Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th Jan 2014, 11:27   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Cooler Master Elite 110 mini-ITX case is its smallest ever
Is the Elite 130 too big for you? Check out Cooler Master's smallest case yet.
http://www.bit-tech.net/news/hardwar...x-case-launc/1
Meanmotion is offline   Reply With Quote
Old 10th Jan 2014, 11:41   #2
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
What with all the really great mini-ITX cases on the market nowadays you would think the PSU manufactures would step up and make some decent SFF PSU's
At the moment AFAIK the choice of SFF PSU's is very small and its near nigh impossible to find one above 500W.
Corky42 is offline   Reply With Quote
Old 10th Jan 2014, 12:50   #3
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
That's about the biggest acceptable size for a mITX-case, but the layout of this one isn't especially well thought out imho.
Having only the fan of the PSU as an exhaust for the case isn't helping to run the components silently, especially when talking about fitting a GTX760 or something like it.
Also. Either out the front I/O ontop or in the front. What's with this I/Os in the side, where you can't reach it easily, while sitting infront of your screen. When it's sitting besides your screen the I/O is either behind the screen, or it's on the far side where you have to search for the port.
Build a mITX like a "normal" ATX tower with 15 liters and it'll only be 310mm tall, 180mm wide (which allows for bigger CPU-coolers) and some 250 deep, which even let's you fit an AIO-watercooler for the CPU and standard-sized GTX760. Even has enough room for two 3.5" HDDs or four 2.5" SSD/HDDs and a 92mm exhaust fan in addition to the standard-sized ATX-PSU. All in 14 liters.
I don't understand the urge to design these mITX-cases like cubes insted of "normal" towers. Cube-designs are only nice for smaller systems, maximum 200mm≥, but these can't fit standard dual-slot GPUs or ATX-PSUs.
The best SFX-PSU currently on the market is the Silverstone ST45SF-G, and a 450W PSU is totally enough for an intel i7 (95W) + a single GTX760/GTX770 (150-200W).
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 10th Jan 2014, 13:09   #4
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
This thing looks like a cheap and nasty speaker and would belie what could be a very nice system inside. If I want a compact Mini-ITX system there are far better cases that not only look nicer but they perform better while often being even more compact (albeit without a standard PSU).
__________________
SchizoFrog is offline   Reply With Quote
Old 10th Jan 2014, 13:20   #5
Corky42
So that leaves you with around 150W for everything else in the system, while that's within range of the maximum you would expect the rest of the system to draw it doesn't leave a lot of head room.
Old 10th Jan 2014, 13:31   #6
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
The problem is that it relies on a short graphics card like the GTX 760/670 DirectCU Mini. There's absolutely no guarantee anyone can make next gen the same length. Currently can't make Radeon series that length...
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 10th Jan 2014, 13:36   #7
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
How much headroom do you need? Our test systems with mid-range graphics cards such as the GTX 760 use around 250W in games, probably around 300-400W if you fully load the CPU and graphics card at the same time, which isn't going to happen in a majority of people's PCs unless they're running synthetic benchmarks or are mining bitcoins. But this it with fans, had disks and SSDs running too - we note the total system power draw, so really, 450W is plenty of headroom unless you're going for £500 graphics cards, especially as hardware is generally getting more power efficient.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 10th Jan 2014, 14:23   #8
jrs77
theorycrafting
jrs77's Avatar
This is the way I approach it. I add up the maximum powerdraw of the CPU + GPU and add some 100 Watts for the rest (motherboard, 2-3 HDDs, optical drive and some 2-4 120mm fans). And as you usually don't run a system at 100% for more than a couple minutes, if at all, this should be suffcient enough.
To this day I've never owned a PSU with more than 500 Watts actually.
__________________
Old 10th Jan 2014, 15:14   #9
Corky42
OK i over estimated the need for more than 450W in a SFF system , but i still think the range of SFF PSU's are rather limited compared to the amount of SFF cases. Its either go with a full ATX PSU, or a SFF one from the only two company's that seem to make them.
Old 10th Jan 2014, 17:57   #10
MrJay
You are always where you want to be
MrJay's Avatar
MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.
I was running an AMD ITX system for years on a 400w PSU
Athlon II 640 CPU (95w)
ASUS ITX board (880 chipset based)
HD 6850 (150w)
Blu-Ray drive
2 x 3.5" drives
1 x SSD
1 x 140mm fan
2 x 120mm fans (inc cooler)
Lovely case though! Iid snap that up if I had the money for an ITX build.
__________________
Main Phanteks Enthoo ITX Windowed - Pentium G3258 @ 4.5GHz - 8GB Samsung DDR3 @ 1600 MHz - Sandisk Ultra 240GB - EVGA 760 SC 2GB - Asrock Z97M-ITX/ac - Windows 10
HTPC Intel NUC (Celeron 847) - 30GB Samsung mSATA SSD - 2GB Crucial RAM 1333MHz - Windows 10
MrJay is offline   Reply With Quote
Old 11th Jan 2014, 16:59   #11
DBA
I do my modding with a spoon
DBA's Avatar
DBA has yet to learn the way of the Dremel
Why exactly CoolerMaster won't produce an SFX PSU is beyond my guess. You would have thought that now with Steam Machines well on their way and thus a small push for smaller gaming PCs, more manufacturers would have shown some love for the SFX PSU.
DBA is offline   Reply With Quote
Old 11th Jan 2014, 17:25   #12
jrs77
theorycrafting
jrs77's Avatar
Problem with SFX-PSUs is the noise-level - atleast with the ones I've tested so far.
Ive had a 180W Chieftec, the 300 and the 450W from Silverstone and a 350W from bequiet. They're all good at delivering power, but the 80x10 or 80x15mm fans are very noisy, even when the PC is idling.
Changing the fans does help alot, but it can't be done without soldering the 2-pin connectors to the new fans and you'll loose warranty ofc.
__________________
Old 11th Jan 2014, 18:55   #13
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.
My 110 case shipped Thursday for a Monday delivery. I'll see what I like about it and what we can change to fix it up.
John
__________________
Coming to a forum near you. January 2014.
jhanlon303 is offline   Reply With Quote
Old 13th Jan 2014, 01:05   #14
Star*Dagger
Banned
Star*Dagger has yet to learn the way of the Dremel
Never in a million years. And if your PSU only has 100 watts left over you are asking for serious trouble.
Star*Dagger is offline   Reply With Quote
Old 13th Jan 2014, 01:44   #15
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
No way. Any quality PSU should work up to its rated wattage otherwise it's not doing its job properly.
__________________
Old 13th Jan 2014, 09:54   #16
bawjaws
Mod Master
bawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyan
Well, that's just a load of bollocks, isn't it?
bawjaws is online now   Reply With Quote
Old 13th Jan 2014, 10:00   #17
Corky42
Maybe my thinking is outdated or just plain wrong, but i thought PSU's are most efficient when working at 50% load. I have to admit it sounded wrong when i read it but im no expert on the workings of PSU's
Old 13th Jan 2014, 11:19   #18
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
I'm starting to wonder whether these tiny ITX cases might start to benefit from rackmount style cooling, with a single fan or fan array pushing/pulling air through all the components.
Although it would be hard to make this compatible with the motley selection of enthusiast hardware we'd want to shove in there...
50-75% iirc.
I've learned to enjoy the one or two days a month that S*D chooses to grace us with is trollworthy presence.
__________________
6700K | Z170I | Liqtech 120X | EVGA GTX 980Ti SC | 16GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 14th Jan 2014, 07:13   #19
DarkFear
Supermodder
DarkFear's Avatar
DarkFear has yet to learn the way of the Dremel
I've had my eye on one of these for a while now.
I was thinking that since the case is 280mm long/deep/whatever, you should be able to fit a full size GPU in there like with the Silverstone SG05 by cutting a hole in the front of the case and having the card protrude through the hole and into the plastic front bit.
Only one way to find out I suppose...
DarkFear is offline   Reply With Quote
Old 9th Feb 2014, 12:12   #20
samuraiweasel
What's a Dremel?
samuraiweasel's Avatar
samuraiweasel - may the hammer of Bindi be bestowed on yousamuraiweasel - may the hammer of Bindi be bestowed on yousamuraiweasel - may the hammer of Bindi be bestowed on yousamuraiweasel - may the hammer of Bindi be bestowed on yousamuraiweasel - may the hammer of Bindi be bestowed on yousamuraiweasel - may the hammer of Bindi be bestowed on yousamuraiweasel - may the hammer of Bindi be bestowed on yousamuraiweasel - may the hammer of Bindi be bestowed on yousamuraiweasel - may the hammer of Bindi be bestowed on yousamuraiweasel - may the hammer of Bindi be bestowed on yousamuraiweasel - may the hammer of Bindi be bestowed on you
@jhanlon303
where did you get yours from mate? and any updates? pics?
samuraiweasel is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
