Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 13th Feb 2014, 15:26   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Intel updates NUC for better Linux support
New BIOS solves Debian boot issues.
http://www.bit-tech.net/news/hardwar...el-nuc-linux/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 13th Feb 2014, 15:39   #2
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
Well this would have been pretty awesome a few months ago. Originally tried Linux on it back then but found that the sound over HDMI (important as that's the only output...) was borked. Ended up sticking a copy of windows 8 on it to get things over and done with, CBA to replace everything now that it's all installed.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: Cheers Luv!
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 13th Feb 2014, 16:52   #3
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
You'd think Intel would've fixed something like this before releasing the product, considering its better suited for linux anyway.
I would be a lot more inclined to like these NUC boards if their price point and board layouts were better. In most cases, I'd rather go with a cortex-A15 board - they're typically cheaper, are more power efficient, slimmer, can run with passive cooling, better GPUs, and while they have less features overall, are easier to work with. I'm sure an A15 CPU is a little worse than what Intel NUC boards offer, but buying one of these platforms for processing power is a stupid approach anyway.
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Old 13th Feb 2014, 22:13   #4
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
Problem with ARM is GPU support under Linux. Safest way is to go with a Freescale SoC as they fully release their documentation (helping to have good drivers).
GuilleAcoustic is offline   Reply With Quote
Old 13th Feb 2014, 22:19   #5
schmidtbag
Ultramodder
I'd say the REAL problem is the fact that most of the GPUs are only GLES compatible. Freescale and Nvidia are the only companies I'm aware of that support good 'ol openGL, and the Vivante GL support is pretty crappy. I think the real worst issue with ARM is you can't use package maintained kernels, which is a headache in terms of drivers.
__________________
Old 13th Feb 2014, 22:56   #6
Jimbob
Multimodder
Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.
I'm sure literally several people will be pleased by this.
Jimbob is offline   Reply With Quote
Reply
Tags
debian, intel, intel nuc, linux, nuc, steam box, steam machine, steam os, ubuntu, valve
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
