Reply
Thread Tools View Mode
Old 14th Jan 2014, 03:40   #1
lowfat
Multimodder
lowfat's Avatar
lowfat has yet to learn the way of the Dremellowfat has yet to learn the way of the Dremel
Big Lian Li. 100% Complete. FINAL PICS.
FINAL PICS
http://forums.bit-tech.net/showpost....&postcount=104
Hello. I actually started working on this case 1.5 years ago but just recently found this fine forum. So I'll do cliff notes to what I've done in the past since there are nearly 600 pics in the album.
First it started as a 2p machine.
But then I lost interest in the build for a while. Ended up picking it up again 6 months later. This time with a single socket.
Then I moved to z87 and acrylic tubing.
Then about a month ago I decided to try something different. Decided to try an inverse atx. I'm not much a modder nor do I have a garage. So besides a cordless drill ill only be using hand tools.
Test fit of the backplate.
Filing the edges for it to fit.
Frosted and painted the reservoir.
Cut and tapped the new motherboard tray.
Test fitting.
Cut the hole in the backplate.
Counter sinking the rivet holes.
Cutting holes for the cable management. Also added the screws for the cable management.
Working on the 24 pin.
I decided to repolish all my blocks.
Had to modify the Titan block in order to fit the 780Ti. Also painted the caps, connectors, and edge of the PCB black.
Painted the battery.
A frontal pic.
More cable management work.
Still have more cable management work left but i'll be using these in the near future.
lowfat is offline   Reply With Quote
Old 14th Jan 2014, 05:31   #2
craig - toyoracer
Supermodder
craig - toyoracer's Avatar
craig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysis
Great to see this build here Lowfat I remember when you started it on HWC.
__________________
octTower
Electrocutous Orchid
craig - toyoracer is offline   Reply With Quote
Old 14th Jan 2014, 08:53   #3
Hukkel
James' minion
Hukkel's Avatar
Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.
Welcome to Bit Tech Brendon. Your polished waterblock look just as amazing on this forum
Hukkel is offline   Reply With Quote
Old 14th Jan 2014, 09:51   #4
thetrashcanman
Angel headed hipsters
thetrashcanman's Avatar
thetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpitthetrashcanman is almost as Godly as yodasarmpit
Awesome build log mate, loving the work so far
__________________
is rebuilding his rig.... Asus Maximus IV Extreme/ i5 2500k @4.4Ghz/ EVGA 780 Classified/ 2 x Corsair 960Gb Neutron XT SSD / Mac Pro Tower
thetrashcanman is offline   Reply With Quote
Old 14th Jan 2014, 10:05   #5
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
"Oh, hai!" /casually throws pics of some sweet, sweet nodding on here
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is online now   Reply With Quote
Old 14th Jan 2014, 10:08   #6
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
Its rare that the stuff going on behind someones motherboard looks as awesome as they stuff going on in front of it!
__________________
NCase M1 - 5820k @4.3Ghz - H105 - GTX 980ti - ASRock X99e ITX/ac - 16GB DDR4 - 3x SSD - 600w SFX - 29" Ultrawide - Xonar U7 - Bassshaker - RAT3 - Quickfire TK - Q90s - Orbweaver - Warthog
Parge is online now   Reply With Quote
Old 14th Jan 2014, 11:59   #7
mrbungle
Undercooked chicken giver
mrbungle's Avatar
mrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyan
Dat acrylic tubing
__________________
//5930K//Gigabyte X99 SLI//16gb DDR4//Asus 480X Strix 8GB//HX1050w//
mrbungle is offline   Reply With Quote
Old 14th Jan 2014, 12:22   #8
B NEGATIVE
All Hail Kim Jong Magoo!
B NEGATIVE's Avatar
B NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming Saiyan
Welcome aboard Low...Now people will know what im talking about when I talk about your photo skills......
B NEGATIVE is offline   Reply With Quote
Old 14th Jan 2014, 14:49   #9
saxovtsmike
Multimodder
saxovtsmike has yet to learn the way of the Dremel
Welcome aboard.. I still think you polished EK blocks are one of the best looking Waterblocks avaliable.
saxovtsmike is offline   Reply With Quote
Old 14th Jan 2014, 16:59   #10
mansueto
Too broke to mod
mansueto's Avatar
mansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyan
Very nice and tidy. I love the sleeved tubing also!
__________________
Black Momba: i5 2500k @ 4.5ghz | Corsair H80 | MSI P67A-G43 | 16GB DDR3 1600 Ripjaws | 128GB Corsair M4, 1TB Barricuda | Gigabyte R9 380X | Asus PA248 IPS + Acer P243w | Asus Xonar D1 + Fio E07K Andes | Windows 7 Ultimate x64 | Seasonic X760 | Fractal R3 | Corsair Vengeance K70 w/ Browns | Razor Deathadder Chroma
Lenovo U410: i7 3517u | 8GB ram | 24GB + 750GB HDD | 14 inch ultrabook
mansueto is offline   Reply With Quote
Old 15th Jan 2014, 03:13   #11
hero1
Multimodder
hero1's Avatar
hero1 - it's over 9000!!!!!!!!1!1!1!!!hero1 - it's over 9000!!!!!!!!1!1!1!!!hero1 - it's over 9000!!!!!!!!1!1!1!!!hero1 - it's over 9000!!!!!!!!1!1!1!!!hero1 - it's over 9000!!!!!!!!1!1!1!!!hero1 - it's over 9000!!!!!!!!1!1!1!!!hero1 - it's over 9000!!!!!!!!1!1!1!!!hero1 - it's over 9000!!!!!!!!1!1!1!!!hero1 - it's over 9000!!!!!!!!1!1!1!!!hero1 - it's over 9000!!!!!!!!1!1!1!!!hero1 - it's over 9000!!!!!!!!1!1!1!!!
Welcome Lowfat. Good to see you here.
hero1 is offline   Reply With Quote
Old 25th Jan 2014, 15:58   #12
lowfat
Multimodder
lowfat's Avatar
Thanks Y'all!
Got back from vacation yesterday. So I worked on the GPU cables.
Unfortunately the sun was down so the pics aren't very good.
Old 25th Jan 2014, 17:18   #13
Marquee
Mac Pro Modder
Marquee's Avatar
Marquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming Saiyan
welcome to the forums, and great job on the tubing I love it.
Marquee is offline   Reply With Quote
Old 28th Jan 2014, 01:14   #14
lowfat
Multimodder
lowfat's Avatar
Thanks.
A few more WIP pics
Holy sausage fingers batman
These fans have a hard reflective sticker. Rather impressed, except they aren't black.
My new radiators fans. Supposedly these Phanteks are top dog for quieter high pressure 140mm fans.
Monsoon silver bullets, came with a reservoir I bought. Pretty nifty but I won't be using them.
Sheet of aluminum w/ plastic wrapping in place.
Weird angle shot of the backside of the mainboard tray.
Have the SSD and fan controller mounted in place. This is just a temporary SSD so I can get the cables made. I have a 480GB Mushkin Chronos Deluxe on the way.
Old 28th Jan 2014, 09:27   #15
Nexxo
Whatever's Geek.
Nexxo's Avatar
They are. Comparative testing on some modding site found them to be the most powerful for the noise produced. I've got two for my project, and doing a test run with a bench power supply showed them to be insanely powerful and practically inaudible.
__________________
Old 28th Jan 2014, 14:20   #16
Cookie Monster
Your cookies belong to me!
Cookie Monster's Avatar
Cookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming SaiyanCookie Monster is a Super Spamming Saiyan
Your cable management gets me wet!
__________________
Big Bird - Arc Midi | 790fx-GD70 | 955BE | 8Gb RAM | 2 x HD4890 | 120Gb SSD | 3.5Tb HDD's | 3 x Dell U2412M
Cookie Monster is offline   Reply With Quote
Old 28th Jan 2014, 18:12   #17
hero1
Multimodder
hero1's Avatar
I have to say that I credit this man for helping me throughout my water cooling journey (other people from HWC also helped me a lot). This is one classy guy and I am glad to know him (even though I don't know him in person). Keep up the good work lowfat.
Old 29th Jan 2014, 11:49   #18
montymole
Rigid Tubist
montymole's Avatar
montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.
look really neat and clean
__________________
Red Candy http://bit.ly/1uKlFtG
Silver Ghost http://bit.ly/1xQTjnq
FB http://bit.ly/MyModdingPage
Hex Gear R40 Black Ice http://bit.ly/1xO6eDJ
montymole is offline   Reply With Quote
Old 30th Jan 2014, 07:07   #19
lowfat
Multimodder
lowfat's Avatar
Uh thanks.
It was no problem. You have gone a long way in such a short time.
Thanks.
@Nexxo, thanks for you opinion on the fans. They do feel like sturdy fans. I've powered them up and they sound good. I just haven't tried them on a radiator yet.
Continuing working on the cable management. So very close to completing the PSU.
Just need to crimp on some new connectors for the fan controller and SSD.
Got a couple of new toys for the rig today. First was Topre Realforce 87U. I've been wanting one of these bad boys for about 5 years. Finally thought it was time to try one out. I am definitely say I am very much impressed. I definitely will be retiring my Filco w/ cherry blues for this.
Next was a 480GB Mushkin Chronos Deluxe. One of the cheapest 480GB drives I could find that used toggle NAND. Didn't know it had a nice brushed aluminum case. Pulled the label off 30 seconds after opening it. Looks so good naked.
Old 30th Jan 2014, 18:40   #20
hero1
Multimodder
hero1's Avatar
That SSD does look great naked. What the brand on that fan controller?
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
