Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 14th Dec 2013, 13:42   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
SteamOS beta download now available
Valve has made a beta of SteamOS available for download.
http://www.bit-tech.net/news/bits/20...ow-available/1
Meanmotion is offline   Reply With Quote
Old 14th Dec 2013, 14:00   #2
Gigglebyte
:3
Gigglebyte's Avatar
Gigglebyte has yet to learn the way of the Dremel
Very exciting indeed, looking forward to dual booting this on a couple of machines later to take it for a spin!
Gigglebyte is offline   Reply With Quote
Old 14th Dec 2013, 16:29   #3
Narishma
Multimodder
Narishma has yet to learn the way of the Dremel
You can't dual-boot it for the moment.
Narishma is offline   Reply With Quote
Old 14th Dec 2013, 16:48   #4
erratum1
Banned
erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.
It's interesting does cutting out windows do anything for performance?
As I don't play many games these days don't think i'll be turning my pc into a gaming machine.
erratum1 is offline   Reply With Quote
Old 14th Dec 2013, 17:58   #5
Cthippo
Can't mod my way out of a paper bag
Cthippo's Avatar
Cthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming Saiyan
See, that's kind of the point. It's linux, YES YOU CAN dual boot it, you might just have to put in a little more effort to find the dual boot program and set it up properly. Linux doesn't limit what you can do, it just might not support it out of the box.
In this case (IIRC) you install Windows, install Gparted, and then install linux. The computer boots into Gparted and then asks you what actual OS you want to boot into. The functionality is there, it's just not always the easiest to figure out.
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade.
Cthippo is offline   Reply With Quote
Old 14th Dec 2013, 18:24   #6
Glix
Left Thumb Stick in the mud.
Glix has yet to learn the way of the Dremel
He meant the installer blasts all partitions.
Glix is offline   Reply With Quote
Old 14th Dec 2013, 18:47   #7
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.
Yawn. Don't care...another mediocre Linux distro.
__________________
The Box:i7 2700K@5.3GHz|EK Supreme LT+Coolstream XT 360|16GB HyperX DDR3@1866MHz|EVGA GTX780 ti+EK FC780ti|MSI P67A-GD55||M5 512|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Perixx MX2000 + Intuos 4M
Audio: PC->TosLink->TEAC UD-501->Fostex TH600|InEar LivePro 3|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 14th Dec 2013, 19:08   #8
Andy Mc
I *am* a Dremel
Andy Mc's Avatar
Andy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming Saiyan
I see it didn't take long for the trolls to come out of the woodwork...
__________________
Andy Mc is offline   Reply With Quote
Old 14th Dec 2013, 21:44   #9
Yslen
Lord of the Twenty-Seventh Circle
Yslen's Avatar
Yslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming Saiyan
Yes. It makes it worse.
I'm yet to see a cross platform game that runs faster under Linux.
__________________
Asrock Z77e-ITX - Intel i5 3570k - Corsair H100i - G.Skill Ripjaws X 2133MHz - MSI GTX 970 - Crucial M4 - 530W ThermalTake SS PSU - Corsair 250d - LG IPS231P - Logitech G302 - Many, many keyboards
Take a look at my Photography portfolio, here.
Yslen is offline   Reply With Quote
Old 14th Dec 2013, 22:08   #10
leslie
Just me!
leslie's Avatar
leslie has yet to learn the way of the Dremelleslie has yet to learn the way of the Dremel
There are two installers, one is a system image which will wipe everything like a Windows restore disk, the other, I believe, is a normal Debian installer (which Steam OS is based on), that one's easy. The restore disk version either needs a separate drive or install it first, then your second OS. Regardless, you can dual boot both.
__________________
When in doubt, wear red. - Bill Blass
leslie is offline   Reply With Quote
Old 14th Dec 2013, 23:18   #11
Pliqu3011
The cake is an alternative fact
Pliqu3011's Avatar
Pliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming Saiyan
So you've tried it already and found the user experience "mediocre"?
Or is you opinion based purely on assumptions and factless prejudice towards "another" linux distro or linux in general?
Game performance? No. Graphics drivers for Linux are generally still not as good as their Windows equivalents. Hopefully the new push to Linux by developers will encourage AMD and nVidia to put more effort into them. If your only concern is the best gaming performance, I don't think you'll want to switch anytime soon.
However, for general desktop performance you will notice an improvement, from what I've seen. Most of your experience will be based on personal preference though.
(If you're not planning on playing a lot of games, but are interested in Linux, I'd recommend to just try a well-established, beginner-friendly linux distro like Ubuntu or Linux Mint through wubi (or on a VirtualBox). It'll create a small virtual harddrive within your Windows partition and can be uninstalled just like any other program. If you like it you could later on go to a full dual-boot, or try out SteamOS when it's a bit better supported. If you don't, then you can just uninstall it with the click of a button. It's both free and risk-free, so why not give it a shot?)
__________________
“Talent is a pursued interest. In other words, anything that you're willing to practice, you can do.” - Bob Ross
“Ὁ βίος βραχύς, ἡ δὲ τέχνη μακρή, ὁ δὲ καιρὸς ὀξύς, ἡ δὲ πεῖρα σφαλερή, ἡ δὲ κρίσις χαλεπή.” - Hippocrates
Pliqu3011 is offline   Reply With Quote
Old 15th Dec 2013, 05:53   #12
dyzophoria
Supermodder
dyzophoria has yet to learn the way of the Dremel
hope it does good for valve, though I seriously was hoping they should have just focused on developing HL3
__________________
[FONT=Lucida Console]picture this..[/FONT] // [FONT=Tahoma][FONT=Fixedsys]picture that..[/FONT][/FONT]
dyzophoria is offline   Reply With Quote
Old 15th Dec 2013, 09:31   #13
erratum1
Banned
Thanks for the info.
Old 15th Dec 2013, 10:56   #14
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
I think I'll get it and hang on to it even if I choose not to install it, let alone use it. The main reason for this is the cynic in me that thinks that one day things like this may not be free and having this version already may well provide me with what is needed for a back door. I do like testing things BEFORE I hand over money for them.
__________________
SchizoFrog is offline   Reply With Quote
Old 15th Dec 2013, 11:40   #15
Measter
Multimodder
Measter has yet to learn the way of the DremelMeaster has yet to learn the way of the Dremel
They're required by law to provide the source code, so the OS will always be free. Some things that come with it, such as the Steam client, are not open source, so they could still charge for that.
Measter is offline   Reply With Quote
Old 15th Dec 2013, 12:04   #16
Cthippo
Cthippo's Avatar
"By law" is a bit of a misnomer, but the linux code that it's based on is all licensed under the General Public License and part of what that means is that all derivative products must also be open source. This is more of a contractual issue, but it is legally enforceable and has been upheld in court.
__________________
Old 15th Dec 2013, 12:19   #17
Corky42
I Mod, Therefore I Own
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
The performance of a game has less to do with the OS, and more to do with the drivers and optimisations done on the graphics API.
According to Valve’s own blog post testing done on L4D2, DirectX running on Windows hit 270.6 fps, OpenGL on Linux hit 315 fps, and OpenGL on Windows ran at 303.7 fps.
I found the following article informative on the differences between gaming on Windows vs Linux
http://www.extremetech.com/gaming/16...d-nvidia?print
Corky42 is offline   Reply With Quote
Old 15th Dec 2013, 13:12   #18
DriftCarl
Supermodder
DriftCarl is the Cheesecake. Relix smiles down upon them.DriftCarl is the Cheesecake. Relix smiles down upon them.DriftCarl is the Cheesecake. Relix smiles down upon them.DriftCarl is the Cheesecake. Relix smiles down upon them.DriftCarl is the Cheesecake. Relix smiles down upon them.DriftCarl is the Cheesecake. Relix smiles down upon them.DriftCarl is the Cheesecake. Relix smiles down upon them.DriftCarl is the Cheesecake. Relix smiles down upon them.DriftCarl is the Cheesecake. Relix smiles down upon them.DriftCarl is the Cheesecake. Relix smiles down upon them.DriftCarl is the Cheesecake. Relix smiles down upon them.
I installed it onto a VirtualBox image last night just to see what the fuss is about. So its no different from steam running on windows.
it IS just debian with steam installed onto it, maybe a bit of a UI change, im not familiar with debian on its own.
I don't know what I expected, maybe something a bit more customised, but its clearly just linux with steam installed, no reason why someone couldn't just install it onto their own already built linux machine.
I downloaded DOTA2, didnt run very well because, well it was a VM.
I think I would rather stick to PC gaming, my PC is in my living room anyway
DriftCarl is offline   Reply With Quote
Old 15th Dec 2013, 19:40   #19
forum_user
forum_title
forum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyan
My gaming PC is in my study/office. With a tidy SteamOS box in my lounge, I will be streaming games on the big lounge screen when the missus goes to bed. Lots of the oldskool adopters of Steam have grown up and gotten bigger houses and will likely be doing same as me.
forum_user is offline   Reply With Quote
Old 15th Dec 2013, 21:10   #20
theshadow2001
[DELETE] means [DELETE]
theshadow2001's Avatar
theshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyan
I haven't installed it virtually or otherwise. But from what I've seen its just debian with a few packages missing and the steam client installed. Thats about all steamOS really will be even after beta, perhaps slightly more restricted.
It's all a bit disappointing really. I was at least expecting some sort of customized desktop or interface, instead of just a bare debian/gnome combo.
theshadow2001 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
