Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Feb 2014, 10:59   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
SanDisk launches 240MB/s USB flash drive
Serious speed at a hefty price.
http://www.bit-tech.net/news/hardwar...-extreme-pro/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 12th Feb 2014, 14:53   #2
Anfield
I *am* a Dremel
Anfield's Avatar
Anfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming Saiyan
pricing has been confirmed at 149.95 in the UK, putting it considerably above the level of an admittedly less-portable 128GB 2.5" SATA drive in a USB 3.0 housing.
If it was only a 128GB you could get for less, but you can actually get a 240GB Crucial M500 in a USB 3.0 housing for 125.98.
http://www.overclockers.co.uk/showpr...odid=HD-028-CR
http://www.overclockers.co.uk/showpr...odid=HD-014-AK
So yep, SanDisk is def asking way too much.
Anfield is offline   Reply With Quote
Old 12th Feb 2014, 17:36   #3
theshadow2001
[DELETE] means [DELETE]
theshadow2001's Avatar
theshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyan
Is that a wodge of storage in your pocket or are you just happy to see me?
theshadow2001 is online now   Reply With Quote
Old 12th Feb 2014, 22:03   #4
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming Saiyan
Not sure I would be happy to carry that around, USB sticks are so easy to loose
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 12th Feb 2014, 22:29   #5
play_boy_2000
It was funny when I was 12
play_boy_2000's Avatar
play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.
I'd rather go with a eSATAp (powered) adapter ($6 from china) and a regular SSD. Some of the SSD PCB's take up such a small space that you could easily hack it into something much smaller than a standard 2.5" case.
__________________
Intel Core i5 2500k @ 4.5Ghz
16GB @ 1600mhz CL9 1.5V
XFX 7950 3GB
Asus P8P67
Patriot Wildfire 120GB SSD
play_boy_2000 is offline   Reply With Quote
Old 14th Feb 2014, 01:14   #6
Anfield
I *am* a Dremel
Anfield's Avatar
If you need compact then make sure you have a smartphone with a removable battery, the battery compartment is usually big enough that you can use it to store one or more extra microSD cards.
__________________
i7 6700k, Asus Maximus Gene VIII, 2x8GB Corsair Vengeance 3000 DDR4, Reference GTX 980Ti, 512GB Samsung 950 Pro, 4TB WD Black, Corsair H105, Corsair RM850i, Corsair Carbide Air 240.
Max Blackbird TKL Mech KB, Logitech G402, AOC U3477PQU (34" 21:9 ftw)
Reply
Tags
128gb, extreme pro usb 3.0, flash drive, pen drive, sandisk, sandisk extreme pro, solid-state, storage, usb 3.0, usb flash drive
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
