Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 18th Apr 2014, 08:07   #1
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
Alphacool to 3D-scan GPUs to make waterblocks for non-reference cards
You can send yours in and receive a free waterblock for your troubles. This is all kinds of awesome!
http://www.bit-tech.net/news/hardwar...ke-waterbloc/1
Dogbert666 is offline   Reply With Quote
Old 18th Apr 2014, 10:49   #2
daletur328
Minimodder
daletur328 has yet to learn the way of the Dremel
Great idea, would have loved this service with my card, just a pity it's 6xx series GeForce. Would be good to see a review of the temps.
daletur328 is offline   Reply With Quote
Old 18th Apr 2014, 11:55   #3
theshadow2001
[DELETE] means [DELETE]
theshadow2001's Avatar
theshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyan
It's cool and offers choice where there was none. Which is great. But chances are it'll be expensive due to the small job lot production runs of the non generic elements.
theshadow2001 is offline   Reply With Quote
Old 18th Apr 2014, 14:23   #4
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
Definitely an interesting idea, but I'm sure the service will be pricey.
Makes me wonder how much an advanced 3D scanner was necessary. For example, I wonder if you could get the same results using a regular photo scanner. The way this works is you measure distance of the components based on how blurry they are, and maybe use brightness too as an aiding factor. This obviously isn't going to be as accurate, but you don't need 100% precision for a heatsink. You just need to make sure it's tightly and fully pressed against the GPU die and that it doesn't hit any of the other components. Also, from a user perspective, this approach is more difficult and requires more manual intervention. Personally, I'd rather spend $50 on a photo scanner than a multi-hundred (possibly multi-thousand) dollar 3D scanner that scans a device that is largely 2-dimensional.
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Old 18th Apr 2014, 16:55   #5
SMIFFYDUDE
Supermodders on my D
SMIFFYDUDE's Avatar
SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.
Why do customers have to send their cards in, why can't Alphacool just get hold of the cards for themselves and save people the hassle?
__________________
i7 6700K|Sabertooth Z170 S|16GB Crosair Dominator Platinum 3200MHz|KFA2 GTX 1080 HOF|Creative Sound Blaster ZxR|Super Flower Leadex Gold 850W|Raijintek Triton|Corsair 780T|HP LP2475w|Speedlink Medusa 5.1|CM Storm Inferno|Windows 10
Steam: SMIFFY
SMIFFYDUDE is offline   Reply With Quote
Old 18th Apr 2014, 16:58   #6
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Maybe not too pricey, It looks like they have a stock heatsink they can slap in a mill with little setup.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 18th Apr 2014, 17:21   #7
theshadow2001
I think the reason for sending the cards in and the laser scanner is to get various part samples across numerous batches. This would allow them to measure the variances in the cards production and ensure the blocks they produce would work correctly across all cards.
Old 18th Apr 2014, 17:40   #8
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
There won't be any costs afaik - if the card isn't in their database and they deem your model worthy of adding to it, then it's free and you get a block for your trouble - very little hassle in that tbh so long as they return your card in a reasonable time.
It's also highly impractical to get hold of every non-reference card for every generation - literally dozens - no block manufacturer has managed it yet and asking for cards to scan isn't new either - EK has done it in the past, albeit maybe not with 3D scanning. This way both Alphacool and the end user benefit - the end user with a free block for their card if it hasn't been scanned already, and Alphacool gets to build its database of cards so it can cater for as many models as possible.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 19th Apr 2014, 00:22   #9
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
If it was reliable to produce an accurate 3D scan from a 2D photograph using nothing but DOF... everyone would be doing it. If you're going to add it lots of processing and dynamic light sources for shadow mapping then you're just building an inaccurate 3D scanner using less than optimal techniques.
3D scanning has been pretty much sorted now. Hacked solutions are no longer required.
Guinevere is offline   Reply With Quote
Old 19th Apr 2014, 00:48   #10
true_gamer
Cheesecake on sale!
true_gamer's Avatar
true_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyan
I like it! - The design is pretty slick too! Think this will be in my next build...
__________________
i5 4670K @ 4GHz - Corsair H100i - MSI Z87-G45 Gaming Mobo - 16GB Hyper X DDR3 2400MHz - SandDisk Ultra 2 120GB SSD - 500GB SSHD - 2x Asus R9 280X DCU2 - Coolermaster 1KW PSU - NZXT Phantom 530 Case - Philips 40" 4K Monitor BDM4065UC
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer
Crysis 3 Ultra Config Crysis 1 ultra Config
true_gamer is offline   Reply With Quote
Old 19th Apr 2014, 09:00   #11
law99
Custom User Title
law99's Avatar
law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.
This is a great idea. If you can choose any card you want, the premium of using this service would be well worth the extra paid.
__________________
3570k WC @ 4.7giggles | 8gb Kingston 2133mhz | ASUS Sabertooth Z77 | soaking 1070 gtx | Seasonic x-660w | NZXT 810 switch | Crucial M4 128gb | 2x F3 1tb Raid 1 | NZXT Sentry 6ch 50w fan controller | BenQ bl3200pt 2560x1440p
law99 is offline   Reply With Quote
Old 19th Apr 2014, 17:25   #12
Dogbert666
bit-tech Staff
Dogbert666's Avatar
Awesome - knew we could rely on you
Old 19th Apr 2014, 18:11   #13
ksyruz
What's a Dremel?
ksyruz has yet to learn the way of the Dremel
Seems cool and all, but most non-reference cards (Asus DCU ii, EVGA, MSI Lighning, KFA2/Galaxy hof, and Gigabyte) get waterblocks by one of the brands, especially EK waterblocks who do all of them in full cover.
ksyruz is offline   Reply With Quote
Old 19th Apr 2014, 19:22   #14
craig - toyoracer
Supermodder
craig - toyoracer's Avatar
craig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysis
At last we can now WC Quadro-Firepro cards, so a good option.
__________________
octTower
Electrocutous Orchid
craig - toyoracer is offline   Reply With Quote
Old 20th Apr 2014, 17:18   #15
true_gamer
Cheesecake on sale!
true_gamer's Avatar
Of course! - Just wish the next gen hardware would hurry up so I can start a build log.
__________________
Old 20th Apr 2014, 17:49   #16
Apoptosis
Modder
Apoptosis has yet to learn the way of the Dremel
This is a good idea - I've been meaning to buy a GTX 780 for a water-cooled build but reference PCB's seem to be few and far between.
Apoptosis is offline   Reply With Quote
Old 27th Apr 2014, 22:34   #17
Star*Dagger
Banned
Star*Dagger has yet to learn the way of the Dremel
Not sure I would be comfortable with only 2 cards in my system. And I do my best to keep them in there and watercooled and not moved until the next 9 month upgrade cycle.
S*D
Star*Dagger is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
