Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 15th Jan 2014, 13:10   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Wireless power 'superlens' extends range significantly
A team from Duke University has created a device for greatly extending wireless power range.
http://www.bit-tech.net/news/bits/20...s-range-sign/1
Meanmotion is offline   Reply With Quote
Old 15th Jan 2014, 22:07   #2
hyperion
Hypermodder
hyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyan
This is really interesting because if this technology was implemented everywhere then gadgets would simply operate like they were permanently plugged in and batteries would be like auxiliary units that would only come into use when in nature. If it's powerful enough maybe they could lay the technology down on the streets and electric city cars could operate without the current autonomy limitations of fuel cells/batteries, and even lose the weight of those batteries entirely.
Does it have any effect on animals, like frying your brain or anything?
hyperion is offline   Reply With Quote
Old 16th Jan 2014, 06:51   #3
desertstalker
Multimodder
desertstalker has yet to learn the way of the Dremel
At the power intensity needed to do more than slowly charge a phone, probably.
desertstalker is offline   Reply With Quote
Old 16th Jan 2014, 08:19   #4
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
Not sure where people get this idea, wireless power doesn't send electrical current through the air. Maybe they should have called it electromagnetic power as that is what most wireless power uses, an electromagnetic field cause the coil in the receiving device to generate voltage.
At worst you may find your keys or other metallic things sticking to the charging unit.
Corky42 is offline   Reply With Quote
Old 16th Jan 2014, 08:29   #5
crudbreeder
Minimodder
crudbreeder has yet to learn the way of the Dremel
But the electromagnetic field is what fries your brain, just like a microwave oven.
crudbreeder is offline   Reply With Quote
Old 16th Jan 2014, 08:39   #6
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming Saiyan
electromagnetic field is just a magnetic field produced by a few electrons moving through a wire, it is no different than a magnetic field produced by a magnet other than it moves. a much larger magnetic field is produced by the earths metal core.
as for the microwave, that works by radiation which vibrates water molecules to heat things. this radiation is produced by a magnetron
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 16th Jan 2014, 08:46   #7
Corky42
You don't get you brain fried when you go in a MRI and that uses a much more powerful magnetic field, you seem to be confusing magnetic fields with radio waves.
Old 16th Jan 2014, 09:51   #8
ModSquid
Supermodder
ModSquid's Avatar
ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.
But can you catch it from toilet seats?
ModSquid is offline   Reply With Quote
Old 17th Jan 2014, 20:59   #9
Alecto
Multimodder
Alecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the Dremel
Exclusively.
Alecto is offline   Reply With Quote
Old 18th Jan 2014, 09:52   #10
Bonedoctor
Have you turned it off & on again?
Bonedoctor has yet to learn the way of the Dremel
No, but it does heat things up, especially any metal implants
Bonedoctor is offline   Reply With Quote
Old 18th Jan 2014, 10:03   #11
Corky42
Like i said a MRI is much more powerful, around 5,000 to 30,000 gauss.
If we get to the stage of needing LN2 to cool the electromagnets in an inductive charging loop we will have more to worry about than heating up metal implants.
Old 19th Jan 2014, 18:14   #12
siliconfanatic
Johny-come-Lately
siliconfanatic's Avatar
siliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyan
Such as batteries exploding like a miniature nuke from being overcharged by unheard of proportions?
__________________
Do not let anything good in life pass you by. Cherish it with all of your heart, because before you know it even life will have passed you by. And if you let all those things pass you by? The only thing filling your heart will be deep sadness and regret. So whatever you do, hold on, and never let go.
siliconfanatic is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
