Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 18th Feb 2014, 15:01   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Nvidia GeForce GTX 750 Ti Review
Nvidia's Maxwell architecture is here at last. What does the £115 GTX 750 Ti bring to the table?
http://www.bit-tech.net/hardware/gra...50-ti-review/1
Meanmotion is offline   Reply With Quote
Old 18th Feb 2014, 15:38   #2
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
So this would be the fastest performing card that does not require a power connector of some discription?
rollo is offline   Reply With Quote
Old 18th Feb 2014, 15:56   #3
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
As far as I know, yes.
Dogbert666 is offline   Reply With Quote
Old 18th Feb 2014, 16:17   #4
penryn 2 hertz
I'm not a science fiction writer...
penryn 2 hertz's Avatar
penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.
Other brands will implement the 6 pin for overclocked versions. The cooler looks like trash in my opinion roll on aftermarket solutions...
__________________
“The atoms of our bodies are traceable to stars that manufactured them in their cores and exploded these enriched ingredients across our galaxy, billions of years ago. For this reason, we are biologically connected to every other living thing in the world. We are chemically connected to all molecules on Earth. And we are atomically connected to all atoms in the universe. We are not figuratively, but literally stardust.”
― Neil deGrasse Tyson
penryn 2 hertz is offline   Reply With Quote
Old 18th Feb 2014, 16:22   #5
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
Which will add another £10-15 to the price, in which case you may as well get a R9 270...(unless you only have the option of a card that doesn't need a power connector of course)
Hustler is offline   Reply With Quote
Old 18th Feb 2014, 16:30   #6
Dedlite
Multimodder
Dedlite has yet to learn the way of the Dremel
Can I ask, given your table on the first page, where does the 660 Ti (that I have) fit in?
Dedlite is offline   Reply With Quote
Old 18th Feb 2014, 16:33   #7
penryn 2 hertz
They will be always expensive on release then drop about £20 a few weeks later... Aftermarket brands will be the same price as the stock card on release...
__________________
Old 18th Feb 2014, 16:44   #8
Dogbert666
bit-tech Staff
Dogbert666's Avatar
Sure. The GTX 660 Ti is no longer considered part of the current generation of cards, so it's not in production. However, it technically fits in above the GTX 660, and performs just below the level of the GTX 760, which is a current card
Old 18th Feb 2014, 16:50   #9
penryn 2 hertz
Strange place to put power connector...
__________________
Old 18th Feb 2014, 16:52   #10
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
This card seems to yield much better results under linux, at least compared to other cards (including nvidia brand). I'm not sure if the same tests perform better in linux compared to windows, but lately that seems to be the case.
Also a seriously overkill heatsink.
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Old 18th Feb 2014, 17:03   #11
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
I expect it was the smallest one they had
__________________
3770K | Z77E-ITX | Liqtech 120X | EVGA GTX 980Ti SC | 8GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 18th Feb 2014, 18:10   #12
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
Good to see a capable card with NO power connector. Hope we'll see some REAL single slot version.
GuilleAcoustic is offline   Reply With Quote
Old 18th Feb 2014, 18:20   #13
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
Wow. Evga ftw has core clock of 1189, boosting to 1268. Ridiculous! This all bodes very well for higher end cards. AMD best have some very big improvements over their current architecture, but i have a feeling everyone in their HQ just gulped very, very hard.
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP³ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 18th Feb 2014, 18:47   #14
Sheiken
Wat?
Sheiken's Avatar
Sheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpit
I could very well be interested in this card.
I love the efficiency of it!
__________________
Whoring Out My Hardware 4.6!
Portaputer - rMBP Late 2013 - 13" / i5 / 8GB / 256gb ssd
Sheiken is offline   Reply With Quote
Old 18th Feb 2014, 19:05   #15
SlowMotionSuicide
Come Hell or High Water
SlowMotionSuicide's Avatar
SlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for president
Holy **** hadn't realized how far the latest cards have become since my GTX480. Bested by low-end budget card! Nice of you to have it (480) included in the graphs.
Time for an upgrade methinks, atleast when the higher end cards hit the shelves.
__________________
G3258 @ 4.3GHz | MSI Z97 Gaming 5 | 8Gb Dominators | GTX 660 | Crucial MX100 256GB | F1 Spinpoint 1TB | Seasonic P-760 (XP²) | NZXT H440W
SlowMotionSuicide is offline   Reply With Quote
Old 18th Feb 2014, 22:22   #16
schmidtbag
Ultramodder
I know what you mean, it is a little irritating. I own 2 overclocked HD5750s and they're not going to be able to keep up much longer. Together, they can play just about any last-gen game at full detail (without AA) at 1080p but I don't even think slapping a 3rd card in there will make my current system keep up with newer games. I think it's a little too early for me to decide to upgrade though - right now the 750Ti has the best performance-per-watt of any GPU and by a large margin. I want to see it's PPW ratio on more high-end cards.
But I feel things have been a little too calm in the GPU world lately. Regardless of the bias people have for each company, AMD and nvidia are pretty head to head in performance, depending on what tests you're looking at. We haven't had a big change in a long time. GPUs aren't getting much faster or more efficient lately - the changes feel very incremental. I feel like something big has to happen soon.
__________________
Old 19th Feb 2014, 00:22   #17
MrJay
You are always where you want to be
MrJay's Avatar
MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.
Wow, those are some pretty sweet numbers from such a low wattage card, plumped for a 650ti for a recent build for a friend. He was interested in playing Nvidia optimised titles and it was the only card in his price bracket. This card will be ideal for future friends and family budget builds : )
__________________
Main Phanteks Enthoo ITX Windowed - Pentium G3258 @ 4.5GHz - 8GB Samsung DDR3 @ 1600 MHz - Sandisk Ultra 240GB - EVGA 760 SC 2GB - Asrock Z97M-ITX/ac - Windows 10
HTPC Intel NUC (Celeron 847) - 30GB Samsung mSATA SSD - 2GB Crucial RAM 1333MHz - Windows 10
MrJay is offline   Reply With Quote
Old 19th Feb 2014, 03:56   #18
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
/this
I'd really like to see a single-slot GTX750, preferably in low-profile
Totally kills the AMD R7-250, which I was considering for my next mITX-system and isn't that much more expensive either.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 19th Feb 2014, 09:33   #19
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Can I also ask if you have an ASUS GTX 750 Ti DirectCUII coming any time soon for review?
__________________
SchizoFrog is offline   Reply With Quote
Old 19th Feb 2014, 09:52   #20
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
Hmm. Well I must say the 750 looks very impressive however I do have my reservations. I used to own a pair of 480s and when clocked pretty high they could nip at the heels of a stock 7970 (one not both !). I know things have moved on and I know that these new cards are pretty sweet but unless you're in it for the power savings I think the 480 would still be the better card.
I must say though the power use is pretty amazing. Shame Nvidia have put such a horrid looking cooler on it.
AlienwareAndy is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
