Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 29th Apr 2014, 09:41   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Kingston announces HyperX Cloud headset
Takes the brand to new places.
http://www.bit-tech.net/news/hardwar...hyperx-cloud/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 29th Apr 2014, 10:32   #2
Fizzban
Man of Many Typos
Fizzban's Avatar
Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.
Diversifying their product range seems like a good call, so long as they make decent products anyway.
__________________
-Banana in disc drive error-
To win the battle, is to be prepared to die - Miyamoto Musashi
Originally Posted by RedFlames View Post
Asking to pick between the main parties is like asking which testicle you want to be kicked in, you're gonna get kicked the nuts whoever you pick... Just have to hope whoever you pick aren't wearing steelies...
Fizzban is offline   Reply With Quote
Old 29th Apr 2014, 12:10   #3
Corky42
I Mod, Therefore I Own
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
Was it just me that groaned when i read about a Cloud headset, only to discover it's got nothing to do with the cloud, or does it store something in the cloud ? talk about confusing
Corky42 is offline   Reply With Quote
Old 29th Apr 2014, 13:30   #4
forum_user
forum_title
forum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyanforum_user is a Super Spamming Saiyan
I rolled my eyes Corky. I immediately decided it would be a no-buy, and if it was truly cloud related then it would be a liability with regards security. They need to ditch the 'cloud', as everyone should.
forum_user is offline   Reply With Quote
Old 29th Apr 2014, 13:48   #5
Gareth Halfacree
WIIGII!
bit-tech Staff
It just plugs in with a pair of 3.5mm plugs; the 'Cloud' moniker refers to the soft, floaty memory-foam earcups, nothing to do with server-side software!
__________________
Old 29th Apr 2014, 13:55   #6
Impatience
Ultramodder
Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.
Now that I know that these aren't actually cloud related (apart from name), it makes me wonder how you could actually have cloud headsets? You could potentially fit a little raspberry pi-type device in them and play soundcloud tracks etc.. If it wasn't for the security, that could be a lot of fun!
Impatience is offline   Reply With Quote
Old 29th Apr 2014, 15:08   #7
Corky42
@Gareth, That make more sense, thanks. Although it does make me wounder how many people will make the same mistake as me (unless I'm being dense that is)
Are some people going to see the 'Cloud' moniker and think security risk and dismiss them offhand without giving them a second look, while others that think a Cloud related headset would be cool dismiss them once they find out they don't come with server-side functions.
Seem a little like a marketing boo boo, maybe they should have called them something like the
HyperX Mr. Stay Puft headset
Old 29th Apr 2014, 17:57   #8
wafflesomd
I *am* a Dremel
wafflesomd's Avatar
wafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysis
"Was it just me that groaned when i read about a Cloud headset, only to discover it's got nothing to do with the cloud, or does it store something in the cloud ? talk about confusing :?"
Ermmmm..... It's only confusing if you associate the word cloud with cloud computing.
Anyways, I really want to try these. The build quality appears to be top notch, reminds me a couple beyerdynamic cans. The headset market really needs something good that is affordable. I'm really tired of people buying these bulky hunks of plastic that razor/astro/trittan try to pass off as headphones. I've yet to try anything from them that didn't feel like cheap, bulky, and sound terrible.
wafflesomd is offline   Reply With Quote
Old 29th Apr 2014, 18:09   #9
Corky42
When talking about computers don't most people associate the word cloud with cloud computing, the first few pages in Google tend to associate it with that.
Quote button
Old 30th Apr 2014, 02:28   #10
Woodspoon
Supermodder
Woodspoon's Avatar
Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.
Nope not just you, I think the marketing department was probably let loose with their book of buzzwords.
Woodspoon is offline   Reply With Quote
Old 30th Apr 2014, 11:40   #11
Gareth Halfacree
WIIGII!
bit-tech Staff
If anyone's interested in buying one, I've just had an email from Kingston saying that the UK RRP - which wasn't in the original press release - will be 89.99. With pre-order prices averaging at around 70, that means buying now will save a not-inconsiderable chunk of change. Cheapest I've found is Saverstore at 65.60 plus delivery.
__________________
Old 30th Apr 2014, 20:44   #12
Cthippo
Can't mod my way out of a paper bag
Cthippo's Avatar
Cthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming Saiyan
THIS!
It's usually good if a product's name tells you what the product is. I associate the HyperX brand with memory, and cloud with servers, so my initial thought was that this was some new server memory. Clearly I'm not the only one having this problem.
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade.
Cthippo is offline   Reply With Quote
Reply
Tags
gaming headset, headphones, headset, hyperx, hyperx cloud, kingston, microphone
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
