Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th Feb 2014, 11:38   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
HP moves BIOS upgrades behind warranty wall
No more free fixes for older gear.
http://www.bit-tech.net/news/bits/2014/02/10/hp-bios/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 10th Feb 2014, 12:48   #2
edzieba
Virtual Realist
edzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyan
customers with machines suffering from known firmware issues but whose initial warranty has expired will be locked out from receiving a fix unless and until they purchase a valid warranty pack.
Hoooo boy, that's a lawsuit waiting to happen!
edzieba is offline   Reply With Quote
Old 10th Feb 2014, 13:00   #3
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
Most people wont even relise its the bios thats the fault. ( 99% of buyers of hp products wont relise its a bios fault)
rollo is offline   Reply With Quote
Old 10th Feb 2014, 13:13   #4
Bungletron
Ultramodder
Bungletron's Avatar
Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.
Dastardly manoeuvre to try and increase revenues, I bet those idiotic HP execs must be rubbing their hands with glee. This type of innovation deserves to sink any company implementing without trace, not that that will happen!
As a microserver owner here's hoping it massively backfires in their faces. Similar to other forum members, since the only support I require is the firmware downloads (never contact their support etc) I do not see the value nor buy their stupid after care packages.
For someone in my position whether they charge for this service or it leads to scaling down or termination (unlikely I know) of the department makes no difference; I won't be able to get any new firmware anyway!
__________________
Main rig: i7 2600K + Corsair H75 | P8Z77-M Pro | 8GB DDR3 | MSI GTX 970 4G + NXZT G10 + Corsair H75 | Xonar DX | 840 EVO + 850 EVO RAID0 1TB stripe | F4 2TB | NXZT Hale 650W | Carbide 240 Air | U2713HM
HTPC: A10 5800K | GA-F2A75M | 8GB DDR3 | EVGA GTX 950 SuperClock+ | Be Quiet! TopFlow | M4 512GB | F4 2TB | Lian Li PC-V355B
Server: Xeon E3-1240L v3 | ASRock E3C226D2I | 16GB ECC DDR3 | Fujitsu D2616 RAID | Seagate XT 500GB | MX100 256GB | 5 x 4TB HDD (RAID 5) | SilverStone DS380
Bungletron is offline   Reply With Quote
Old 10th Feb 2014, 13:34   #5
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
Won't the firmware downloads just start appearing in other, less wholesome locations?
__________________
3770K | Z77E-ITX | Liqtech 120X | EVGA GTX 980Ti SC | 8GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 10th Feb 2014, 13:36   #6
sandys
Mod Master
sandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpit
That's just the way it is for a lot enterprise stuff particularly on the software side, annual service contracts and licensing, when you supply relatively small amounts of hardware/software this sort of approach is needed to keep the effort financially viable.
sandys is offline   Reply With Quote
Old 10th Feb 2014, 13:47   #7
MrJay
You are always where you want to be
MrJay's Avatar
MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.
Yeah id piss off the only sector that is keeping your sorry ass afloat...
Excellent strategy.
__________________
Main Phanteks Enthoo ITX Windowed - Pentium G3258 @ 4.5GHz - 8GB Samsung DDR3 @ 1600 MHz - Sandisk Ultra 240GB - EVGA 760 SC 2GB - Asrock Z97M-ITX/ac - Windows 10
HTPC Intel NUC (Celeron 847) - 30GB Samsung mSATA SSD - 2GB Crucial RAM 1333MHz - Windows 10
MrJay is offline   Reply With Quote
Old 10th Feb 2014, 14:07   #8
Votick
My CPU's hot but my core runs cold.
Votick's Avatar
Votick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming Saiyan
I think this is a good move.
Hopefully if the kit is a certian age then they won't supply warrenty.
Votick is offline   Reply With Quote
Old 10th Feb 2014, 14:09   #9
BA_13
Minimodder
BA_13 is almost as Godly as yodasarmpitBA_13 is almost as Godly as yodasarmpitBA_13 is almost as Godly as yodasarmpitBA_13 is almost as Godly as yodasarmpitBA_13 is almost as Godly as yodasarmpitBA_13 is almost as Godly as yodasarmpitBA_13 is almost as Godly as yodasarmpitBA_13 is almost as Godly as yodasarmpitBA_13 is almost as Godly as yodasarmpitBA_13 is almost as Godly as yodasarmpitBA_13 is almost as Godly as yodasarmpit
Aren't the majority of Firmware updates required on this sort of equipment issued in response to defects found in the original BIOS and not used to add additional functionality?
Regardless I shall now be looking at other micro server options when I get home, I don't think I shall be buying any more HP kit in the future (I already dislike their printers due to several bad experiences).
BA_13 is offline   Reply With Quote
Old 10th Feb 2014, 14:27   #10
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
Yep. A nice time to register a site in Russia and start hosting them. Not that I would do that for advertising revenue...
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 10th Feb 2014, 15:48   #11
Tuthmose
Multimodder
Tuthmose's Avatar
Tuthmose is the Cheesecake. Relix smiles down upon them.Tuthmose is the Cheesecake. Relix smiles down upon them.Tuthmose is the Cheesecake. Relix smiles down upon them.Tuthmose is the Cheesecake. Relix smiles down upon them.Tuthmose is the Cheesecake. Relix smiles down upon them.Tuthmose is the Cheesecake. Relix smiles down upon them.Tuthmose is the Cheesecake. Relix smiles down upon them.Tuthmose is the Cheesecake. Relix smiles down upon them.Tuthmose is the Cheesecake. Relix smiles down upon them.Tuthmose is the Cheesecake. Relix smiles down upon them.Tuthmose is the Cheesecake. Relix smiles down upon them.
" . . . We know this is a change from how we’ve done business in the past; however, this aligns with industry best practices and is the right decision for making even more money."
Fixed it for you
-Tuthmose
Tuthmose is offline   Reply With Quote
Old 10th Feb 2014, 17:31   #12
azazel1024
Supermodder
azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.
I am waiting for this to be extended to their consumer line.
Oh, and drivers. Just waiting on drivers also to be stuck behind a warranty pay wall (unless of course that is what they mean about firmware).
HP Drivers and BIOS updates appearing on pirate sites in 3...2...1...
__________________
Core 2 Duo E7500, MSI P43-C51, 2x2GB G.Skill Eco DDR3 1600 Cas 7, OCZ Vertex 60GB, Vertex 30GB, Samsung F3 500GB, Samsung F4 2TB, Powercolor Go Green ATI 5570
azazel1024 is offline   Reply With Quote
Old 10th Feb 2014, 17:35   #13
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
My guess is that Lenovo and Dell really like this news.
faugusztin is offline   Reply With Quote
Old 10th Feb 2014, 17:50   #14
RedFlames
...is volatile under pressure.
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
Luckily *most* components rely on standardised drivers that can be found elsewhere [GPU, chipset etc.]
Though as faug points out, Dell et al. if they have any sense could capitalise on this...
EDIT: though if for some reason this doesn't come back to bite HP... you can expect other OEMs to follow suit...
__________________
You wouldn't really die of anything, in the traditional sense. You would just stop being biology and start being physics.
RedFlames is online now   Reply With Quote
Old 10th Feb 2014, 18:15   #15
j_jay4
Supermodder
j_jay4's Avatar
j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.
*Rushes to HP website to download updates for MicroServer before 19th February deadline*
__________________
Gaming PC: ASUS PB287Q, Fractal Design ARC Mini R2, AsRock Z87e-ITX, Intel 4670K, Samsung 840 EVO 500 GB, G.Skill 8GB RipjawsX, EVGA GTX 670, Be Quiet! Dark Power Pro 750 W.
HTPC Server Samsung UE40F5000, HP ProLiant G7 N54L 2.2GHz MicroServer, 4 GB RAM, ASUS R7 240, TBS 6982, Samsung 830 256 GB, 3 TB WD Red.
j_jay4 is offline   Reply With Quote
Old 10th Feb 2014, 18:53   #16
Phil Rhodes
Hypernobber
Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.
Depends what they mean by "firmware updates," really. I've never used the equipment in question, so this is by way of a question, really: are they talking about major new features, or is it just glitch fixing?
If the former case, well, maybe fair enough. If the latter, not so much.
Phil Rhodes is offline   Reply With Quote
Old 10th Feb 2014, 18:57   #17
faugusztin
@Phil: any BIOS updates, RAID card firmware updates etc. Simply put, you won't see the download page for the product you own if it is out of warranty.
Old 10th Feb 2014, 19:04   #18
DC74
Doh!
DC74's Avatar
DC74 is a hoopy frood who really knows where their towel is.DC74 is a hoopy frood who really knows where their towel is.DC74 is a hoopy frood who really knows where their towel is.DC74 is a hoopy frood who really knows where their towel is.DC74 is a hoopy frood who really knows where their towel is.DC74 is a hoopy frood who really knows where their towel is.DC74 is a hoopy frood who really knows where their towel is.DC74 is a hoopy frood who really knows where their towel is.DC74 is a hoopy frood who really knows where their towel is.DC74 is a hoopy frood who really knows where their towel is.DC74 is a hoopy frood who really knows where their towel is.
Well that's it then HP putting a gun to their own head and pulling the trigger. That's the dumbest idea ever to screw money out of customers. I can see HP filing for bankruptcy in a couple of years, the damage to their reputation is complete.
I remember a few years ago they were caught putting a cut off switch into their printer cartridges so after a certain amount of time they just stopped working regardless if they had been used much or not. They were sued over that one and it's not like they were cheap to replace either. Since then I've steered clear of HP products. HP has now shown it's true colours, money for nothing yet again, if everyone else just stops buying their products they will learn the hard way.
DC74 is offline   Reply With Quote
Old 10th Feb 2014, 21:14   #19
Flibblebot
Smile with me
Flibblebot's Avatar
Flibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming Saiyan
But for the Microservers, don't most people already use the modified BIOS - which is freely available on other sites - anyway? Or are HP going to start issuing cease and desist notices on any site that hosts a modified BIOS file...
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse
Flibblebot is offline   Reply With Quote
Old 10th Feb 2014, 21:46   #20
Gareth Halfacree
WIIGII!
bit-tech Staff
Originally Posted by Phil Rhodes View Post
Depends what they mean by "firmware updates," really. I've never used the equipment in question, so this is by way of a question, really: are they talking about major new features, or is it just glitch fixing? If the former case, well, maybe fair enough. If the latter, not so much.
Most often the latter. For instance - and I know this, 'cos I've just bought one - the HP ProLiant MicroServer N54L has a bug in its BIOS that prevents the on-board network port from working properly on Windows Server 2012 and Windows 8.1. The updated BIOS - available only to warrantied customers, and that's right now rather than from the 19th - fixes that problem.
__________________
Reply
Tags
bios, firmware, hewlett packard, hp, mary mccoy, warranty
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
