Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th Apr 2014, 09:04   #1
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
Do case manufacturers really understand water cooling?
Antony questions whether case manufacturers are really taking water cooling seriously, or just doing the minimum to meet check-list criteria...
http://www.bit-tech.net/blog/2014/04...nderstand-wat/
Dogbert666 is offline   Reply With Quote
Old 10th Apr 2014, 09:36   #2
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
Dude can't cool an overclocked Core i5-3570K and GeForce 660 Ti on a dual 120 rad? That's only 230W-ish, tops. He's doing something wrong. I'm cooling 240W on a single BIX.
Anyway, it is pretty difficult to create a case for PC components that were designed to be in a strict particular orientation towards each other and the case, and still have room for a decent watercooling system, without ending up with a huge monster case that ate Detroit.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is offline   Reply With Quote
Old 10th Apr 2014, 10:02   #3
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Didn't say it couldn't cool it just that I had to have the fans at 12v to cope with lengthy gaming sessions - I usually like to have them between 5 and 7v otherwise the fans are by far the noisiest components in the PC.
I don't think it is that difficult. As I mentioned, many cases we've reviewed recently just needed minor changes like making the case a tad wider or really maximising the fan mount clearance. The PC-V360 is a classic example.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 10th Apr 2014, 10:02   #4
ev1lm1nd666
Multimodder
ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!
I have to disagree, If water cooling was a major consideration at the earliest design points of a case then it should be relatively easy, we just need the "big" names in cases to pull their fingers out as water cooling isn't going away.
It took years for case manufacturers to realise we didn't want plain beige boxes for our pc'sand they don't seem to be paying too much attention even now with all-in-one coolers.
All a case manufacturer has to do is look in the modding forums at what people are doing to their cases to fit water cooling to get the idea and convert it into a real case design.
I'd love to have the money to start up a small case company as I reckon the designs I have penned up til now would sell very well for water cooler users.
__________________
AMD FX 4100 @ 4.6Ghz, ASUS M5A97 PRO, EVGA GTX 560 Ti @1Ghz 2200Mhz Mem, 8Gb Corsair Dominator DDR3 1600, Corsair CX600 PSU, Antec 300 Case, Samsung Multyi DVD Drive
ev1lm1nd666 is offline   Reply With Quote
Old 10th Apr 2014, 10:07   #5
Nexxo
Whatever's Geek.
Nexxo's Avatar
Talk to Partum systems. They work in acrylic, but their equipment should manage 3mm aluminium. About time they branch out their range a bit.
__________________
Old 10th Apr 2014, 10:07   #6
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
I'd definitely like to see some more considerations being made for reservoirs. I think a lot of the time now, even mid-towers are capable of putting in so much radiator, that you don't need thick ones. The H440 can fit 2x360mm rads and the 450D a 360 + 280, and this is using a stock configuration. That's just insane, imagine taking either one of those case back to 2009, people would be gobsmacked. You don't need thick rads if you fill up the space on those.
However, they do have the issue of not having many spots for reservoirs you're right. Phantek's have done a good job of tackling this subject with their Enthoo Primo, as Have Corsair with their 900D, but those are massive cases where finding a space isn't hard.
Still, it's progress. Clearly manufacturers are taking custom loops into account (which is much better than in the past), so I would expect to see these features making their way into cases pretty soon.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: Cheers Luv!
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 10th Apr 2014, 10:11   #7
Gurdeep14
Hypermodder
Gurdeep14's Avatar
Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.
Even the TJ-07 which is a premium case with watercooling in mind required quite a lot of modification from me to fit my loops. The top only accommodates a slim 240mm radiator, I had to get the case modified to fit a slim 360mm radiator to cope with cooling a i7 920 @ 4Ghz, the MOSFETS, motherboard and RAM. The bottom section is reserved for a normal thickness 360mm radiator without much modification (just a radiator mount) to cool the GPUs. I had to completely fabricate a new method to hold the dual D5s and reservoirs within the bottom 3 5.25" bays.
Baring in mind this is a 200+ case, I'd say they still have some work to do.
__________________
Intel Core i7 4790K | EVGA 780 Classified Hydro Copper 3GB | ASUS Maximus VII Hero Z97 | 32GB (4x8GB) 2400Mhz Corsair Vengeance Pro Series Red | Corsair HX1200i | ASUS Xonar D2X | 256GB Samsung 950 Pro M.2 NVMe | 250GB Samsung Evo 840 | 256GB Samsung 830 | 512GB Crucial BX100 | Silverstone TJ-07 | Acer 27" XB271HU (2K 144Hz G-Sync) Here
Gurdeep14 is offline   Reply With Quote
Old 10th Apr 2014, 10:24   #8
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
It doesn't help when the mainstream manufacturers specifically design their cases with only enough room to accommodate AIOs, when they also make AIOs. Yeah, promote your own products, but not at the expense of other options.
I've given up looking at case reviews from a certain manufacturer, because of their bias in this area.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170|32GB|256GB M.2|500GB SSDs|8TB NAS|GTX 980|3007WFP-HC|Parvum S2.0
David is offline   Reply With Quote
Old 10th Apr 2014, 11:44   #9
montymole
Rigid Tubist
montymole's Avatar
montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.montymole is the Cheesecake. Relix smiles down upon them.
have to say i am keeping a 4770k @4.6ghz 1.3v and a R9 280X both well under 50c whilst gaming with an EK XTX 240mm and 2 Enermax Cluster Advance Fans and is pretty much silent this is in and AeroCool Dead Silence case that is not exactly the biggest or greatest at cooling
__________________
Red Candy http://bit.ly/1uKlFtG
Silver Ghost http://bit.ly/1xQTjnq
FB http://bit.ly/MyModdingPage
Hex Gear R40 Black Ice http://bit.ly/1xO6eDJ
montymole is offline   Reply With Quote
Old 10th Apr 2014, 12:03   #10
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
Manufacturers don't even put too much thought into aircooling, so why should their products be any better for watercooling?
The biggest problem with most cases is, that they still have tons of unnecessary 5.1/4" and 3.1/2" trays. Get rid of them and you automatically gain more room for radiators and better airflow.
Put the PSU in the bottom and a single 5.1/4" and two 3.1/2" trays infront at the bottom. That way you've got the whole rest of the front and the whole top for radiators not blocked by anything. Just food for thoughts.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 10th Apr 2014, 12:13   #11
true_gamer
Cheesecake on sale!
true_gamer's Avatar
true_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyan
The TJ07 was an Awesome case for it's time, as water cooling was only really starting to show up.
I had 3 loops in that case back in 2010 with 1x slim 240 rad in the top along with 1x 240 & 1x 360 rad in the bottom.
Clicky
So as the likes of the Corsair 760T case, you can mount a full size 120.3 rad in the roof along with a oversized 120.2 rad in the front without any modifying.
So case manufactures like Corsair are listening to their costumers and accommodating for custom waterloops.
I have some great plans for when my 760T case turns up.
__________________
i5 4670K @ 4GHz - Corsair H100i - MSI Z87-G45 Gaming Mobo - 16GB Hyper X DDR3 2400MHz - SandDisk Ultra 2 120GB SSD - 500GB SSHD - 2x Asus R9 280X DCU2 - Coolermaster 1KW PSU - NZXT Phantom 530 Case - Philips 40" 4K Monitor BDM4065UC
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer
Crysis 3 Ultra Config Crysis 1 ultra Config
true_gamer is offline   Reply With Quote
Old 10th Apr 2014, 12:14   #12
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
Water cooling is complicated and over the years ive resorted to wierd case mods to get the stuff inside and outside of the case. My current setup has the 360 rad outside of the case with the fans on 5v.
It can fit inside the case but the problem then becomes higher fan speed requirements for the same temperature.
And thats with a case designed for water cooling the NZXT Phantom that you reviewed a few years back.
PSU in bottom is how the phantom does it and theres still not alot of room unless your removing drive bays and hd spacers. Niether is really that realistic for most users.
rollo is offline   Reply With Quote
Old 10th Apr 2014, 13:08   #13
Gurdeep14
Hypermodder
Gurdeep14's Avatar
Clicky
Nice, I went for a 360 in the rood and a 360 in the bottom, because I wanted some space at the bottom for cables and to mount the pumps and reservoirs
Clicky
__________________
Old 10th Apr 2014, 13:10   #14
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
Parvum innit.
__________________
6700K | Z170I | Liqtech 120X | EVGA GTX 980Ti SC | 16GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 10th Apr 2014, 13:16   #15
M3G4
talkie walkie
M3G4's Avatar
M3G4 has yet to learn the way of the Dremel
I personally don't understand watercooling. What with the lower TDP of CPU's and most other components the need for it is becoming moot, unless you're a major overclocker.
__________________
Apple iMac | 2.5GHz i5, 500GB HDD, 4GB RAM, BT & 802.11n, Superdrive, 21.5" tft, MacOS 10.7
Twitter / Flickr / Facebook
M3G4 is offline   Reply With Quote
Old 10th Apr 2014, 13:29   #16
Maki role
Maki role's Avatar
Thing is, watercooling is about much more than overclocking. Air cooling is for the most part very much a "black box" solution, you can't really put your own stamp on it as much. Sure you can add shrouds, change fans etc. but your options are very limited. Watercooling on the other hand offers a huge amount of freedom. You can express so much simply through how you choose to use it. It can also be a fun challenge to try and see just how far you can take it. It's basically a full on hobby, the Raspberry Pi doesn't even need a cooler, didn't stop Phame from watercooling one for the hell of it.
Not to mention that whilst the TDPs on many/most parts are indeed going down, there are still notable exceptions. Top end GPUs are still power hungry beasts, Intel's Sandy/Ivy-e chips are also very power hungry, especially when overclocked. AMD's latest CPU offerings have 220W TDPs, with their normal versions still clocking in at 130W. That's a lot of heat for any air cooler, even the very best. Start overclocking even a reasonable amount and you'll find the fans spinning up a lot.
__________________
Old 10th Apr 2014, 13:49   #17
Shirty
Moderator
Shirty's Avatar
Ill just leave this here.
I strongly urge you to have a good read of that thread from start to finish, because chap made a number of valid points huehuehue.
__________________
Old 10th Apr 2014, 13:55   #18
David
RIP Tel
David's Avatar
One thing, and most important to me, about watercooling - you can add enough rad to a loop to keep your rig cool even for extended gaming/benching sessions without any increase in fan speed or noise output.
I've stripped and sold off my loops twice now, but I still keep coming back. I'm not going to say it's for everyone, and I'm not going to pretend that it's essential but, for me at least, it is worth it.
__________________
Old 10th Apr 2014, 13:57   #19
David
RIP Tel
David's Avatar
**SLAP**
That asshat doesn't need the coverage or encouragement, Nick.
__________________
Old 10th Apr 2014, 14:02   #20
Shirty
Moderator
Shirty's Avatar
I have a theory that chap (who recently returned after an 18 month hiatus with this gem) is actually one of the first sentient computers connected to the internet.
He's not very good at much yet, but he's learning. We should welcome his occasional presence at Bit-tech.
__________________
Reply
Tags
all-in-one, case, corsair, lian li, manufacturer, nzxt, sealed loop, water cooling
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
