News Asus announces PG278Q and PB287Q gaming monitors
Discussion in 'Article Discussion' started by Meanmotion, 7 Jan 2014.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. GeorgeStorm
    16 Dec 2008
    1440p 120hz me likey.
    Scared of what the price will be once it's actually released in the UK though.
  3. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Hasn't AMD tried to say that G-Sync is pointless?
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    If you're after a 2560x1440 IPS panel with G-sync then Overlord, sellers of the overclockable Korean IPS monitors, announced that they are working with Nvidia on G-sync.
    They didn;t quite tell the whole truth. VESA do mention the potential for varying the VBLANK timing in standards documentation. What the standards don't mention is a set method of reacting to that variance. It is perfectly within the standard for a monitor to just display "NO SIGNAL", show garbage, or show duplicate frames if it gets odd VSYNC timings. There's no requirement for monitors to handle arbitrary VBLANK triggering, so the vast majority don't. I'd bet money that the demo laptops (Satellite Click) they used in their freesync demo will only work due to having one specific model of panel, and if another panel (of equivalent LVDS timings) were substituted it would not function.
    That is what G-Sync is for: providing a standard display controller so it can be assumed the variable VBLANK timing will be interpreted correctly. That, and allowing an accelerated read-in and read-out due to that big bank of RAM on-board (for increased memory bandwidth rather than storage space).
  5. Guest-16
    Guest-16 Guest
    The problem with IPS is that by nature it's response rate is very slow and overclocking it can produce improper images. If it was so good big companies would have jumped on it ages ago.
  6. Gradius
    Gradius IT Consultant
    3 Feb 2009
    For sure PG278Q will be below $500.
Tags: Add Tags
