Nexxo
Whatever's Geek.
Nexxo's Avatar
I am ashamed.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
