Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 17th Dec 2013, 11:28   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
BT modems have NSA back-door, claim researchers
"Never trust closed source routers."
http://www.bit-tech.net/news/hardwar...bt-back-door/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 17th Dec 2013, 11:46   #2
Gareth Halfacree
WIIGII!
bit-tech Staff
Added a couple of comments from people who say that the paper is making a mountain out of a decidedly not-DoD-flavoured molehill. Yes, that means an already lengthy piece is even longer. Grab a coffee.
__________________
Old 17th Dec 2013, 12:20   #3
John_T
Supermodder
John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.
Nothing wrong with a long article: I'd rather it was long and properly balanced than short for the sake of it. As someone who uses the BT setup I wouldn't mind seeing a follow-up to this to see whether there actually is anything in it. Not that I do anything I don't particularly want 'authorities' to know about, but you know, it's the principal of the thing...
John_T is offline   Reply With Quote
Old 17th Dec 2013, 13:07   #4
forum_user
forum_title
forum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyan
BT won't be able to say it is true even if it is, so, safe to assume a full denial incoming?
[homehub]
Shutdown router.
[/homehub]
forum_user is offline   Reply With Quote
Old 17th Dec 2013, 13:21   #5
Brooxy
Like a boss (but not a boss)
Brooxy's Avatar
Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.
This. I'm also using the Homehub 4 setup, along with the Openreach Modem - if any more information about this comes up, it would be interesting to know, no matter how boring my internet history is...
Kind of scary that we've entered a time when all tinfoil hat-esque ideas are becoming more of a reality. What's next, NSA backdoor hidden in my ethernet enabled blu-ray player? GPS Tracking bug built into the ECU of my car, with dialler to dial back to the NSA? (Not likely - it's a poverty spec 2002 Golf, but you get the gist of what i'm getting at...)
Last edited by Brooxy; 17th Dec 2013 at 13:49. Reason: Because I'm a dope and mistyped the version of my homehub... *facepalm*
Brooxy is offline   Reply With Quote
Old 17th Dec 2013, 13:29   #6
Gareth Halfacree
WIIGII!
bit-tech Staff
Originally Posted by Brooxy View Post
This. I'm also using the Homehub 5 setup, along with the Openreach Modem
Interesting. The Home Hub 5 was the first to include a built-in dual-mode ADSL/VDSL modem, meaning it works without the Openreach VDSL modem. The instructions for the Home Hub 5, however, don't reflect this; "If you're on Infinity Option 1 or Option 2," they explain, "connect the Home Hub 5 to the modem via an Ethernet cable." When my Infinity Option 2 was fitted, the Openreach engineer didn't bring a modem; when I queried why, concerned that he was installing plain-old ADSL2+, he confirmed that they're no longer required with the Home Hub 5 - and, indeed, BT had stopped using 'em because they had a tendency to overheat.
You, however, have a Home Hub 5 and an Openreach modem - even though you don't need two boxes. When was your broadband installed, out of interest?
__________________
Last edited by Gareth Halfacree; 17th Dec 2013 at 13:37. Reason: I accidentally a word.
Old 17th Dec 2013, 13:48   #7
Brooxy
Brooxy's Avatar
Well this is embarrasing - meant to type Homehub 4 not 5...although in answer to the question, it was installed in August I think.
Old 17th Dec 2013, 14:10   #8
Gareth Halfacree
WIIGII!
bit-tech Staff
That would explain it; the 4 has no VDSL capabilities - just ADSL. Still doesn't explain why the HH5 manual clearly states you'll get a separate modem if you're on Infinity, though.
__________________
Old 17th Dec 2013, 14:17   #9
liratheal
Sharing is Caring
liratheal's Avatar
liratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyanliratheal is a Super Spamming Saiyan
You know what. If it's true, anyone still using those aborted foetus' of routers deserve it.
__________________
Shadow Moses: Windows 10, Asus Sabertooth X58, 12gb Corsair XMS3, i7 950, Sapphire RX480 4gb, Corsair 1kw.
2008 Mondeo estate
Focus RS Mk1; Build number 1506
liratheal is offline   Reply With Quote
Old 17th Dec 2013, 14:29   #10
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
At this point I'll not be surprised if my analogue watch is always listening to me tbh. Anyone else feel the same?
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is online now   Reply With Quote
Old 17th Dec 2013, 14:53   #11
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.
And kids, this is why I always use my own router with OpenWRT - and it's not just because ISP routers have horrifically crap hardware+firmware that's locked down like mad.
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | XFX Radeon 7970 DD | 500GB Samsung 840 Evo | Samsung XL2270HD | KBT Race | Logitech G402
Mac: 13 inch MacBook Pro 2014 | 16GB RAM | Filco Minila Air | Magic Trackpad
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 | Arch Linux
r3loaded is offline   Reply With Quote
Old 17th Dec 2013, 15:26   #12
Atomic
Gerwaff
Atomic's Avatar
Atomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming Saiyan
It's not the router that has the backdoor, it was the modem so you'd not be safe.
__________________
:: All your PowerShell are belong to me ::
Atomic is offline   Reply With Quote
Old 17th Dec 2013, 15:29   #13
Bloodburgers
Multimodder
Bloodburgers has yet to learn the way of the Dremel
Well my watch keeps telling me things so am sure its more than capable of listening too.
__________________
Leviathon: Asus Sabertooth 990FX, AMD FX8320, Corsair H40, 8GB Corsair Vengeance 1866Mhz, Seagate 2TB , CORSAIR HX 520W MODULAR PSU, XFX HD7850 2GB Black Edition
Bloodburgers is offline   Reply With Quote
Old 17th Dec 2013, 16:05   #14
GeorgeStorm
Aggressive PC Builder
GeorgeStorm's Avatar
GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.
Someone I know who does networky stuff (as far as I'm aware) commented on this earlier:
They use DOD space because it's not internet-routable, and it's for the TR-069 ( http://en.wikipedia.org/wiki/TR-069 ) service. This is *NOT* news.
The internet is full of these idiots who think they know better -- yet this one could be easily passed off by saying "why would they do it to your modem/router when they control the transport infrastructure". They'd tap it at the exchange, not your £10 Huawei modem!
It was already in NetworkWorld, AAISP have had to rebuke it, it's bonkers.
__________________
"Anyone who just plays games for fun is a n3rd" - Jörge "I should be in prison for what I'm thinking right now" - Will
My Parvum Systems build log - My flickr - My blog it'sfilmnotmovie - hwbot
I identify as mayonnaise-kin, think of it as white without the privilege.
GeorgeStorm is offline   Reply With Quote
Old 17th Dec 2013, 16:15   #15
Umbra
Hypermodder
Umbra's Avatar
Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.
It wouldn't surprise me if my BT H%£e sm%^T ph%£$ is monitoring me
Umbra is offline   Reply With Quote
Old 17th Dec 2013, 16:16   #16
Umbra
Hypermodder
Umbra's Avatar
OK, That's weird, who censored my post
Old 17th Dec 2013, 16:23   #17
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming Saiyan
it was your BT Home smart phone ;-) whatever one of those is, lol
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 17th Dec 2013, 18:06   #18
Omnituens
Hypermodder
Omnituens's Avatar
Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.Omnituens is a hoopy frood who really knows where their towel is.
Is it just me, or is the plot of MGS2 starting to make a little bit more sense?
Won't be long before words start to get La-li-lu-le-lo'ed
__________________
Current Rig: i7 D0 4.2GHz, X58 Sabertooth, 12GB RAM, GTX 680, Xonar D2X
Omnituens is offline   Reply With Quote
Old 17th Dec 2013, 19:05   #19
John_T
Supermodder
Maybe I am stupid for using the (perfectly functional) kit that I already paid for (without choice) from my ISP, but I "deserve" it? Really? At least I understood the article.
Besides, what makes you think that only ISP supplied hardware would then be affected? If this story were true, (GeorgeStorm's post aside for a moment) do you think other brands of hardware wouldn't also be affected? Perhaps you've simply chosen one with a backdoor for a different country's security agency...
Old 17th Dec 2013, 19:10   #20
John_T
Supermodder
Yep, put me in that category. I used to file stories like this under 'tinfoil hat brigade' - the last few years have increasingly proved that the tinfoil hat wearers were actually the sensible ones and it's the rest of us that were deluded. Definitely makes you paranoid!
Reply
Tags
backdoor, bruce schneier, bt, bt broadband, bt infinity, department of defence, dod, edward snowden, gchq, government, isp, leak, modem, nsa, privacy, router, security, snowden, vlan
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
