Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 8th Apr 2014, 13:00   #1
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
AMD Radeon R9 295X2 Review
This bonkers card features two R9 290X GPUs and liquid cooling. Oh, and a >1,000 price tag...
http://www.bit-tech.net/hardware/gra...295x2-review/1
Dogbert666 is offline   Reply With Quote
Old 8th Apr 2014, 13:07   #2
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Personally I prefer the ASUS approach to hybrid cooling with their ROG Poseidon range. This system looks tacky and more like a botch job to me rather than a professional design.
Considering the dual GPU nature I am surprised that no SLi or XFire set-ups were compared.
__________________
SchizoFrog is offline   Reply With Quote
Old 8th Apr 2014, 13:11   #3
Dogbert666
bit-tech Staff
Dogbert666's Avatar
We would have had we had two samples of anything on hand. Sadly it was too short notice to get anything else in, hopefully we'll be able to for when Titan Z comes in.
Old 8th Apr 2014, 13:15   #4
Harlequin
I Mod, Therefore I Own
Harlequin's Avatar
Harlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming Saiyan
Woot for AMD math
1 x 8pin power is 150w
so 2 is 300w and
the slot for 75 w = 375.
wonder where the extra 125w is coming from
__________________
They shall grow not old, as we that are left grow old:
Age shall not weary them, nor the years contemn.
At the going down of the sun and in the morning
We will remember them
Harlequin is offline   Reply With Quote
Old 8th Apr 2014, 13:18   #5
Dogbert666
bit-tech Staff
Dogbert666's Avatar
Originally Posted by Harlequin
Woot for AMD math
so 2 is 300w and
This card needs a lot more current per connector, so that's where :P
Old 8th Apr 2014, 14:02   #6
Harlequin
Harlequin's Avatar
cant increase the voltage since that's fixed at 12v , so they must be stuffing more amps through....
__________________
Old 8th Apr 2014, 14:07   #7
Dogbert666
bit-tech Staff
Dogbert666's Avatar
Yeah, you need them connected to separate 12V rails that can each supply 28A.
Old 8th Apr 2014, 14:08   #8
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming Saiyan
It's pretty ugly. For that and the ridiculous price I think I'll pass.
__________________
"For every stalwart bit-tech-worthy tech out there, another 2 cretinous arse-scratchers are out there pulling your patches and reconfiguring your ****." - Krikkit
Unicorn is offline   Reply With Quote
Old 8th Apr 2014, 14:10   #9
Harlequin
Harlequin's Avatar
so its openly way above pcie spec then?
since 175 (w)/12(v) = 15(a) or just under
this it it at 336watts per 12v rail....
__________________
Old 8th Apr 2014, 14:13   #10
SimoomiZ
Modder
SimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for president
That 4k performance makes it look fairly future proof. Were it more competitively priced vs Titan Black they could have a winner.
Guessing with regards to the BF4 bench, the mantle driver doesn't support this yet?
SimoomiZ is offline   Reply With Quote
Old 8th Apr 2014, 14:17   #11
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
Beast card
AlienwareAndy is offline   Reply With Quote
Old 8th Apr 2014, 14:26   #12
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
Personally I think the box looks nicer than the card itself. Can't deny the performance figures though.
You can just tell that a few years down the line, this generation of GPUs is going to be one where we look back and ask "What the F*** went wrong with the pricing there".
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: Cheers Luv!
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 8th Apr 2014, 14:49   #13
Harlequin
Harlequin's Avatar
titan black is like $1100 and titan Z is apparently $3000
__________________
Old 8th Apr 2014, 14:59   #14
rollo
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
Pricing is crazy, 2 780s or 2 780 ti or 2 r290x would be both cheaper and faster and probably consume less power in the nvidia solutions.
You could also likely afford to buy a seperate water cool loop with the 2 780s or 2 r290x setup.
Nice to see these cards made but they are for milionaires as id take the 2 seperate cards over duel gpu any day of the week. My last experience of duel gpu was awful and I wont be going back to it again.
As for 4k gaming this card or 2 of any of the mensioned cards will only satisfy you if you are happy under 60fps I never could be.
Performance wise maxwell should be alot quicker than the current cards and hopefully a more realistic price to boot ( have my douts on this one )
Computer technology in general pricing as gone up alot in recent years.
rollo is online now   Reply With Quote
Old 8th Apr 2014, 15:01   #15
SimoomiZ
Modder
Cryptocurrency mining has been keeping the AMD cards' prices artificially high too. So the Nvidia prices are becoming absurd.
Wonder how much R9 295X2 would be without that watercooling kit? As anyone laying down that sort of cash will probably put their own block on and integrate it into an existing loop.
Old 8th Apr 2014, 15:20   #16
Dogbert666
bit-tech Staff
Dogbert666's Avatar
Seems that way, though I doubt that actually means anything.
Old 8th Apr 2014, 15:27   #17
Bloody_Pete
Technophile(and yes, thats 724Mb/s)
Bloody_Pete's Avatar
Bloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming Saiyan
Did the article just vanish for anyone else?
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Asus 780 Posiedon Platinium, 512GB Crucial Mx1000, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W.
Bloody_Pete is offline   Reply With Quote
Old 8th Apr 2014, 15:43   #18
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
Good performance for what it is and decent temps.
Still cannot think of anything else to say other than Meh!
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 8th Apr 2014, 16:00   #19
Otis1337
aka - Ripp3r
Otis1337's Avatar
Otis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming Saiyan
reminds me of old school cards with the red transparent fans
__________________
Haswell killer - Long live x58
KFA2 GTX 970 OC Infin8 Black::Xeon X5650 Hex @ 4Ghz::H110i GT::Asus P6T SE x58::Patriot Tri DDR3 12GB
CoolerMaster 850W RealPower::Phanteks Enthoo EVOLV::Sammy F3 1TB::OCZ SSD 2x120GB::Asus Xonar - HyperX Cloud
Otis1337 is offline   Reply With Quote
Old 8th Apr 2014, 16:25   #20
Dogbert666
bit-tech Staff
Dogbert666's Avatar
The actual GPU temperature is probably closer to 70 degrees, though compared to even a single R9 290X that's pretty damn good, and as I said I didn't see the card throttling.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
