Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 30th Apr 2014, 09:56   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Research warns of graphene's environmental impact
Particles highly mobile in surface water.
http://www.bit-tech.net/news/bits/20...-environment/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 30th Apr 2014, 10:03   #2
Dave Lister
Hypermodder
Dave Lister's Avatar
Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!
Interesting, so they need to start running tests to see how it will effect living organisms before any widespread use in electronics. Somehow I don't see that happening, there is no money to be made in being responsible !
__________________
Main Rig:Case: BitFenix Prodigy, Motherboard: MSI Z97I Gaming, CPU: Intel i7 4790K, RAM: 16Gb 2400Mhz Kingston HyperX Beast GPU: MSI GTX 970 Gaming, Primary HDD: 256Gb Samsung 850 Pro, Games Drive: 2Tb 2.5" Toshiba HDD, Cooler: Corsair H105, OS: Win 7 - 64
Dave Lister is offline   Reply With Quote
Old 30th Apr 2014, 10:30   #3
Spraduke
Lurker
Spraduke is the Cheesecake. Relix smiles down upon them.Spraduke is the Cheesecake. Relix smiles down upon them.Spraduke is the Cheesecake. Relix smiles down upon them.Spraduke is the Cheesecake. Relix smiles down upon them.Spraduke is the Cheesecake. Relix smiles down upon them.Spraduke is the Cheesecake. Relix smiles down upon them.Spraduke is the Cheesecake. Relix smiles down upon them.Spraduke is the Cheesecake. Relix smiles down upon them.Spraduke is the Cheesecake. Relix smiles down upon them.Spraduke is the Cheesecake. Relix smiles down upon them.Spraduke is the Cheesecake. Relix smiles down upon them.
I'm failing to see how what is 100% carbon which has oxidised can be toxic to any carbon based life form, it might be possible for it to cause some other affect, suffocation perhaps but toxic? Unlikely.
Spraduke is offline   Reply With Quote
Old 30th Apr 2014, 10:33   #4
Gareth Halfacree
WIIGII!
bit-tech Staff
It's not the material itself, but its construction: graphene [allegedly] suffers from what is known as nanotoxicity. Try this paper from January for a detailed explanation.
Think of it like this: I could easily eat a chunk of asbestos with little ill-effect, but if small particles of it get airborne and I breathe 'em in then I'm in serious trouble.
__________________
Old 30th Apr 2014, 10:35   #5
Fused
Multimodder
Fused's Avatar
Fused can run CrysisFused can run CrysisFused can run CrysisFused can run CrysisFused can run CrysisFused can run CrysisFused can run CrysisFused can run CrysisFused can run CrysisFused can run CrysisFused can run Crysis
It could pay to invest in research into its environmental impacts ahead of its wide scale use in case it is found to have some particularly damaging properties to the environment or human health which might affect how company mass produces and disposes of future devices. Could save them in the long run to know about these things in advance. Environmental disaster fines are something I would hope most companies are looking to avoid (by putting in correct safety and disposal procedures not by avoiding blame or prior knowledge)
Either way I think there is sometime before (even if) we see graphene make it into mass production. I am sure governments are willing to fund these kind of research projects as its easy to see what the potential benefit to society might be
__________________
Canon 50D
Fused is offline   Reply With Quote
Old 30th Apr 2014, 10:45   #6
Fused
Multimodder
Fused's Avatar
There are plenty oxides of carbon which are toxic (Carbon monoxide for example) which I guess would suffocate you but by the time it got to that concentration the toxic effect it has on your blood has already killed you. Anyway..
I think Gareth has pretty much got it. I could also see that small enough fragments of graphene or graphene oxide once inside you could interact with biomolecules in all sorts of ways, some of which could be toxic, it just isnt known.
__________________
Canon 50D
Old 30th Apr 2014, 11:32   #7
Spraduke
Lurker
Fair points, obviously carbon monoxide needs to be inhaled and I was primarily thinking ingestion / absorption by plant life. Scientific discovery is full of unexpected side effects (CFC's etc.) so it definitely pays to find out these things before the disaster!
Old 30th Apr 2014, 17:57   #8
Alecto
Multimodder
Alecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the Dremel
Anything made of carbon (say coal or charcoal for example) that has been oxidized to the monoxide form (CO) kills quite a number of people each year.
Alecto is offline   Reply With Quote
Old 30th Apr 2014, 21:57   #9
Gambler FEX online
Minimodder
Gambler FEX online has yet to learn the way of the Dremel
They use microsilver in toothpaste these days and it might have a bad effect on beneficial bacteria in nature.
Gambler FEX online is offline   Reply With Quote
Old 1st May 2014, 07:52   #10
Corky42
I Mod, Therefore I Own
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
We have use all sorts of things that have caused harm in the past, like lead in petrol that made us all go a bit loopy, or radium in toothpaste, and how about when women ate arsenic to improve their complexion.
At least we are learning from past mistakes and researching the potential harm that could be done before wide spread use.
Corky42 is offline   Reply With Quote
Old 1st May 2014, 10:36   #11
benji2412
Has an Avatar avatar
benji2412's Avatar
benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.
Don't forget the barium suppositories!
__________________
Compy Mark V
Intel Core i5 2500K // ASUS P8P67 Pro // 8GB DDR3 Cosair XMS // ASUS GTX580 DirectCU II // Antec 750W // Antec 1200
benji2412 is offline   Reply With Quote
Old 1st May 2014, 13:11   #12
[USRF]Obiwan
I *am* a Dremel
[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.
Well at least they are willing to investigate the impact. Not what they did with the plastic that is killing all live as we speak.
__________________
[USRF]Obiwan is offline   Reply With Quote
Old 1st May 2014, 14:08   #13
DXR_13KE
BananaModder
DXR_13KE's Avatar
DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.
It is as if current tech does not use poisonous stuff.
__________________
Renegade X - Release Date Unveiled
Check it out!!
DXR_13KE is offline   Reply With Quote
Old 1st May 2014, 14:43   #14
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
Exactly. Graphene is negligible in toxicity compared to many other electronic materials. It is also VERY valuable and is used in relatively tiny quantities - I highly doubt it is going to end up polluting water sources in the next 20 years.
But the real point to get across is graphene has far more environmentally positive benefits than detriments. The most harmful thing about true molecular graphene is the processes to make it, which can involve high-power lasers and harsh acids. However, graphene has little to no shelf life and it is AMAZINGLY efficient compared to the materials it replaces. That means it wastes less energy and takes up less materials (and therefore less volume and less mass) to accomplish the same thing as it's counterparts.
In case anyone is wondering, graphene is known to be an INSANE supercapacitor, it can absorb solar energy, and the most mindblowing of all, it can absorb thermal energy. If that doesn't help improve the environment, I don't know what will.
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Old 1st May 2014, 17:41   #15
benji2412
benji2412's Avatar
Originally Posted by schmidtbag View Post
It can absorb solar energy
But doesn't do anything useful with it yet.
__________________
Compy Mark V
Reply
Tags
carbon, environment, graphene, graphene oxide, graphite, jacob lanphere, researcher, researchers, riverside, university, university of california
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
