Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 7th Jan 2014, 10:34   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
EVGA Z87 Stinger Review
We test the Z87 Stinger - EVGA's answer to Asus' Maximus VI Impact.
http://www.bit-tech.net/hardware/mot...inger-review/1
Meanmotion is offline   Reply With Quote
Old 7th Jan 2014, 14:24   #2
Sim0n
rm -rf /
Sim0n's Avatar
Sim0n has yet to learn the way of the Dremel
Is this the mITX motherboard thats designed to fit "perfectly" into the hadron air ? As in the heatsink holes line up to the inbound backplate of the chassis. Allowing easier fitting on aftermarket aircoolers.
Sim0n is offline   Reply With Quote
Old 7th Jan 2014, 20:06   #3
Cei
pew pew pew
Cei's Avatar
Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.
Yep, this is "the" board designed for the Hadron...but the Impact fits fine.
I was torn between this board and the Impact when I was putting my rig together, and went for the Impact. Simply put, the daughter soundcard, better VRMs and bundled WiFi/Bluetooth are actual value features with practical use, which EVGA didn't match. It's a shame, as I would have liked an entirely EVGA made box
__________________
Join the BitSec organisation in Star Citizen! | Fleet Roster
i7 3770K | Asus RoG Maximus V Gene | 16GB 1866Mhz Vengeance | Crucial M4 256 & Samsung EVO 500 | Corsair H105 | Corsair AX860 | GTX 1080 FE | Air 240
i5 4670K | Asus RoG Maximus VI Impact | 8GB 1866Mhz Vengeance LP | Samsung 840 EVO 128GB | Noctua NH-U9B SE2 | GTX 770 SC 2GB | EVGA Hadron Air
Cei is offline   Reply With Quote
Old 7th Jan 2014, 21:05   #4
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Originally Posted by Cei
...went for the Impact. Simply put, the daughter soundcard...
How have you found the sound of the Impact, anything noticeable over standard sound ? What speakers are you using if you don't mind me asking?
__________________
SchizoFrog is offline   Reply With Quote
Old 7th Jan 2014, 21:15   #5
B NEGATIVE
All Hail Kim Jong Magoo!
B NEGATIVE's Avatar
B NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming Saiyan
If the BIOS is still up to recent EVGA standards then i will pass.
Shame,I have a soft spot for EVGA as a company,all went a bit bobbins after Shamino left.
I cant say i noticed any improvement with my impact...my ears are battered from years of Drum and Bass raves tho.....
B NEGATIVE is offline   Reply With Quote
Old 7th Jan 2014, 21:16   #6
Cei
pew pew pew
Cei's Avatar
I'm using Bowers & Wilkins MM-1 speakers most of the time, which being USB don't use the soundcard. However, my headphones are constantly plugged in to the Impact (Razer Carcharias), and there is noticeably less 'hiss' over the output (coming from a Realtek HD), and a generally fuller sound.
I've run the MM-1s over a standard 3.5mm jack as well, and they sound good. I've also had it hooked to my home cinema (a Sony STR-DA1030 receiver, two Sony SS B4ED speakers for fronts and Mordaunt Short rears/centres) with a noticeable difference.
__________________
Old 8th Jan 2014, 00:12   #7
SchizoFrog
I *am* a Dremel
Damn... I seem set to continue my dilemma regarding a m-ITX or Micro-ATX build next time around.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
