Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th Apr 2014, 10:55   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Sony announces The Last of Us Remastered for PS4
Better graphics, bundled DLC.
http://www.bit-tech.net/news/gaming/...st-of-us-ps4/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 10th Apr 2014, 20:44   #2
Instagib
Ultramodder
Instagib's Avatar
Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.
So does this mean it's coming out on the PC?
__________________
Silverstone FT04B | Maximus V Extreme | i7 - 3770K @4.6 | 16Gb Corsair Vengeance LP DDR3 1600Mhz | H80i | ASUS GTX 780Ti DCII |Seasonic 660XP2
Silverstone TJ07|Rampage 3 Extreme | X5650 @ 4.2 | 12Gb Corsair DDR3 1600mhz | EVGA GTX680 | Akasa 1000W Powermax | 480 rad; all under water
Instagib is online now   Reply With Quote
Old 10th Apr 2014, 22:42   #3
Mister_Tad
Moderator
Modaretor
Moderator
Mister_Tad's Avatar
Mister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming Saiyan
Why would it?
Mister_Tad is offline   Reply With Quote
Old 10th Apr 2014, 23:18   #4
Instagib
Ultramodder
Instagib's Avatar
Just hoping really. Played it on the ps3 and it was easily one of the best games I have ever played. Period. I was hoping that if they took the time to code it for the PS4, maybe they could tweak it for the PC too? I mean the difference between a PS3 and a PS4 is a ravine when compared to the difference between a PS4 and PC.
Wishful thinking though.
__________________
Old 11th Apr 2014, 08:59   #5
SimoomiZ
Modder
SimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for presidentSimoomiZ should be considered for president
AMD say porting games across from PS4 to PC is easier too.
Can't imagine Sony bringing it to MS Windows though. And a SteamOS release isn't really viable with its small install base
SimoomiZ is offline   Reply With Quote
Old 11th Apr 2014, 09:38   #6
Impatience
Ultramodder
Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.
I'd buy a separate HDD to boot SteamOS onto if it meant I could play games like TLOU! I wouldn't mind swapping out a SATA cable based on which OS I want to use!
Impatience is offline   Reply With Quote
Old 11th Apr 2014, 09:43   #7
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
To be honest I doubt it'll come to PC for same reason why Halo (the new releases that is) won't. It's a console defining top game. I know people who bought PS3s for this game, Sony will want to keep it as a reason to buy a PS4. It's annoying from our end, but it makes sense from a business perspective if it helps to ensure a larger install base for the console.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: Cheers Luv!
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 13th Apr 2014, 14:21   #8
true_gamer
Cheesecake on sale!
true_gamer's Avatar
true_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyan
Too true! - I did this when GTA San Andreas came out on PS2. I couldn't wait around for the Xbox release, so I went out and bought a PS2 just to play it.
__________________
i5 4670K @ 4GHz - Corsair H100i - MSI Z87-G45 Gaming Mobo - 16GB Hyper X DDR3 2400MHz - SandDisk Ultra 2 120GB SSD - 500GB SSHD - 2x Asus R9 280X DCU2 - Coolermaster 1KW PSU - NZXT Phantom 530 Case - Philips 40" 4K Monitor BDM4065UC
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer
Crysis 3 Ultra Config Crysis 1 ultra Config
true_gamer is offline   Reply With Quote
Reply
Tags
console gaming, naughty dog, playstation, playstation 3, playstation 4, post-apocalyptic, ps3, ps4, sony, the last of us, the last of us remastered, third person shooter, tps
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
