Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 17th Mar 2014, 09:59   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
MSI Z87I Gaming AC Review
Can MSI's new 120 enthusiast mini-ITX board better Asus and EVGAs premium boards?
http://www.bit-tech.net/hardware/mot...ng-ac-review/1
Meanmotion is offline   Reply With Quote
Old 17th Mar 2014, 11:22   #2
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
Originally Posted by Article
The INtel Z87 chipset has bee a fantastic
May want to have a glance at that part again
These MSI boards are great for the money, but it's the layout that leaves them dead in the water for me. When I was shopping around for one, I ended up opting for the Asus Z87 I-Pro (despite the higher price tag and non-matching colour scheme) simply because it's layout was that good. Having all the power connectors on the edge of the board (and on a handy side too) just makes things look that much cleaner, plus it means you don't have cables in hard to reach areas.
Would be nice if the wireless card didn't stick out so much on this one too, would definitely need to give it a bit of TLC if it were to be on show through a window or something.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: I Need Healing!, Parvum Argentum
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 17th Mar 2014, 11:31   #3
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Fixed, thanks!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 17th Mar 2014, 12:20   #4
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
It seems ironic that my first comment is regarding the 'wires' for the 'wireless' adapter. How half arsed is that? Could MSI not have even tried to route the cables more effectively? Even to have them clipped around the perimeter would have been better than two lose wires running straight across the board and close to the CPU cooler area.
Hands down it is a great board but those layout choices really do affect it for me and I believe they should have counted more against it. Especially as an Mini-ITX board where neatness and tidyness are so much more important.
Hopefully though this board's price will help ASUS to reduce their 'Impact' (?) Z97 version slightly although I doubt it will be a significant discount due to their better circuitry, more features along with the daughter board for improved sound.
Although having seen the specs of the 750Ti, I like may others, am eager to see what the higher end GPUs bring to the table and us such I have decided to hold my new build until the new Maxwell chips arrive as I believe they will bring a significant performance boost along with massive efficiency benefits which over time will be well worth the wait.
__________________
SchizoFrog is offline   Reply With Quote
Old 17th Mar 2014, 13:28   #5
Redbeaver
The Other Red Meat
Redbeaver's Avatar
Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!
My dream board for the past couple months.... just need to save up enough budget to purchase the CPU + RAM as well.
....but then you guys got an article on possibly-Z97 mini ITX.............
__________________
Ophelia
ASUS P5Q Pro Turbo - Q6600 - 4GB DDR2 - NVIDIA 8800GTS 640 - WD Black 2x320Gb RAID-0 - Silverstone TJ-06 [Modded]
Perseus
ASUS Z97i-Plus - i5 4670K - Corsair H110i GTX - 8GB DDR3 - Zotac GTX 970 - RAID-0 Crucial MX100 2x256GB - Phanteks Enthoo ITX Red
Redbeaver is offline   Reply With Quote
Old 17th Mar 2014, 13:38   #6
SchizoFrog
I *am* a Dremel
Upon further thoughts, I can't help but feel a little let down too by the use of only a dual channel wireless unit, especially for AC. Or am I not understanding something about it?
__________________
Old 17th Mar 2014, 16:39   #7
Combatus
Moderator
Combatus's Avatar
AFAIK the Intel 7260 is the only third party mini PCI-E 802.11ac adaptor out there - obviously going a little more customised and including something with triple antennas and the like would only push the price up but yes, I for one would like to see some higher-end WiFi kit with some of the mini ITX boards seeing as there's no way to use a PCI-E WiFi card if you're also using a graphics card.
Also SchizoFrog, like you I would also hope to see some cheaper enthusiast mini-ITX boards - the Stinger and Impact are a pretty darn expensive!
__________________
Old 17th Mar 2014, 18:57   #8
ObsCure
Minimodder
ObsCure has yet to learn the way of the Dremel
Speed
44 / 45
Speed
24 / 30
Value
22 / 25
ObsCure is offline   Reply With Quote
Old 17th Mar 2014, 19:17   #9
Combatus
Moderator
Combatus's Avatar
Originally Posted by ObsCure
Speed
44 / 45
Speed
24 / 30
Value
22 / 25
Ha ha! I didn't even think that was possible. Thanks!
__________________
Old 20th Mar 2014, 11:14   #10
ArthurB
Minimodder
ArthurB has yet to learn the way of the Dremel
The Z87I Gaming AC is certainly much better looking than its cheaper sibling too and the heatsinks that are included shouldn't interfere with any coolers. Layout on the hole is good, although there are a couple of bones to pick here.
Which hole are you referring to?
ArthurB is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
