Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 11th Feb 2014, 12:11   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
ARM announces mid-range Cortex-A17
Up to 60 per cent faster than the A9.
http://www.bit-tech.net/news/hardwar...m-cortex-a17/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 11th Feb 2014, 14:16   #2
azazel1024
Supermodder
azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.
I am hoping the A17 is a bit more promising than the A15.
The A15 just doesn't seem to have the performance per watt ratio that works well, at least for phones. It might be higher performance than the A17 here, but it also is a fair bit thirstier on power, even in a big.little config, which also increases chip cost because of die area.
I am wondering if/when OEMs realize that maybe "octocore" designs aren't the way to go. I'd think, especially in a phone, the best setup would be 2 A17s and a single A7 if you need a big.little configuration. I can't imagine it would be that difficult for the OS to schedule it appropriately. Chip would cost a lot less than a 4+4 design and probably be roughly as powerful for a lot of workloads.
__________________
Core 2 Duo E7500, MSI P43-C51, 2x2GB G.Skill Eco DDR3 1600 Cas 7, OCZ Vertex 60GB, Vertex 30GB, Samsung F3 500GB, Samsung F4 2TB, Powercolor Go Green ATI 5570
azazel1024 is offline   Reply With Quote
Old 11th Feb 2014, 14:26   #3
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
So, is this basically just a more power efficient A15? It seems to be pretty similar to it in most ways, except for power consumption. Also, ARM is getting to be just as bad as Intel and AMD when it comes to naming products. Their naming schemes are much simpler but still don't make much sense.
On another note, I'm a little surprised its taking so long for the A9 to go away.
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Old 11th Feb 2014, 14:31   #4
schmidtbag
Ultramodder
I agree, the the octocores aren't ideal. I thought big.LITTLE was kind of a dumb idea - it's a pain for fabrication systems and software developers to work with; it was a sloppy solution with good market potential (8 cores in a phone or tablet).
But, what many people tend to forget is the A15, while not as power efficient as A9, still (generally) had better performance-per-watt compared to most Intel Atoms and similarly clocked Celerons.
__________________
Old 11th Feb 2014, 14:38   #5
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
A9 has stuck around for so long because its cheap and still more than enough for 90% of users.
rollo is offline   Reply With Quote
Old 11th Feb 2014, 18:09   #6
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
As long as it has a good Linux support (GPU included) ...
GuilleAcoustic is offline   Reply With Quote
Reply
Tags
arm, big.little, cortex-a17, cortex-a7, cortex-a9, ian ferguson, soc, system on chip
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
