Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 30th Jan 2014, 19:47   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Battlefield 4 Mantle update released, AMD drivers missing
The much anticipated Mantle update to BF4 has arrived but there's no AMD driver to support it.
http://www.bit-tech.net/news/hardwar...eased-amd-dr/1
Meanmotion is offline   Reply With Quote
Old 30th Jan 2014, 20:20   #2
Instagib
Ultramodder
Instagib's Avatar
Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.
"Got there timing a bit off" - their.
The Beta drivers only support Mantle on R9 290s and 290Xs though. The rest of us on 280Xs or 7970s will have to wait.
Also, have they fixed the game yet?
__________________
Silverstone FT04B | Maximus V Extreme | i7 - 3770K @4.6 | 16Gb Corsair Vengeance LP DDR3 1600Mhz | H80i | ASUS GTX 780Ti DCII |Seasonic 660XP2
Silverstone TJ07|Rampage 3 Extreme | X5650 @ 4.2 | 12Gb Corsair DDR3 1600mhz | EVGA GTX680 | Akasa 1000W Powermax | 480 rad; all under water
Instagib is offline   Reply With Quote
Old 30th Jan 2014, 21:06   #3
SAimNE
Multimodder
SAimNE has yet to learn the way of the Dremel
270x and the apus are also all mantle compatible if i remember right.
SAimNE is offline   Reply With Quote
Old 30th Jan 2014, 21:17   #4
Assassin8or
Multimodder
Assassin8or has yet to learn the way of the Dremel
The delay is to get full GCN coverage in the Mantle driver rather than releasing with just GCN1.1 support. That means HD7xx0, R9 280X, R7 270(X) and HD8xx0 support released too.
Edit: in the end it looks like an installer issue caused a delay
Assassin8or is offline   Reply With Quote
Old 31st Jan 2014, 11:41   #5
Corky42
I Mod, Therefore I Own
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
It seems the driver maybe delayed until this weekend.
http://www.guru3d.com/news_story/upd...r_release.html
During the QA process, we identified an installation issue in AMD Catalyst 14.1 that renders it unsuitable for distribution for testing in your labs. We are testing a new build overnight and will update you on its status by mid-afternoon Eastern Standard Time on January 31. We apologize for the delay and appreciate your patience and understanding.
This is the press-driver as we have just learned, AMD promised the media at least 24 hours with the driver prior to release to do some internal testing. We do hope it'll be out fairly soon. But at this stage, nothing is certain whatsoever.
http://wccftech.com/amd-confirms-man...-gpus-support/
The Mantle Catalyst driver 14.2 BETA will initially feature support for only four GPUs at launch which include the Radeon R9 290X, Radeon R9 290, Radeon R7 260X and the Radeon R7 200 series integrated Kaveri APUs.
Corky42 is offline   Reply With Quote
Old 31st Jan 2014, 18:04   #6
Pookie
Level 0
Pookie's Avatar
Pookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming Saiyan
Hopefully this will help go towards fixing all the issues with 290 series cards and not just implement mantle.
__________________
Unlimited Fibre Broadband 38Inc Per month including line Rental!
http://pulse8broadband.co.uk/fibreoptic-broadband
Pookie is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
