Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th Feb 2014, 12:47   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Sennheiser G4ME One Review
We take a look at Sennheiser's high-end open-back gaming headset.
http://www.bit-tech.net/hardware/per...e-one-review/1
Meanmotion is offline   Reply With Quote
Old 25th Feb 2014, 14:07   #2
edzieba
Virtual Realist
edzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyan
Again, if you want to pay the letters-replaced-by-numbers tax than they're a not-awful set of headphones, but poor value for money even compared to Sennheiser's non-bling lines.
edzieba is offline   Reply With Quote
Old 13th Jun 2014, 10:46   #3
Omikron
What's a Dremel?
Omikron has yet to learn the way of the Dremel
After reading your Sennheiser G4ME One Review, I believe you have 2 major typos by messing around One and Zero:
On page 1, you wrote: "Nonetheless, while the G4ME One can fold flat, the earcups of the Zero are fixed, except for a little bit of movement – 5 or 10 degrees – to allow them to adjust to your head."
Do you actually mean G4ME Zero can fold flat, the earcups of the One are fixed?
On page 2, you wrote: "Whereas the One felt like they were floating around your head the Zero are very much pinned too it."
Do you actually mean Zero felt like they were floating around your head the One are very much pinned to it?
Omikron is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
