Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 11th Feb 2014, 09:00   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Deepcool Gamer Storm Gabriel Review
Deepcool is on a roll with sub-30 coolers and the latest is a 120mm low-profile model.
http://www.bit-tech.net/hardware/coo...briel-review/1
Meanmotion is offline   Reply With Quote
Old 11th Feb 2014, 09:20   #2
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
Man, Deepcool are going on proper militant !
Great prices ask some seriously hard questions of Noctua et al. It even looks nice.
AlienwareAndy is offline   Reply With Quote
Old 11th Feb 2014, 09:36   #3
mitch311
Minimodder
mitch311's Avatar
mitch311 - it's over 9000!!!!!!!!1!1!1!!!mitch311 - it's over 9000!!!!!!!!1!1!1!!!mitch311 - it's over 9000!!!!!!!!1!1!1!!!mitch311 - it's over 9000!!!!!!!!1!1!1!!!mitch311 - it's over 9000!!!!!!!!1!1!1!!!mitch311 - it's over 9000!!!!!!!!1!1!1!!!mitch311 - it's over 9000!!!!!!!!1!1!1!!!mitch311 - it's over 9000!!!!!!!!1!1!1!!!mitch311 - it's over 9000!!!!!!!!1!1!1!!!mitch311 - it's over 9000!!!!!!!!1!1!1!!!mitch311 - it's over 9000!!!!!!!!1!1!1!!!
Are the low profile coolers ever tested for compatibility with mITX motherboards that have graphics cards installed? With many of these smaller boards siting the CPU socket close to the PCIe slot, it means that some of these coolers won't be compatible. I find that this is the most time consuming part of deciding on a heatsink for a mITX board.
Edit: Should also say that I do like the look of this and it's shorter than the cooler I have atm which I am currently looking at replacing.
mitch311 is offline   Reply With Quote
Old 11th Feb 2014, 11:35   #4
Dave Lister
Hypermodder
Dave Lister's Avatar
Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!
" the Grabriel is a good, but not quite award-worthy low-profile cooler. "
__________________
Main Rig:Case: BitFenix Prodigy, Motherboard: MSI Z97I Gaming, CPU: Intel i7 4790K, RAM: 16Gb 2400Mhz Kingston HyperX Beast GPU: MSI GTX 970 Gaming, Primary HDD: 256Gb Samsung 850 Pro, Games Drive: 4Tb Toshiba X300, Cooler: Corsair H105, OS: Win 7 - 64, VR: Oculus with touch
Dave Lister is offline   Reply With Quote
Old 11th Feb 2014, 13:42   #5
lilgoth89
Captin Calliope
lilgoth89's Avatar
lilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyan
depends on the company...
Noctua are my go-to for that at as they actually test fit the cooler on as many motherboards as they can find before it gets released, and if you find you cant fit it onto your motherboard, write them an email and ( I think ) they will refund you and update their list
__________________
I7 3770 @ 4.5Ghz | Asrock z77 extreme 6 | 16gb hyper X Ram 1600 | SfX7870 oc |Crucial 512 gb M4 | Samsung Spin point 2tb x2 | SiverStone Raven02 | Corsair Hx 850
lilgoth89 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
