Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 14th Feb 2014, 08:57   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Asus ROG Poseidon GTX 780 Review
We look at Asus' overclocked and tweakable hybrid GeForce GTX 780 that can be air or water-cooled.
http://www.bit-tech.net/hardware/gra...x-780-review/1
Meanmotion is offline   Reply With Quote
Old 14th Feb 2014, 09:49   #2
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Not read the full review... yet! But I had to come and just say that I do think that is the best looking 'off the shelf' piece of PC hardware I have ever seen.
Also, I do think the price is not that bad either considering the ASUS DirectCUII card is only £60 less expensive. If I was considering spending that much on the air cooled ASUS card I think I would definitely pay the extra and get this instead. The only thing that would make me think twice is if they plan to release a Ti version at all...
__________________
SchizoFrog is offline   Reply With Quote
Old 14th Feb 2014, 09:56   #3
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
Just lovely.
AlienwareAndy is offline   Reply With Quote
Old 14th Feb 2014, 11:09   #4
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
Personally I think that this card is beautiful when compared with other air cooled cards, but hideous when compared to a card fitted with a normal block.
I can certainly see the useful side of this though. If anything it would be great thanks to the flexibility of not having to change from air to water and vice versa when circumstances change. If you're redoing a loop for instance, you could just run I on air whilst you sort other things out (just slap a simple heatsink on the CPU for that time). This is a fair bit more practical than having to remove the blocks and put the air coolers back on, or simply not have the option of using the PC at all in the interim.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: I Need Healing!, Parvum Argentum
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 14th Feb 2014, 12:00   #5
Panos
Supermodder
Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.
Another great review from bit-tech. Keep the good work guys.
In general, while the card is beautiful, at the price (£500) maybe tad bit expensive if go only for air?
A Zotac 780Ti AMP goes for £530, and a Palit 780Ti Jetstream for£519 which are pre overclocked to 1000 already.
Panos is offline   Reply With Quote
Old 14th Feb 2014, 12:30   #6
Si_the-dude
Techaholics Anonymous. 0 days clean
Si_the-dude's Avatar
Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.Si_the-dude is the Cheesecake. Relix smiles down upon them.
Pure sexytimes. Recent purchases aside I'd been waiting on ASUS releasing the TI version of this. I hope they do as this is a mighty fine bit o'kit! Good work ASUS!
__________________
Delidded i7 4770k @ 4.7- Custom EK loop with 360mm and 240mm rads - Watercooled GTX Titan SLI - Gigabyte G1 Sniper M5 - Corsair Vengeance 16gb with EK block - Monsoon Fittings - Phanteks Enthoo Primo - Dell U2713HM
Si_the-dude is offline   Reply With Quote
Old 14th Feb 2014, 19:24   #7
law99
Custom User Title
law99's Avatar
law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.
Good idea and looks good? I missed the boat. Bought too early in this gen...
__________________
3570k WC @ 4.7giggles | 8gb Kingston 2133mhz | ASUS Sabertooth Z77 | soaking 1070 gtx | Seasonic x-660w | NZXT 810 switch | Crucial M4 128gb | 2x F3 1tb Raid 1 | NZXT Sentry 6ch 50w fan controller | BenQ bl3200pt 2560x1440p
law99 is offline   Reply With Quote
Old 15th Feb 2014, 09:30   #8
Tattysnuc
Thinking about which mod to do 1st.
Tattysnuc's Avatar
Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.
If only they'd transfer these technologies over to an AMD 290 - then I'd have bought one... two actually.
When building a rig, it's a constant cause of frustration that I have to build once with Air cooling, then switch over component by component to test each installation of the water blocks - with component like this coming pre fitted, you can test it when it arrives by just plugging it in, then cut over to water cooling, piece by piece.
A great concept that looks exceptionally well delivered. Now all they have to do for me is have the fans as a clip on/off feature that reduces the waterblock down to a single card thickness for SLI purposes....
Tattysnuc is offline   Reply With Quote
Old 15th Feb 2014, 10:13   #9
law99
Custom User Title
law99's Avatar
Exactly! To stop constant tear downs, I need to basically buy another pump so I can test the block before chucking it in. That or just putting it in there and hoping for the best...
__________________
Old 16th Feb 2014, 01:48   #10
brave758
Ultramodder
brave758's Avatar
brave758 is definitely a rep cheat.brave758 is definitely a rep cheat.brave758 is definitely a rep cheat.brave758 is definitely a rep cheat.brave758 is definitely a rep cheat.brave758 is definitely a rep cheat.brave758 is definitely a rep cheat.brave758 is definitely a rep cheat.brave758 is definitely a rep cheat.brave758 is definitely a rep cheat.brave758 is definitely a rep cheat.
I love this. Asus... We want more
__________________
The PC : X99 Deluxe = Crucial 16gig@2400= i7 5820K EKWB = PA 120.3 Rad = EKWB EVGA 780 ti classified SLI = Corsair AX1200i PSU = Mountain Mods U2-UFO= 2 x M4 SSD raid 0
Laptop : Alienware M17XR3, 2960xm, 16g corsair vengeance 1600, crucial M4 256, GTX680M 4gig, 3D, Killer networks wifi card.
Our lives begin to end the day we become silent about things that matter. (Martin Luther King)
brave758 is offline   Reply With Quote
Old 16th Feb 2014, 02:16   #11
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming Saiyan
Hmm, now I'm wondering... This or an EVGA 780 Classified next payday? Decisions decisions....
FWIW I'm leaning towards this because it comes ready to liquid cool and also with a backplate, neither of which are true for the Classified unless you go for the Hydro Copper version, which doesn't allow running and testing without a loop installed and running. It's looking like EVGA just got done out of a sale by Asus. Again.
__________________
"For every stalwart bit-tech-worthy tech out there, another 2 cretinous arse-scratchers are out there pulling your patches and reconfiguring your ****." - Krikkit
Unicorn is offline   Reply With Quote
Old 16th Feb 2014, 03:56   #12
siliconfanatic
Johny-come-Lately
siliconfanatic's Avatar
siliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyan
Hybridized air/water cooler?
__________________
Do not let anything good in life pass you by. Cherish it with all of your heart, because before you know it even life will have passed you by. And if you let all those things pass you by? The only thing filling your heart will be deep sadness and regret. So whatever you do, hold on, and never let go.
siliconfanatic is offline   Reply With Quote
Old 16th Feb 2014, 12:24   #13
SchizoFrog
I *am* a Dremel
Is there any news about full cover water blocks for an ASUS GTX 760? I am thinking that if I went with ASUS (which I very much want to) then I would have to go with a GTX 770 rather than my GTX 760 choice and that is significantly more and would probably be above my limits... OR go with another GTX 760 supplier.
__________________
Old 16th Feb 2014, 13:36   #14
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
GTX 770 Poseidon should be on sale this month.
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 16th Feb 2014, 13:48   #15
SchizoFrog
I *am* a Dremel
Well if it has the same mark up as this version it is going to come in just under the lower priced OC'd and custom cooled GTX 780's at around £350.
__________________
Old 17th Feb 2014, 11:02   #16
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
You know where to send it
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 17th Feb 2014, 12:42   #17
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Email Gareth
Also 'should' = no commitment
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
