Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 24th Jan 2014, 11:53   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Intel and Berkeley announce nano-cooling breakthrough
Carbon nanotubes to cool future chips.
http://www.bit-tech.net/news/hardwar...ey-nanotubes/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 24th Jan 2014, 12:03   #2
Shirty
Time travelling rogue
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
Cool!
__________________
6700K | Z170I | Liqtech 120X | EVGA GTX 980Ti SC | 16GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 24th Jan 2014, 12:10   #3
murraynt
I Mod, Therefore I Own
murraynt's Avatar
murraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for president
Originally Posted by Shirty View Post
Cool!
I see what you did there
__________________
l I5 4690k l MSI Z78I l 8GB corsair 1600mhz l Asus 5870 v2 l Fractal Node 304 l 60GB Crucial M4 l F3 1TB Spinner l 700Watt Thermaltake l Samsung IPS231 l
Steam: murraynt
murraynt is offline   Reply With Quote
Old 24th Jan 2014, 12:14   #4
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Assuming that this will eventually be used to connect the processor to the heat spreader plate, we still need to develop methods for better transfer between the heat spreader and the actual cooler. Otherwise I can only see this being used in sealed units that won't be upgradeable or replaceable.
__________________
SchizoFrog is offline   Reply With Quote
Old 24th Jan 2014, 12:37   #5
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
What a waste of good carbon nanotubes
I want my space elevator and I want it NOW!
Guinevere is offline   Reply With Quote
Old 24th Jan 2014, 12:53   #6
Shirty
Moderator
Shirty's Avatar
It was a toss up between that and:
WOW
MUCH NANO
AMAZE
VERY MOLUECULE
SO COOLING
MANY THERMALS
WOW
But I like to think I took the high road and avoided the overused meme, preferring simple wordplay.
__________________
Old 24th Jan 2014, 13:23   #7
MjFrosty
Hypermodder
MjFrosty's Avatar
MjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on you
Cool!
This. Basically!
__________________
Fast
MjFrosty is offline   Reply With Quote
Old 24th Jan 2014, 13:45   #8
Umbra
Hypermodder
Umbra's Avatar
Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.
As the thermal conductivity of carbon nanotubes exceeds that of diamond or any other natural material it would seem that the continued use of carbon nanotubes to connect the heat spreader to the cooler would be the ideal solution but the distances between processor and heat spreader are probably much smaller than the distances between heat spreader and cooler and I'm not sure if it's possible or financially viable to use carbon nanotubes for that purpose.
If carbon nanotubes could be used between heat spreader and cooler and were super efficient but could only be made using a sealed unit it wouldn't really matter, all though it would be very annoying for us modders who often find it hard to believe that a company spending 000,000's on development can make something better than we can in a shed with after market h/sinks and fans
Nanotubes aside, "Molecular Foundry" what a great phrase, I really need a Skyrim mod for a Molecular Foundry maybe the next great incarnation of The Elder Scrolls will have the option for nano technology, I can here the Skyrim Lore perfectionists sharpening their weapons already
Umbra is offline   Reply With Quote
Old 24th Jan 2014, 17:26   #9
edzieba
Virtual Realist
edzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyan
The big question: how much does the process cost? Intel already switched from solder bonded IHS to a past TIM because it was fractionally cheaper (even though lower performing at higher voltages), so why would they switch to this, even if it performed significantly better, if it cost more?
edzieba is offline   Reply With Quote
Old 24th Jan 2014, 22:21   #10
NIHILO
The Customer isn't always right!
NIHILO's Avatar
NIHILO is a Super Spamming SaiyanNIHILO is a Super Spamming SaiyanNIHILO is a Super Spamming SaiyanNIHILO is a Super Spamming SaiyanNIHILO is a Super Spamming SaiyanNIHILO is a Super Spamming SaiyanNIHILO is a Super Spamming SaiyanNIHILO is a Super Spamming SaiyanNIHILO is a Super Spamming SaiyanNIHILO is a Super Spamming SaiyanNIHILO is a Super Spamming Saiyan
Such Polite.
Much courtesy.
Wow.
__________________
The snake is notoriously tempting, but the snake is fair.
What is worse than not knowing? To live or disappear?
NIHILO is offline   Reply With Quote
Old 25th Jan 2014, 22:13   #11
Glix
Left Thumb Stick in the mud.
Glix has yet to learn the way of the Dremel
Me too, but so long as it doesn't lead to fiery death.
Glix is offline   Reply With Quote
Reply
Tags
berkeley, carbon nanotubes, chemistry, chip, cooling, heatsink, intel, microchip, microprocessor, physics, research, semiconductor
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
