Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 23rd May 2014, 10:09   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Schenker partners with Gigabyte for new XMG laptops
Gigabyte design, Schenker customisation.
http://www.bit-tech.net/news/hardwar...ker-gigabyte/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 23rd May 2014, 21:24   #2
proxess
Ultramodder
proxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for president
Though I looked at the Schenker laptops, in the end I went with a PC Specialist laptop. They offered more options and a pretty competitive price for what I was getting. In the end though, it's all Clevo chassis.
__________________
Laptop: i7 4930MX @4.0GHz; 4x 8GB Kingston HyperX Impact 1600MHz; Nvidia 980M 8GB; Samsung 840 EVO mSATA 250GB; Ubuntu 16.04 x64 and Windows 10 Pro.
Linux #429448
proxess is offline   Reply With Quote
Old 24th May 2014, 16:33   #3
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Apart from the MSI gaming rigs, I don't know of many options for backlit keyboards on a Laptop. I do a lot of DJing work and that is a must requirement for my next machine.
__________________
SchizoFrog is offline   Reply With Quote
Old 24th May 2014, 18:15   #4
xaser04
Ba Ba Ba BANANA!
xaser04's Avatar
xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.
A large majority of the high end Clevo based laptops have them (at least the P150/170 SM & above anyway).
My PC Specialist Vortex IV (P170SM) does for example.
__________________
Daedalus - Clevo P170SM | i7 4700MQ @ 3.4Ghz | GTX780M 4GB @980/6000 | 16GB DDR3 | 17.3" 1920x1080 |
ZPM "VIVE" Mini - Fractal Node 202 | i7 4770S | GTX1070 | 8GB DDR3 | 4K TV / HTC VIVE |
Consoles / Retro - PS4 Pro | PS4 | Xbox One x2 | Dreamcast x2 (VGA) | WiiU | Retron5 |
xaser04 is offline   Reply With Quote
Old 24th May 2014, 19:09   #5
Zurechial
Elitist
Zurechial's Avatar
Zurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run Crysis
I've had good experiences with Schenker as a company and the XMG laptop I got from them a while ago is solid as a rock. This could be good news for gamers looking to buy whitebooks.
__________________
Main: CM Cosmos II <-> i7 4770k <-> EVGA GTX 780Ti SC <-> Sabertooth Z87 <-> 16GB DDR3 <-> Samsung 840 Pro <-> Crucial M4 <-> Dell U2410 <-> HP ZR24w
Laptop: Core i7 2670QM<-> GTX 570M <-> 8GB DDR3 <-> Crucial M4 <-> XMG P511
Zurechial is offline   Reply With Quote
Reply
Tags
gaming laptop, gigabyte, laptop, robert schenker, schenker, xmg, xmg core
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
