Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 20th Mar 2014, 13:40   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Ubisoft shows off The Division's Snowdrop Engine
Ubisoft gives insight into its in-house engine being used to create The Division.
http://www.bit-tech.net/news/gaming/...s-snowdrop-e/1
Meanmotion is offline   Reply With Quote
Old 20th Mar 2014, 14:03   #2
SimoomiZ
Modder
SimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for president
The Division gameplay looked absolutely incredible. So incredible in fact, people are questioning whether it was a 'target render' , aka 'bullshots' in motion.
SimoomiZ is offline   Reply With Quote
Old 20th Mar 2014, 14:08   #3
XXAOSICXX
Hypermodder
XXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpit
"Tom Clancy's The Division is a third-person tactical shooter RPG MMO"
*facepalm*
Just...no.
XXAOSICXX is offline   Reply With Quote
Old 20th Mar 2014, 14:31   #4
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
It looks good but I won't be buying it unless there is a beta or something so I can see how the 3rd person works as I generally don't like 3rd person games.
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 20th Mar 2014, 16:03   #5
Skiddywinks
Hypermodder
Skiddywinks has yet to learn the way of the DremelSkiddywinks has yet to learn the way of the Dremel
Look up the Limit Theory update videos if you want to know anything else about this nodal based coding. Josh (the lone developer of LT) has raved about the benefits and has been using nodes for everything; AI, UI, research trees etc.
Skiddywinks is offline   Reply With Quote
Old 20th Mar 2014, 16:05   #6
Dave Lister
Hypermodder
Dave Lister's Avatar
Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!
Looks impressive.
__________________
Main Rig:Case: BitFenix Prodigy, Motherboard: MSI Z97I Gaming, CPU: Intel i7 4790K, RAM: 16Gb 2400Mhz Kingston HyperX Beast GPU: MSI GTX 970 Gaming, Primary HDD: 256Gb Samsung 850 Pro, Games Drive: 4Tb Toshiba X300, Cooler: Corsair H105, OS: Win 7 - 64, VR: Oculus with touch
Dave Lister is offline   Reply With Quote
Old 20th Mar 2014, 19:02   #7
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.
Small tip for bit-tech - please could you use YouTube's iframe embed code instead of directly using a Flash object? That way it'll use HTML5 for video by default. I'm unable to view the video on my iPad and had to go to my desktop to watch it.
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | XFX Radeon 7970 DD | 500GB Samsung 840 Evo | Samsung XL2270HD | KBT Race | Logitech G402
Mac: 13 inch MacBook Pro 2014 | 16GB RAM | Filco Minila Air | Magic Trackpad
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 | Arch Linux
r3loaded is offline   Reply With Quote
Old 20th Mar 2014, 23:38   #8
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
I didn't have the video on Chrome on my Windows machine either. Been an issue for a while...
__________________
The Angel Delights?
mi1ez is online now   Reply With Quote
Old 21st Mar 2014, 03:43   #9
LordPyrinc
Legomaniac
LordPyrinc's Avatar
LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.
Every time I try out a game that is 3rd person view I just get frustrated and disappointed. If you can play something like Skyrim in first person view, why the heck would you make a shooter game third person? It just doesn't make sense to me. It's disorienting and awkward. Give me a view down the sights of the gun and I'll play it. I don't want to be staring at the rear end of my character the whole time, blocking part of the field of view. I especially detest the main character being placed off center on some of these games. I've always felt that first person view is more immersive to the player and just feels more natural.
__________________
Intel i7-920 @ 2.66GHz - Corsair Vengeance 16GB DDR3 @ 1600MHz - Windows7 64bit - Firestrike Ultra Score 6645
2 x 150GB WD VelociRaptor HDs (RAID 0) - 1TB WD 7200 rpm HD - 60GB OCZ SSD - 1TB WD External USB HD
2 x NVidia Founders Edition 1070 GTX 8GB (SLI HB Bridge) - Razer BlackWidow Ultimate - Logitech Proteus Spectrum G502
Corsair Polaris MM800 - Cooler Master HAF 922 - Thermaltake Smart M 850W - 40" Samsung UHD 640D LED Display (3840x2160)
LordPyrinc is offline   Reply With Quote
Old 21st Mar 2014, 10:45   #10
Stanley Tweedle
NO VR NO PLAY
Stanley Tweedle's Avatar
Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.
I also generally don't like 3rd person games but there have been exceptionss... the most recent Tomb Raider with massive in your face boobies and also a game from some years ago called Dark Sector. Actually Dark Sector looks very nice graphically even now. Dead Space was also a game I hated initially because of the 3rd person but when I actually went back and played it I liked it a lot.
The Division looks very good and I don't know why some are suggesting it's pre-rendered. Top game engines are certainly at this level and beyond.
__________________
One of us is dumb.
Stanley Tweedle is offline   Reply With Quote
Old 22nd Mar 2014, 09:36   #11
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
Works fine on my Surface RT...
/runs
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is online now   Reply With Quote
Old 22nd Mar 2014, 10:24   #12
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
Ain't gonna lie, that looks gorgeous.
AlienwareAndy is offline   Reply With Quote
Old 22nd Mar 2014, 10:31   #13
GravitySmacked
Mostly Harmless
GravitySmacked's Avatar
GravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming Saiyan
I'm excited to see how this game turns out; it looks extremely promising!
GravitySmacked is offline   Reply With Quote
Old 22nd Mar 2014, 13:17   #14
SexyHyde
Supermodder
SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.SexyHyde is the Cheesecake. Relix smiles down upon them.
Originally Posted by Nexxo
Works fine on my Surface RT... /runs
LOL
Had some trouble with Youtube on Chrome personally, and got friends who have had trouble with it on Firefox.
SexyHyde is online now   Reply With Quote
Old 22nd Mar 2014, 20:38   #15
r3loaded
Ultramodder
r3loaded's Avatar
/runs
Let me know when I can get apps for Digg Reader and Pocket on it (apps that are also available on my Nexus 4)
But yeah, I use Firefox on my Linux desktop and I have Flash installed but disabled because it runs like crap. Doesn't help that Adobe abandoned Linux on Flash 11 and only update it for security fixes. Hence I try to live a Flash-free existence.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
