Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th Jan 2014, 10:07   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Valve names first Steam Box hardware partners
Scan, Alienware and Gigabyte included.
http://www.bit-tech.net/news/hardwar...box-partners/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 6th Jan 2014, 10:34   #2
KidMod-Southpaw
KidMod-Southpaw's Avatar
KidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming Saiyan
Ooh, a Scan Steambox! CES is going to be a good one this year!
__________________
Project Logs: Refraction - Steampunk Flash Drive - Steel; Sleek; Slate
BitFenix Prodigy - Gigabyte Z87N - Intel 4670K - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - M4 128GB - WD Red 1TB X2 - H60 - Antec 650W - Dell U2312HM - Poker MX Red - Sennheiser HD 598
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 6th Jan 2014, 10:39   #3
dyzophoria
Supermodder
dyzophoria has yet to learn the way of the Dremel
After trying out the steam OS I still have to see why I would like to replace my steam client on my windows machine =\
__________________
[FONT=Lucida Console]picture this..[/FONT] // [FONT=Tahoma][FONT=Fixedsys]picture that..[/FONT][/FONT]
dyzophoria is offline   Reply With Quote
Old 6th Jan 2014, 10:56   #4
Snips
I can do dat, giz a job
Snips's Avatar
Snips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming Saiyan
It works well as a dual boot doesn't it? I haven't tried it but I'm sure I've seen it somewhere here that there are advantages.
Snips is offline   Reply With Quote
Old 6th Jan 2014, 11:31   #5
dyzophoria
Supermodder
It should work, its generally just another linux distro (well custom distro) with the steam client smacked on as the default window manager, at the moment I just don't see the point (other than maybe, and its a big maybe that games will perform a bit better on a dedicated gaming OS), but after testing trying it out questions like "what if I want to work on a project while gaming, what if Wanted to write a document in Word and decided to set a game to Window Mode, well the basic of what I do most of the time. then it makes you realize the steam OS is really just for the Living room, the benefit that this could bring that I see is I have a game bought through the steam client, then it should be available as well to the HTPC running steamOS as well, if valve pulls it off then it should be easier to have a HTPC, still depends though if building and setting up an HTPC was already easy for you in the first place
__________________
Old 6th Jan 2014, 11:32   #6
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
If you have a capable Windows machine nether do i, well unless for some reason you cant use that in the living room. But then I'm not sure you would be Valve's target market as I'm guessing you have already bought into the Steam ecosystem.
Corky42 is offline   Reply With Quote
Old 6th Jan 2014, 12:09   #7
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
I take it that's not Next the clothes shop?
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP³ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 6th Jan 2014, 12:12   #8
Gareth Halfacree
WIIGII!
bit-tech Staff
I dunno... They did release an 'own-brand' tablet.
__________________
Old 6th Jan 2014, 17:14   #9
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
It does have money to burn after all!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 6th Jan 2014, 17:21   #10
The_Crapman
The exhaust fan will probably have an attachment for air wick* refills so it doubles as an air freshener.
*other air fresheners are available. See your local retailer.
__________________
Old 6th Jan 2014, 19:11   #11
Jimbob
Multimodder
Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.
You've been able to buy Steam Boxes for ages, we all just called them Linux powered HTPCs before. I'm genuinely confused as to why people think these will do well. I don't see how they are better in any way to a Windows powered PC that can run a massive library of games already and comes in a multitude of form factors from hundreds of manufactures.
You can walk into any independant shop right now and they will build a gaming HTPC for you no problem. Plug in an xBox controller and install Steam and job's done.
Jimbob is offline   Reply With Quote
Old 6th Jan 2014, 19:31   #12
Pliqu3011
The cake is an alternative fact
Pliqu3011's Avatar
Pliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming Saiyan
SteamOS is not meant for you or me. It's meant for people who want a console-like "plug and play" user experience, with powerful pc-like hardware, the option to change and customize stuff should they ever want it and upgradeability in the future.
I think it's a bit too early to judge whether or not Steam Machines and SteamOS are something people will want to buy. Maybe it'll be like when the first tablets came out: everyone thought "why the hell would you ever want that?", and now they're everywhere.
__________________
“Talent is a pursued interest. In other words, anything that you're willing to practice, you can do.” - Bob Ross
“Ὁ βίος βραχύς, ἡ δὲ τέχνη μακρή, ὁ δὲ καιρὸς ὀξύς, ἡ δὲ πεῖρα σφαλερή, ἡ δὲ κρίσις χαλεπή.” - Hippocrates
Pliqu3011 is offline   Reply With Quote
Old 6th Jan 2014, 22:48   #13
SAimNE
Multimodder
SAimNE has yet to learn the way of the Dremel
i think his point is that it already is plug and play. get someone to build a pc and slam steamOS on it, and buy an xbox360 controller or just wait and grab the steam controller... you literally would have no real differences in the experience. just plug everything up and shoot stuff/solve puzzle/free hyrule.... that easy.
SAimNE is offline   Reply With Quote
Old 6th Jan 2014, 22:56   #14
erratum1
Banned
erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.
You say that as someone who knows about computers your average joe can only walk in a shop and ask for an xbox one or ps4...Steam are hoping to persuade them to ask for a Steambox.
Many will have never heard of Steam.
erratum1 is offline   Reply With Quote
Old 6th Jan 2014, 23:47   #15
Pliqu3011
Pliqu3011's Avatar
And this is exactly what Valve wants. What you are talking about is the concept of a "Steam Machine". What's the difference between buying it from a manufacturer or from a local computer store, or even building it yourself if you know how? In the end it's still a plug-and-play machine that gives the comfort and user experience of a console, with the functionality of a PC.
I don't think Valve's main aim is to get those pre-made boxes in everyone's livingroom, but instead to spread "a PC with SteamOS" (aka Steam Machine) as a valid, simple and well-recognised alternative to consoles (and by consequence push more games towards Linux).
__________________
Old 6th Jan 2014, 23:49   #16
SexyHyde
Supermodder
SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.
The best way to look at it is Valve are building a console. An open console. You could make your own, pay someone to make a similar one or just buy one in a box at a gaming shop. Valve are looking at expanding their market with this.
I'm interested at the price points these will be retailing for. And the controller needs to be out yesterday.
SexyHyde is offline   Reply With Quote
Old 7th Jan 2014, 01:59   #17
Vallachia
Minimodder
Vallachia is the Cheesecake. Relix smiles down upon them.Vallachia is the Cheesecake. Relix smiles down upon them.Vallachia is the Cheesecake. Relix smiles down upon them.Vallachia is the Cheesecake. Relix smiles down upon them.Vallachia is the Cheesecake. Relix smiles down upon them.Vallachia is the Cheesecake. Relix smiles down upon them.Vallachia is the Cheesecake. Relix smiles down upon them.Vallachia is the Cheesecake. Relix smiles down upon them.Vallachia is the Cheesecake. Relix smiles down upon them.Vallachia is the Cheesecake. Relix smiles down upon them.Vallachia is the Cheesecake. Relix smiles down upon them.
The one thing I am most excited about with SteamOS is the one that seems to get almost no attention:
Valve are working towards vastly better Linux driver support for Nvidia GPUs and for Nvidia digital audio under linux. Imagine a proper Nvidia driver with full surround sound over HDMI instead of stereo only. And if AMD want any of the SteamBox pie, they will have to come to the table with decent drivers too.
Vallachia is offline   Reply With Quote
Old 7th Jan 2014, 07:58   #18
Corky42
AMD are beavering away on new Linux Drivers, they released 13.12 last month with a bunch of fixes.
If anyone is interested arstechnica has a gallery and most of the specs from each of the announced partners.
Reply
Tags
alienware, alternate, cyberpowerpc, falcon northwest, gigabyte, ibuypower, linux, linux gaming, materiel.net, origin pc, scan, steam, steam box, steam machine, steamos, va, webhallen, xi3, zotac
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
