Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Feb 2014, 17:05   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Titanfall Preview - A Second Look
After a second extensive preview session is Titanfall still wowing us?
http://www.bit-tech.net/gaming/pc/20...-second-look/1
Meanmotion is offline   Reply With Quote
Old 12th Feb 2014, 17:10   #2
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
Another let down from EA. Who'da thunk it?
AlienwareAndy is offline   Reply With Quote
Old 12th Feb 2014, 17:49   #3
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
Bit early to say, pick up and play shooters have had there success storys,
COD and its many iterations despite been hated on this site its still the biggest selling franchise of all time. And its a pick up and play shooter.
rollo is online now   Reply With Quote
Old 12th Feb 2014, 18:14   #4
Gunsmith
Maximum Win
Gunsmith's Avatar
Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.Gunsmith is definitely a rep cheat.
that is possibly the shittest ingame ui i have ever seen.
if you're going to patronise gamers then do it with a capitol "**** you"
__________________
The King of Crysis
// This is currently not used anywhere (David: and I don't see what this would be used for. Our hero is not Jesus).
m_stats.isWalkingOnWater = false;
Gunsmith is offline   Reply With Quote
Old 13th Feb 2014, 13:08   #5
sotu1
Ex-Modder
sotu1's Avatar
sotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on you
Yeah Gunny.... If you use the wrong 'capitol' then sure we can patronize you
__________________
Still alive
sotu1 is offline   Reply With Quote
Old 13th Feb 2014, 16:01   #6
Redbeaver
The Other Red Meat
Redbeaver's Avatar
Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!
In the meantime... play Strike Vector...
__________________
Ophelia
ASUS P5Q Pro Turbo - Q6600 - 4GB DDR2 - NVIDIA 8800GTS 640 - WD Black 2x320Gb RAID-0 - Silverstone TJ-06 [Modded]
Perseus
ASUS Z97i-Plus - i5 4670K - Corsair H110i GTX - 8GB DDR3 - Zotac GTX 970 - RAID-0 Crucial MX100 2x256GB - Phanteks Enthoo ITX Red
Redbeaver is offline   Reply With Quote
Old 13th Feb 2014, 16:11   #7
Gunsmith
Maximum Win
Gunsmith's Avatar
40 hours being awake i knew id screw up somewhere
__________________
The King of Crysis
Old 13th Feb 2014, 16:32   #8
exceededgoku
Multimodder
exceededgoku has yet to learn the way of the Dremel
I'll wait for the Gundam Wing mod, especially if it's based on Source engine!
exceededgoku is offline   Reply With Quote
Old 14th Feb 2014, 00:29   #9
fix-the-spade
Mod Master
fix-the-spade's Avatar
fix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyan
And then EA will close your Origin account for altering the game files, not that they have history with this or anything.
__________________
CMDR Fix-the-spade
fix-the-spade is offline   Reply With Quote
Old 16th Feb 2014, 16:12   #10
GravitySmacked
Mostly Harmless
GravitySmacked's Avatar
GravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming Saiyan
I've been enjoying it over the weekend but only in small bursts of 2 rounds or so at a time. I'm not sure if that's down to something the game is lacking or my old age and slower reactions.
GravitySmacked is offline   Reply With Quote
Old 16th Feb 2014, 19:18   #11
Stanley Tweedle
NO VR NO PLAY
Stanley Tweedle's Avatar
Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.
From what I played last night it was infinitely more enjoyable than the laggy, over-textured over-hyped hawken.
__________________
One of us is dumb.
Stanley Tweedle is offline   Reply With Quote
Old 17th Feb 2014, 12:39   #12
Stanley Tweedle
NO VR NO PLAY
https://www.youtube.com/watch?v=y6R7InWe-vM#t=192
Dun look too bad at all.
Just wondering why it needs tanks and aircraft to compete with BF?
Does hawken have tanks and A/C?
Hawken is just mechs and nothing else. This is foot fighting and mech. It doesn't set out to be a BF 2142.
__________________
One of us is dumb.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
