Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th May 2014, 09:55   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Scythe launches Kaze Master Flat II fan controller
Triples maximum current to 3A per channel.
http://www.bit-tech.net/news/hardwar...ster-flat-ii/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 6th May 2014, 15:06   #2
BD Hopkins
Minimodder
BD Hopkins has yet to learn the way of the Dremel
The body of the original Kaze Master Flat was made entirely out of plastic. Even the sides and front. It looked and felt cheap and flimsy.
This needs to be metal all the way around to get my money. I can't tell from the pictures.
BD Hopkins is offline   Reply With Quote
Old 7th May 2014, 06:16   #3
DrTiCool
Multimodder
DrTiCool has yet to learn the way of the Dremel
Got the original Kaze Master over 5 years now and its still working perfectly. More power output in the new one is a neat feature, even I hadn't any problems of running more fans on single channel.
DrTiCool is offline   Reply With Quote
Reply
Tags
fan controller, kaze master flat ii, scythe, vfd
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
