Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 31st Mar 2014, 09:28   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Intel upgrades the Edison
Opts for tried-and-tested Atom.
http://www.bit-tech.net/news/hardwar...-edison-atom/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 31st Mar 2014, 10:51   #2
Narishma
Multimodder
Narishma has yet to learn the way of the Dremel
I was under the impression that Quark was more of a beefed up 486 rather than Pentium.
Narishma is offline   Reply With Quote
Old 31st Mar 2014, 11:01   #3
Gareth Halfacree
WIIGII!
bit-tech Staff
Then you were under the wrong impression; it's the full Pentium instruction set architecture, right down to having the F00F Bug - which wasn't present on the 486. I can tell you that as an absolute certainty, 'cos I've got a Quark-based Galileo right 'ere.
__________________
Old 31st Mar 2014, 11:20   #4
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
Might be interesting. I'm after something that can handle FLAC and generate I²S signal. Right now the Beagle Bone Black is my best friend, but I'm not done searching for another viable solution .
GuilleAcoustic is offline   Reply With Quote
Old 31st Mar 2014, 11:23   #5
Gareth Halfacree
WIIGII!
bit-tech Staff
The Edison's no good for you, then; it's more of a computer-on-module (CoM) than a single-board computer (SoC). Have you looked into a Raspberry Pi with a Wolfson Audio board attached?
__________________
Old 31st Mar 2014, 12:00   #6
GuilleAcoustic
Ook ? Ook !
I'm following this blog : http://hifiduino.wordpress.com/
They made an interresting comparison between Rpi and BBB : http://hifiduino.wordpress.com/2014/...ack-for-audio/
I have an antique (1963) Telefunken valve amp + valve radio tuner that I'm willing to modernize. The idea is to keep the antique look of it and add a network controlled media player. I need a C with ethernet + IS to access and read audio files (or web radios) and and IS DAC to send analog signal to the preamp stage (ECC83).
I've ordered two Ti/BurrBrown PCM1794A chip soldered onto an SSOP28 to DIP adaptor for the DAC purpose (one per channel).
Reply
Tags
atom, brian krzanich, ces, edison, embedded, galileo, intel, mcu, michael bell, quark, silvermont
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
