Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 16th Apr 2014, 10:27   #1
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Antec Kühler H20 650 Review
We take a look at Antec's budget all-in-one liquid cooler - the Kühler H20 650
http://www.bit-tech.net/hardware/coo...0-650-review/1
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 16th Apr 2014, 12:40   #2
JCBeastie
Supermodder
JCBeastie's Avatar
JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.JCBeastie is the Cheesecake. Relix smiles down upon them.
Wouldn't touch it with a barge-pole. What happens when the fan fails? I've had several new fans on CPU heatsinks, graphics cards and cases fail in the first few months; I'd want to be able to easily replace them. This thing is so integrated you'd have to return the whole unit. Sure you could add a fan behind it but that's not likely to perform well.
JCBeastie is offline   Reply With Quote
Old 16th Apr 2014, 14:07   #3
Sim0n
rm -rf /
Sim0n's Avatar
Sim0n has yet to learn the way of the Dremel
JCBeastie, more importantly, the fan motor is the pump motor in this case. So if the fan stops, the fluid movement also stops.
With no "software control", theres nothing to TELL you the fan/pump has broke, other than when your PC shutdown because the CPU is boiling away with no active cooling.
Worrying, surely ?
Sim0n is offline   Reply With Quote
Old 17th Apr 2014, 13:23   #4
biojellywobbles
Supermodder
biojellywobbles's Avatar
biojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyan
Surely it's only as worrying as if the fan stops on an air cooler? Modern CPUs are not really harmed by overheating any more as they will throttle or shutdown in the event that things get a bit too hot.
__________________
Main box: i5 4690K @4.5GHz, Corsair H80, 8GB Value RAM, Powercolor 280X with Kuhler 620 on G10 Bracket, OCZ ARC100 240GB, 2x500GB Seagate Barracuda, Silverstone PS07, Win7
biojellywobbles is offline   Reply With Quote
Old 31st Dec 2014, 14:46   #5
StaticFX
Minimodder
StaticFX has yet to learn the way of the Dremel
just an FYI - the Fan motor is NOT the pump motor. I have pulled it all apart and managed to change the fan.. have not had the chance to try it out yet.. hoping noise will be better. I could just plug the fan into the MB for better control if I want
StaticFX is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
