Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 22nd Jan 2014, 10:39   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Starbound Early Access Review
We take a look at the beta of this vast, space exploration game.
http://www.bit-tech.net/gaming/pc/20...ccess-review/1
Meanmotion is offline   Reply With Quote
Old 22nd Jan 2014, 11:21   #2
loftie
Mod Master
loftie's Avatar
loftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyan
But any planet that doesn't consist entirely of fart is viable for a bit of interstellar prospecting.
__________________
Sent from my PC using a keyboard
loftie is offline   Reply With Quote
Old 22nd Jan 2014, 11:24   #3
Shirty
Time travelling rogue
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
Gotta love Rick's prose.
I have been described as a gas giant in the past
__________________
6700K | Z170I | Liqtech 120X | EVGA GTX 980Ti SC | 16GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 22nd Jan 2014, 11:25   #4
Draksis
Code Monkey
Draksis's Avatar
Draksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for presidentDraksis should be considered for president
FYI for anyone who going to run off now and buy the game: The Development team is currently in the final stages of a huge patch that will push a full (and final) character/universe wipe. The date for this patch is this weekend, so it's not too long - but still very disheartening if you don't know it's coming and you get really involved in the game this week.
EDIT:
Now that I've read through the entire article, a few points to share:
1.) The matter manipulator is useless and is normally used to collect just enough resources to make a stone pickaxe and axe. After that you use those tools to mine and collect wood. The matter manipulator can then (this might change in future versions) be left in some storage box and forgotten about.
2.) Your spaceship uses varying amounts of fuel, depending on how far you travel. Off the top of my head: 5 fuel between very close planets (planet/moon clusters), 50 fuel to neighboring planet clusters within the same solar system, and 200 fuel for between solar systems.
That, coupled with the fact that 10 unrefined wood (the wood directly from trees) can be changed into 1 coal unit, the "fuel crisis" is not as major as suggested in the article.
3.) All resources are fairly rare on the starting level planets (Alpha sector), but increase nearly exponentially after the first boss.
/2cents
__________________
Originally Posted by liratheal View Post
Terrible, wrapped in a blanket of awful, with a dollop of useless.
Draksis is offline   Reply With Quote
Old 22nd Jan 2014, 12:37   #5
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
As mentioned by Draksis, you can transform 10 "unrefined wood" into 1 coal with your furnace. Then the only thing you need is a tree farm. Like in Terraria, each tree will gives you a tree seed when you cut it down. Since trees grow pretty fast, coal in not a problem anymore.
One important thing, not mentioned in the review, is that you can die from starving or losing to much body heat. So you have to eat (and then farm vegies, fruits, cereals or hunt some meat with a knife or a bow). A fire can reheat you, but you'll need special armors for snowy planets. As well, you'll die quickly on atmospherless planets (moon and asteroid fields) and you'll have to wear a special backpack on those planets.
GuilleAcoustic is offline   Reply With Quote
Old 22nd Jan 2014, 13:41   #6
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
Whether Starbound can continue to surprise and delight in this way after thirty to fifty hours of play is another question entirely
12 for thirty to fifty hours of gameplay is a bargain, in my opinion, so an open-ended game that goes beyond that is great news.
I'm content to wait for the finished game, but this is definitely going on my play list.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170|32GB|256GB M.2|500GB SSDs|8TB NAS|980 Ti|3007WFP-HC|Parvum S2.0
David is online now   Reply With Quote
Old 22nd Jan 2014, 13:46   #7
GuilleAcoustic
Ook ? Ook !
... and do not forget that this game is opened to modders. I'm sure that incredible mods will be available quite rapidly
Old 22nd Jan 2014, 14:41   #8
itrush07
Multimodder
itrush07 has yet to learn the way of the Dremel
Can't wait to try this one also.. looks very interesting to play with.
__________________
IT Rush <my blog
itrush07 is offline   Reply With Quote
Old 22nd Jan 2014, 15:51   #9
exceededgoku
Multimodder
exceededgoku has yet to learn the way of the Dremel
I scoffed when you mentioned tutorial planet and having to gather resources, until I realised that I've been on the tutorial planet for the better part of 8 hours. I have a life on this planet now... I can't get up and leave!
exceededgoku is offline   Reply With Quote
Old 22nd Jan 2014, 17:41   #10
GuilleAcoustic
Ook ? Ook !
I'm exploring Delta sector, but my base is still on the first planet I saw .
Old 22nd Jan 2014, 18:03   #11
MrJay
You are always where you want to be
MrJay's Avatar
MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.
Buy it on humble (through the official site) for $15 works out at just over 9 : )
I've put about 20 hours into it so far, going to put it on the back-burner until it's a little more refined. Looking good so far though!
__________________
Main Phanteks Enthoo ITX Windowed - Pentium G3258 @ 4.5GHz - 8GB Samsung DDR3 @ 1600 MHz - Sandisk Ultra 240GB - EVGA 760 SC 2GB - Asrock Z97M-ITX/ac - Windows 10
HTPC Intel NUC (Celeron 847) - 30GB Samsung mSATA SSD - 2GB Crucial RAM 1333MHz - Windows 10
MrJay is offline   Reply With Quote
Old 22nd Jan 2014, 20:17   #12
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
Anyone ever played The Blockheads on Android and iOS? Yeah. Pretty much. BUT WITH SPACE!
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 23rd Jan 2014, 01:06   #13
abezors
Lurking since '08
abezors's Avatar
abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.
I only explored 4 planets during my time with Starbound - but I can safely say it is worth the money. There is indeed a little too much focus on crafting vs exploration; but the latter is rewarding in itself (and often provides many materials and ores).
Breaking through the surface into a labyrinthine cave complex armed with little more than a flashlight and a pickaxe is one of the many "just another 10 minutes more then I'll go topside" moments. One cave system I still remember took over 2 hours to fully explore and mine (whilst trapping killing or avoiding the high level creatures hidden in the darkness).
Soundtrack is great. Art style is great. You can play the game at whatever suits you.
abezors is offline   Reply With Quote
Old 23rd Jan 2014, 06:54   #14
Draksis
Code Monkey
Draksis's Avatar
The Chucklefish Devs have said that they will be balancing that aspect out when the time comes. Not only with more random chests/stuff in chests but also to include many of the unusual items people need to craft the "Boss callers" (like the superior brain) in containers and chests
__________________
Old 23rd Jan 2014, 07:46   #15
Stiltonpie
What's a Dremel?
Stiltonpie has yet to learn the way of the Dremel
I have nearly 200 hrs on this game and exploring the X Sector. Looking forward to the next patch and all the new content.......it's been a while since I have given so much time to a game, even though it's still in beta. Love it
Stiltonpie is offline   Reply With Quote
Old 12th Feb 2014, 17:10   #16
r3Q
Supermodder
r3Q's Avatar
r3Q has yet to learn the way of the Dremel
yeah, ive got well over 100 hours into this game. lost 3 characters on the wipes of the past.
the game is stable enough to invest time in now that the latest patch has allowed them to keep characters in subsuquent patches. hopefully no more universe\character wipes in the future.
the mods are incredible, and the developers are really attached to the comminuty - even adding really good ideas and mods to the game.
check out /r/starbound if you want to get close to the devs or start modding. the public chat on steam is another good way to find people who want to play or have servers running. playing in multiplayer is where the fun starts. specifically if you have a good friend to skype with while you both start the game for the first time.
just be warned. you better have an entire day to waste. you wont know what happened lol!
__________________
-r3Q
r3Q is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
