Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 17th Dec 2013, 19:26   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
SteamOS, Steam Machine and Controller shown in video
Valve's new Steam Machine and Controller gets an outing on video.
http://www.bit-tech.net/news/gaming/...roller-video/1
Meanmotion is offline   Reply With Quote
Old 17th Dec 2013, 19:56   #2
greypilgers
Supermodder
greypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysisgreypilgers can run Crysis
Always Left4Dead2 and Portal2... Don't get me wrong, they're seminal games, but sheeeeeeeet... When are they gonna at least apply a demo of something slightly less, well, ancient?
__________________
Bungletron: And certainly if my house was burglarized I would phonerelize the police right away, what idiot would not?
greypilgers is offline   Reply With Quote
Old 17th Dec 2013, 20:37   #3
Teknokid
Ultramodder
Teknokid is the Cheesecake. Relix smiles down upon them.Teknokid is the Cheesecake. Relix smiles down upon them.Teknokid is the Cheesecake. Relix smiles down upon them.Teknokid is the Cheesecake. Relix smiles down upon them.Teknokid is the Cheesecake. Relix smiles down upon them.Teknokid is the Cheesecake. Relix smiles down upon them.Teknokid is the Cheesecake. Relix smiles down upon them.Teknokid is the Cheesecake. Relix smiles down upon them.Teknokid is the Cheesecake. Relix smiles down upon them.Teknokid is the Cheesecake. Relix smiles down upon them.Teknokid is the Cheesecake. Relix smiles down upon them.
I'd love to buy the case and install my own small form factor PC in there, It seems like a really good concept to me
Teknokid is offline   Reply With Quote
Old 18th Dec 2013, 08:45   #4
flibblesan
Destroyer
flibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpitflibblesan is almost as Godly as yodasarmpit
I really like that case.
flibblesan is offline   Reply With Quote
Old 18th Dec 2013, 16:16   #5
ziza
Multimodder
ziza's Avatar
ziza has yet to learn the way of the Dremel
I have some concerns with regards to cooling and temperatures, since there are no vents for GPU and I was not able to check the PSU. The cable management built in plastic it is also no good for cooling.
__________________
Per me si va nella cittą dolente,
per me si va nell'eterno dolore,
per me si va tra la perduta gente
ziza is offline   Reply With Quote
Old 18th Dec 2013, 21:45   #6
siliconfanatic
Johny-come-Lately
siliconfanatic's Avatar
siliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyan
I was under the impression that the steambox was going to be using AMD's R9 290, not a 780?
__________________
Do not let anything good in life pass you by. Cherish it with all of your heart, because before you know it even life will have passed you by. And if you let all those things pass you by? The only thing filling your heart will be deep sadness and regret. So whatever you do, hold on, and never let go.
siliconfanatic is offline   Reply With Quote
Old 18th Dec 2013, 22:03   #7
theshadow2001
[DELETE] means [DELETE]
theshadow2001's Avatar
theshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyan
The gpu sucks air in through a vent below the card and blows it out the rear by the i/o. The power supply cpu and gpu all have their own segregated air flow paths
theshadow2001 is offline   Reply With Quote
Old 19th Dec 2013, 00:17   #8
SexyHyde
Supermodder
SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.
Looks fairly decent. I can see room for improvement with the layout, but it's a solid compact start. I'm also wondering whether a btx 'style' cooling setup would be better, as you could have one piece of ducting, one or two channels and cable management and hard drive mounts incorporated.
SexyHyde is offline   Reply With Quote
Old 19th Dec 2013, 01:20   #9
Corky42
I Mod, Therefore I Own
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
Seeing as its very unlikely that Valve is going to make more than these 300 beta test units i couldn't care less how they are built. What im looking forward to is CES 2014 in January and the Valve developers conference after it, as i think we will be seeing a lot more OEM's showing of what their take on a Steam Machine.
Corky42 is offline   Reply With Quote
Old 20th Dec 2013, 00:31   #10
SexyHyde
Supermodder
I think Valve would be stupid to not sell a unit of their own as people would buy a Valve model just because it's Valve. There is a plenty big enough market for a few premium paint models and they could charge a ridiculous amount for a 'companion cube' special.
I'm excited for the future too, but these are a signal of whats to come. Valve will want OEM's to stick to a few key design features. As crap ones will be bad publicity and will tarnish the otherwise great offerings i'm sure we will see.
Old 20th Dec 2013, 01:00   #11
forum_user
forum_title
forum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyan
I would buy a companion cube for sure! Especially if it was a limited edition SteamBox, first release, from Valve, signed by Gabe and Valve staff.
Your mention of a "few key design features" reminds me of many mentions of the 'SteamBox certification' - whether true or not (unconfirmed) - it makes perfect sense for Valve to maintain control over the hardware specs. A third party console that is SteamBox certified can have elevated customer support over Steam PCs due to having some kind of manageable standards in place. A console without great support would be a nightmare for Valve, the 3rd parties, and the customers.
forum_user is offline   Reply With Quote
Old 20th Dec 2013, 10:37   #12
whamio
Minimodder
whamio has yet to learn the way of the Dremel
build your own steam machine, load their os, use the new controller.....what's the problem?
whamio is offline   Reply With Quote
Old 20th Dec 2013, 10:41   #13
Andy Mc
I *am* a Dremel
Andy Mc's Avatar
Andy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming Saiyan
I'm still miffed that the 300 steam boxen ended up being US only in the end...
__________________
Andy Mc is online now   Reply With Quote
Old 20th Dec 2013, 10:54   #14
Corky42
The problem is we cant buy the controller yet.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
