Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 5th Feb 2014, 10:27   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Asus announces Haswell-based Chromeboxes
Can it succeed where Samsung failed?
http://www.bit-tech.net/news/hardwar...us-chromebox/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 5th Feb 2014, 10:48   #2
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
Might be tempted with a cheap one and see about installing a slim copy of windows on it for a media pc.
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 5th Feb 2014, 11:12   #3
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
Windows ? For media PC ? Why ? It would make much more sense to put something like OpenELEC on it - you would fit easily (it uses ~2GB of the dirve), it is a fast booting XBMC install...
faugusztin is offline   Reply With Quote
Old 5th Feb 2014, 11:31   #4
damien c
Mad FPS Gamer
True would have to have a look at that stuff.
__________________
Old 5th Feb 2014, 11:40   #5
Fruitloaf
Tinkerer
Fruitloaf's Avatar
Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!
Honestly I can't see this having any better performance than a Raspberry Pi as a media centre - Celeron processor + 2GB ram doesn't exactly have the grunt to do much more than a Pi could.
Fruitloaf is offline   Reply With Quote
Old 5th Feb 2014, 11:56   #6
faugusztin
I think you are completely mistaken by the "Celeron" name. It is a low clocked Haswell CPU with a cut down Haswell IGP, which is still more than enough for any media centre tasks. And Pi is completely out of picture, compared to the performance of this CPU and GPU.
Take a look - http://www.cpubenchmark.net/mid_range_cpus.html - it is between AMD A4-3300 APU and AMD A4-3400 APU in CPU performance, and even if it is has only half of the Haswell GPU, it is still more than enough for HTPC stuff.
And 2GB RAM... Have you seen actual memory usage of a linux with XBMC on it ? Good luck finding cases when it uses more than half gigabyte of RAM.
Old 5th Feb 2014, 12:01   #7
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming Saiyan
Pedant time "4GB of DDR3 memory adn a choice of "
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 5th Feb 2014, 12:03   #8
Fruitloaf
Tinkerer
Fruitloaf's Avatar
Oh I'm sure its up to the task I just don't know what it could do that a Pi couldn't as a HTPC? You aren't going to game on it so its really just media playback and the Pi can do 1080p fine in my experience.
When I compare my (admittedly aging) Nvidia Ion HTPC and my Pi HTPC both running openelec the interface is slightly faster on the Ion but by no means unacceptable on either. Comparing both the only reason I keep the Ion is because it has a DVD drive for those occasions that I might want to play an actual disk.
Old 5th Feb 2014, 12:03   #9
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
Don't under estimate Celerons. They're extremely capable little processors.
If you want to see what a Sandy Celeron can do then by all means have a skim over this review I wrote a while back -
http://www.fruitforums.com/vb/showth...t=celeron+g530
Note I swear a lot, but the figures don't lie. Paired with a GPU they can actually game with the big boys.
AlienwareAndy is offline   Reply With Quote
Old 5th Feb 2014, 12:09   #10
Gareth Halfacree
WIIGII!
bit-tech Staff
Still getting used to this new keyboard - fixed, ta!
__________________
Old 5th Feb 2014, 12:09   #11
Fruitloaf
Tinkerer
Fruitloaf's Avatar
This machine though doesn't have the option of a dedicated GPU so as a HTPC (and only as a HTPC) I don't see what it does that a pi doesn't. As a web browser sure its plenty fast enough and assuming this is around the £130 mark its not a terrible price for that. The faster models seem pointless unless you stick Windows on it which would require a bigger SSD which are hard to find in that form factor just now.
Old 5th Feb 2014, 12:16   #12
GeorgeStorm
Aggressive PC Builder
GeorgeStorm's Avatar
GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.
I thought the pi struggles with large libraries/high bitrate files?
__________________
"Anyone who just plays games for fun is a n3rd" - Jörge "I should be in prison for what I'm thinking right now" - Will
My Parvum Systems build log - My flickr - My blog it'sfilmnotmovie - hwbot
I identify as mayonnaise-kin, think of it as white without the privilege.
GeorgeStorm is offline   Reply With Quote
Old 5th Feb 2014, 12:21   #13
Fruitloaf
Tinkerer
Fruitloaf's Avatar
I have 300+ movies, 3000+ TV episodes and 257 albums so not a tiny collection and it works fine. Normally I play 720p files but I do sometimes play 1080p which also have always played well for me.
If you had a mostly 1080p collection I'd probably consider something else - I'm not sure how good this chromebook with its cut down GPU would be though - but otherwise a Pi is more than good enough.
Old 5th Feb 2014, 12:50   #14
GeorgeStorm
Fair enough, I don't personally have one but I thought I remembered hearing it did have issues, maybe now that some of the software used has matured a bit it's got better.
__________________
Old 5th Feb 2014, 15:26   #15
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
Can't be done, can't access the BIOS. Goog locks it off for ALL Chrome-machines.
I'm sorry but this is pure crap. Haswell Celeron obliterates a Broadcom ARMv6, even if they were running at the same clock speed.
ARMv6 (ARM11) does ~0.9 DIPS/MHz
ARMv8 (Cortex A9) does 2.5 DIPS/MHz
OLD Atom core (in-order) does 2.5 DIPS/MHz
Haswell Celeron is not even mobile - it's a full fat Core core.
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 5th Feb 2014, 15:32   #16
Fruitloaf
Tinkerer
Fruitloaf's Avatar
Tell that to my chromebook running Ubuntu.
Old 5th Feb 2014, 15:35   #17
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
How'd you get access? They 'should' be locked :P
__________________
Old 5th Feb 2014, 15:39   #18
Phil Rhodes
Hypernobber
Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.
Looked at Chromebook for the maternal unit a while - say nine months - ago. Seemed completely unusable. No local storage? Er, okay.
Phil Rhodes is offline   Reply With Quote
Old 5th Feb 2014, 15:59   #19
Fruitloaf
Tinkerer
Fruitloaf's Avatar
All of them as far as I'm aware can be put into developer mode where they can then be booted from usb or SD card. Certainly all the chromebooks that I know of can be and I assume this chromebox will be the same.
Old 5th Feb 2014, 16:02   #20
Fruitloaf
Tinkerer
Fruitloaf's Avatar
They do have some local storage, usually 16GB ssd but some have spinning rust. I tend to think of them more as tablets with keyboards rather than traditional computers and in that regard so long as you have internet access they can do a lot.
For some people they may well be enough to replace a laptop but for others maybe not. Local storage is overrated imho - a server or cloud storage is usually superior.
Reply
Tags
chrome, chrome os, chromebook, chromebox, google, haswell, intel, linux, sff, small form factor
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
