Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 28th May 2014, 10:42   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
AMD Catalyst 14.6 Beta introduces Eyefinity 3
Support for mismatching monitors.
http://www.bit-tech.net/news/bits/20...st-14-6-beta/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 28th May 2014, 11:02   #2
Kovoet
I Mod, Therefore I Own
Kovoet's Avatar
Kovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming Saiyan
Awesome this will good for some people
__________________
MOBO[ Asus Maximus Formula VII ]CPU[I7 4770K]RAM[Corsair Vengeance PRO Red 2133mhz]SSD's[1TB Samsung EVO, 256GB Samsung, 128GB Mushkin, 128 GT Corsair]GPU[EVGA GTX980]PSU[Corsair AX1200i Red Cables]CASE[Corsair 540] Cooler[Corsair H100i]Screen[Dell U2913WM} Perp[Corsair K70, Logitech G502,Belkin razer N52TE,
HyperX Cloud II]
Kovoet is offline   Reply With Quote
Old 28th May 2014, 23:28   #3
Podge4
Oi, whats your game?
Podge4's Avatar
Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.Podge4 is a hoopy frood who really knows where their towel is.
Id like to get into Eyefinity with my Radeon 7870 but whenever i look at adapters that are certified for Eyefinity on Amazon in the reviews nearly all say they don't work.
Im thinking of this cable should i try it
http://www.amazon.co.uk/Accell-B086B...rds=B086B-002B
__________________
AMD FX8350 @4.3ghz, Asus M5A97 EVO R2.0, 8gb Corsair Vengeance
Sapphire Radeon RX 480 Nitro+ OC 8gb, AOC u2879vf 4k,
Kingston SSDNow V300 240gb, Asus Xonar D2, LG BH10LS30 BD-RE, Win 10 Pro x64
Podge4 is offline   Reply With Quote
Old 30th May 2014, 14:52   #4
Chris_Waddle
Trying hard not to upgrade again
Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.Chris_Waddle is definitely a rep cheat.
I don't think that adaptor will work. It needs to be an active convertor such as this one
Some monitors such as one of the BenQ's that I have (XL2420t), don't require the need for an active convertor as it's already built in.
I'm going to give these drivers a try this weekend. Hopefully I will be able to run Watch Dogs at a bevel adjusted 5760x1080. I like the sound of the improvements that they have made.
Chris_Waddle is offline   Reply With Quote
Old 30th May 2014, 23:43   #5
Podge4
Podge4's Avatar
Nice CW, I'll see about ordering one soon
__________________
Old 31st May 2014, 11:43   #6
Fizzl
Multimodder
Fizzl has yet to learn the way of the Dremel
2560 1440 as the main screen + a 1440 x 900 rotated 90 degrees either side. Would need to find a combination that lines up without too much bezel.
I've always found 3 * 1920 x 1080 slightly too wide so it might be worth the hunt.
Fizzl is offline   Reply With Quote
Old 2nd Jun 2014, 19:24   #7
heir flick
Ultramodder
heir flick's Avatar
heir flick should be considered for presidentheir flick should be considered for presidentheir flick should be considered for presidentheir flick should be considered for presidentheir flick should be considered for presidentheir flick should be considered for presidentheir flick should be considered for presidentheir flick should be considered for presidentheir flick should be considered for presidentheir flick should be considered for presidentheir flick should be considered for president
Does the new eyefinity drivers now suoport portrait landscape portrait
heir flick is offline   Reply With Quote
Reply
Tags
am1, amd, beta, catalyst, catalyst 14.6, driver, eyefinity, eyefinity 3, jpeg acceleration, mantle, multi-display, multi-monitor, thief, watch dogs
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
