Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 3rd Apr 2014, 18:51   #1
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
Antec Kühler H20 950 Review
With a thick radiator and updated pump design, is the refreshed Kühler range still up to scratch?
http://www.bit-tech.net/hardware/coo...0-950-review/1
Dogbert666 is offline   Reply With Quote
Old 3rd Apr 2014, 19:03   #2
CrapBag
I Mod, Therefore I Own
CrapBag's Avatar
CrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming Saiyan
I've been considering an AIO because I'm fed up with the size of air coolers and the fact that they reduce access to parts of the mobo (mainly ram) but these AIO's seem to take up just as much space albeit in a different area.
If I was to fit one of these into my case it would still restrict access to the mobo cpu power socket and I'd imagine.
It's the dual fan idea that seems to bulk them out.
CrapBag is offline   Reply With Quote
Old 3rd Apr 2014, 19:49   #3
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
That is true, although I guess AIOs do at least let you remove the radiator giving you full access to the motherboard. This is usually just held in using four screws so is much easier to remove (and reinstall) than an entire large air cooler.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 4th Apr 2014, 13:29   #4
Farfalho
Supermodder
Farfalho's Avatar
Farfalho has yet to learn the way of the Dremel
So, still nothing on AMD platform? This has being a recurrent thing with no explanation so far :\
You guys know there are people still with AMD.
Farfalho is offline   Reply With Quote
Old 4th Apr 2014, 16:54   #5
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
Then get a H100 or dual rad of sorts and find a case where you can fit it in the roof. Then you have one block/pump and that's it. They leave tons of room to work around.
AlienwareAndy is offline   Reply With Quote
Old 4th Apr 2014, 19:09   #6
CrapBag
CrapBag's Avatar
I love my case so that's not an option, I'm not knocking these coolers I'm just saying size wise they don't save much physical space they just relocate it.
My case takes 2 x 140mm fans in the roof so I could fit a H100 style cooler but it would still encroach on my board.
Old 7th Apr 2014, 09:14   #7
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
I thought that was one of the major advantages, that they simply relocate the cooling to an area that's a little more out of the way? After all, it's not as if they're suddenly going to magically shrink in total size, we're still dealing with dissipating all the heat into flowing air after all.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: I Need Healing!, Parvum Argentum
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 9th Apr 2014, 19:17   #8
Nikumba
Hypermodder
Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.
Think the copy on the front page is wrong :P
HARDWARE > COOLING | 3rd Apr 2014 6
With a slimmer radiator and thinner tubes than the H80i, is the £64 H75 still up to scratch?
I am pretty sure the H80 and the H75 are Corsair
Kimbie
Nikumba is offline   Reply With Quote
Old 9th Apr 2014, 20:30   #9
Dogbert666
bit-tech Staff
Dogbert666's Avatar
Kimbie
I don't know what you're talking about
(thanks)
Old 9th Apr 2014, 21:08   #10
Nikumba
Hypermodder
teehee no worries
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
