Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th Mar 2014, 11:21   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Microsoft warns of Word zero-day vulnerability
Code execution flaw in RTF support.
http://www.bit-tech.net/news/bits/20...ord-zero-day/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 25th Mar 2014, 11:40   #2
Umbra
Hypermodder
Umbra's Avatar
Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.Umbra is definitely a rep cheat.
More people should try "Open Office" it will do what most people want for free and your not on the MS front line with all the scumbags trying to infect your software
Umbra is offline   Reply With Quote
Old 25th Mar 2014, 12:48   #3
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming Saiyan
I just tried the fixit on my system, and it came back as does not apply to your system, I have win8.1pro +office professional plus 2013
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 25th Mar 2014, 13:36   #4
Snips
I can do dat, giz a job
Snips's Avatar
Snips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming Saiyan
Unless you intend to send files to other Microsoft Office users.
Snips is offline   Reply With Quote
Old 25th Mar 2014, 14:13   #5
Gareth Halfacree
WIIGII!
bit-tech Staff
OpenOffice (and LibreOffice) support loading and saving to both .DOC and the new DocX format, and the latest Microsoft Office fully supports the Open Document Format used by OpenOffice. I should know: I wrote an entire book in LibreOffice, sending the files in .DOC format to the publisher. Worked fine.
__________________
Old 25th Mar 2014, 18:10   #6
Snips
Snips's Avatar
As I've said before Gareth, I've been sent files that have been unable to open within Office. It wasn't Microsoft's fault. I was even asked to download a copy of the software to be able to open the file. It never was and we never used the company again. The majority of the business world is using Microsoft Office, if you make an open version, at the very least get it to be compatible with the major player.
Old 25th Mar 2014, 18:19   #7
RedFlames
...is volatile under pressure.
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
While interoperability between the two is a lot better than it was, there's still the odd issue on both sides... TBH I've had more grief with stuff done in iWork [Pages, Keynote and Numbers] than Libre/OpenOffice...
That said, are RTF documents that common any more? Haven't come across/been sent one in ages...
__________________
You wouldn't really die of anything, in the traditional sense. You would just stop being biology and start being physics.
RedFlames is offline   Reply With Quote
Old 25th Mar 2014, 21:40   #8
RichCreedy
Hey What Who
RichCreedy's Avatar
yeah I've had customers who have had issues with libre office and open office files when trying to use word/excel files.
__________________
Old 25th Mar 2014, 22:49   #9
wolfticket
Downwind from the bloodhounds
wolfticket's Avatar
wolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyan
Word is quite good though... Especially if you use the bits that most people don't use, and for a lot of people it's what they're comfortable with.
Compatibility is a moot point as it works both ways, but I haven't found it to be perfect by any means working in either direction or indeed between different versions of MS Office..
Most office packages will open files created in others but whether they'll look the same is another matter.
This sounds like a fairly niche exploit since it relies on using Word to preview emails via Outlook. Not a huge issue for most users.
__________________
Wolfticket: Ambitious but rubbish
"A facility for quotation covers the absence of original thought."
Dorothy L. Sayers (1893 - 1957)
wolfticket is online now   Reply With Quote
Old 25th Mar 2014, 23:09   #10
theshadow2001
[DELETE] means [DELETE]
theshadow2001's Avatar
theshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyan
Compatibility is ok not brilliant. I reckon most users Professional or otherwise would be fine with what Libre office offers. But they use ms office at work so they use it at home.
Certainly I'll never buy office off of ms when Libre office us around.
theshadow2001 is online now   Reply With Quote
Old 26th Mar 2014, 00:08   #11
Umbra
Hypermodder
Umbra's Avatar
I'm sure it is and I'm not disputing that but I'm too tight to buy software that I don't use that much especially if a free open source program does what I want
Old 26th Mar 2014, 08:32   #12
Alecto
Multimodder
Alecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the Dremel
Why would this be an issue? Microsoft Office is incompatible with different versions of itself so anybody locked into M$ Office ecosystem (either by foolish personal choice or by company decision) is already familiar with formatting getting lost when sending stuff around. Don't want your documents to get all messed up? Don't use M$ Office.
Alecto is offline   Reply With Quote
Old 26th Mar 2014, 09:05   #13
Gareth Halfacree
WIIGII!
bit-tech Staff
Why wasn't it Microsoft's fault? It certainly sounds like it was as much Microsoft's fault as OpenOffice's fault.
Tell you what, let's get scientific here. You make a file in Word, save it as DocX, and send it to me. Then post a screenshot of Word displaying said file in this 'ere thread. I'll download the file, open it in LibreOffice, and post a screenshot of the same file - and we'll see how good the compatibility really is.
You up for that, Snips?
__________________
Old 26th Mar 2014, 12:06   #14
Snips
Snips's Avatar
How about you send me the file, since that's the major issue I've had with "open" Office.
"The majority of the business world is using Microsoft Office, if you make an open version, at the very least get it to be compatible with the major player."
I also said that but you cut it from the quote.
Old 26th Mar 2014, 12:18   #15
Gareth Halfacree
WIIGII!
bit-tech Staff
No need for the scare quotes, Snips; OpenOffice is open. Would you like a copy of the source code?
Here's a file created in LibreOffice and saved as .DocX (although I can provide the ODT version, if you've got a copy of Office new enough to support the Open Document Format), and here's what it should look like:
(Text courtesy Picksum Ipsum.)
__________________
Old 26th Mar 2014, 14:22   #16
Snips
Snips's Avatar
Yep, that file works fine Gareth. Is that to Microsoft's credit then?
Old 26th Mar 2014, 14:32   #17
Gareth Halfacree
WIIGII!
bit-tech Staff
No, that's all on the LibreOffice devs; as far as Microsoft Office is concerned, that's a native DocX file. Now, if you want to paint Microsoft in a good light, try it again with the Open Document Format version. If Office loads that without corruption, then yes; that would be to Microsoft's credit. (It should, by the way; as far as I'm aware, ODT support in the latest Office is pretty solid.)
__________________
Old 26th Mar 2014, 14:36   #18
Snips
Snips's Avatar
Yep, on this device it's only using Office 2007 and it works fine. So is that to Microsoft's credit?
Old 26th Mar 2014, 14:46   #19
Gareth Halfacree
WIIGII!
bit-tech Staff
Absolutely it is, yes. So, we're agreed: compatibility, at least for word processor documents, between LibreOffice and Microsoft Office is fine these days. Huzzah!
Which means, of course, that this:
has come to pass; the LibreOffice team did "get it to be compatible with the major player." Not bad for a freebie, hey?
__________________
Old 26th Mar 2014, 15:14   #20
theshadow2001
My only major complaint with Libre office writer is the image scaling tool is rubbish. If that was on par with Word it would be superdeeduperdy
Reply
Tags
code execution, critical, fix-it, microsoft, microsoft office, microsoft word, outlook, security, vulnerablity, word, zero-day
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
