Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 11th Apr 2014, 14:02   #1
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Corsair unleashes a rather good sub 40 enthusiast case
Matt takes a look at Corsair's new wallet-friendly Spec-01
http://www.bit-tech.net/hardware/cas...ec-01-review/1
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 11th Apr 2014, 14:10   #2
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
I know it's been said before, and your reasons for not doing so are well documented, but would it really be that hard just to find a generic 120mm fan just to show how much the case can be improved from stock for a couple of quid extra?
This looks like a great budget choice, and would likely perform infinitely better with either one additional fan, or as you allude to removing the intake and using it as an exhaust... about a minute's work.
I'm sure it was an article on bit or maybe in CPC not that many years ago which proved that one exhaust is far more effective than even several intakes, as it creates negative pressure in the rest of the case forcing it to pull in cold air through any orifice. Whereas an intake will create positive pressure, and the air will try to escape from the nearest orifice, meaning that a proportion of the cold, fresh air will be exhausted before it even meets a component.
__________________
3770K | Z77E-ITX | Liqtech 120X | EVGA GTX 980Ti SC | 8GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 11th Apr 2014, 14:42   #3
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
The trouble is that if we do it for one then it's unfair not to do it for the others - almost every case can have its cooling improved by adding more fans, and it introduces a lot of variables too. Perhaps we could do it in special instances such as this one, where cooling is a letdown in an otherwise good case and there appears to be an easy fix? I'm not sure. That said, as we move into the post-Dennis era there's a lot of re-evaluation going on about our test gear and methods, so it may be something we can include in the future - we'll certainly keep it in mind
Dogbert666 is offline   Reply With Quote
Old 11th Apr 2014, 14:45   #4
Dogbert666
bit-tech Staff
Dogbert666's Avatar
Also, you may be thinking of this article? http://www.bit-tech.net/hardware/201...nvestigation/1
The benefit of having data such as that, as well as data from other cases with good exhaust set-ups, for example, is that it lends weight to our arguments that adding a fan/moving the existing one here to the exhaust position would be very beneficial, without us having to actually run an extra test. Of course, no case is the same, and there are always going to be additional variables, but we don't say such things based on guess work.
Old 11th Apr 2014, 14:46   #5
Shirty
Moderator
Shirty's Avatar
I think if a case only includes a single intake fan then it's at least worth moving it to the exhaust mount to see if that helps, would you agree?
I'm totally with you on the aspect of fairness, but the fan is a modular part of the case so you could argue that moving it is akin to removing a drive cage or similar.
And yes, that was the article - a very good article it was too
__________________
Old 11th Apr 2014, 15:15   #6
lilgoth89
Captin Calliope
lilgoth89's Avatar
lilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyan
i would personally love to see all cases tested with all their fan slots filled with decent but generic fans ( sickleflows for instance ) to show the POTENTIAL cooling of the case as well
you take all the time to install the hardware and test, how hard would a set of fans be to install ? granted it would take another set of testing, but how many of us really buy these cases then leave them stock ?
although saying that i do understand the reasons to test the out of box performance first and foremost. However especially at this end of the market, there is alot of potential that you fail to show
__________________
I7 3770 @ 4.5Ghz | Asrock z77 extreme 6 | 16gb hyper X Ram 1600 | SfX7870 oc |Crucial 512 gb M4 | Samsung Spin point 2tb x2 | SiverStone Raven02 | Corsair Hx 850
lilgoth89 is offline   Reply With Quote
Old 11th Apr 2014, 15:34   #7
tonyd223
king of nothing
tonyd223 has yet to learn the way of the Dremel
Good fans cost money - you take a cheap case with 1x120mm fan, you add 2-3 other 120mm fans and price wise you're into better cases with more features, or worse, more included fans!
tonyd223 is offline   Reply With Quote
Old 11th Apr 2014, 15:52   #8
Shirty
Moderator
Shirty's Avatar
Very true, but a single intake fan is substantially inferior to a single exhaust - and both configurations are options on this case without spending a penny extra
__________________
Old 11th Apr 2014, 16:12   #9
CrapBag
I Mod, Therefore I Own
CrapBag's Avatar
CrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming Saiyan
I would expect at least a standard setup be used for each case which would mean it should at least have 1 intake and 1 exhaust even if they need to be added. Can always be reflected in the price.
Also it's not a bad case even though it has banes breathing apparatus stuck to the front
CrapBag is offline   Reply With Quote
Old 11th Apr 2014, 16:31   #10
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
Is BT going to review the NZXT 440 any time soon?
Hustler is offline   Reply With Quote
Old 11th Apr 2014, 17:11   #11
Dogbert666
bit-tech Staff
Dogbert666's Avatar
We have requested it a lot. We really want to but stock seems to be an issue. I'll chase again.
Old 11th Apr 2014, 17:11   #12
tonyd223
king of nothing
+1
Old 12th Apr 2014, 00:19   #13
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
Hmm, looks like a tarted up Inwin Mana 137.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170i Pro|16GB|256GB M.2|500GB SSD|GTX 980|3007WFP-HC|Hadron Air
David is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
