Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 3rd Jun 2014, 11:08   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
VESA unveils new DockPort standard
Merges DisplayPort and USB 3.1.
http://www.bit-tech.net/news/hardwar...esa-dockport/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 3rd Jun 2014, 12:02   #2
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
Sounds good but i don't think this will come into its own until DP 1.3, isn't DP 1.2 limited in maximum resolution ? So people plugging in a mobile device may not be able to take advantage of higher resolution displays, like a 4k monitor.
Corky42 is offline   Reply With Quote
Old 3rd Jun 2014, 14:28   #3
debs3759
Was that a warranty I just broke?
debs3759's Avatar
debs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyan
Current generation graphics cards all specify a maximum resolution of 4096 x 2160 @ 60 Hz over DisplayPort 1.2.
DP 1.3, when GPU manufacturers start to support it, will enable 8K displays, or a maximum of 81924320
__________________
HeatWare
debs3759 is offline   Reply With Quote
Old 3rd Jun 2014, 15:05   #4
Corky42
Forgive me if I've got this wrong, 4K is 3840 x 2160 yes ? so at present DP 1.2 supports 4K.
Would (I'm guessing) using some of the wires in a DP cable to carry USB and power reduce the maximum resolution a DockPort could display ?
Old 3rd Jun 2014, 15:27   #5
azazel1024
Supermodder
azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.
I need to read in to this more, but I don't think the author is mentioning the limitation. Dock Port, or at least last I read on it a couple of months ago only supports USB3.1 if it is NOT also carrying full video. If you are pushing something like 4k over it, I think it only supports something like USB2. Not even USB3.0.
Its very bandwidth constrained compared to Thunderbolt. I mean, it IS a nice step forward, but it doesn't really compete. Not really.
__________________
Core 2 Duo E7500, MSI P43-C51, 2x2GB G.Skill Eco DDR3 1600 Cas 7, OCZ Vertex 60GB, Vertex 30GB, Samsung F3 500GB, Samsung F4 2TB, Powercolor Go Green ATI 5570
azazel1024 is offline   Reply With Quote
Old 3rd Jun 2014, 15:33   #6
Gareth Halfacree
WIIGII!
bit-tech Staff
'The author' didn't mention it 'cos 'the author' hasn't heard anything of the sort - and can't find anything in previous write-ups or official documentation, either. Got a source on that claim?
EDIT: The closest I've found is a comment on AndandTech's write-up of the same press release, claiming "The problem with Dockport is that in it's current iteration you're limited to 2560x1600@24bit/60Hz with Displayport 1.2 + USB 3.x" - but again with no citation.
__________________
Old 3rd Jun 2014, 16:36   #7
Corky42
Sorry i wasn't meaning to start an argument
I only asked because i was curious if DockPort comes at the expense of a lower maximum resolution, making it (maybe) not as useful for mobile devices until DP 1.3 increases the available bandwidth.
By the sounds of it the technical details are a little thin on the ground at this early stage.
Old 5th Jun 2014, 17:57   #8
[-Stash-]
Multimodder
[-Stash-] has yet to learn the way of the Dremel
Please. Either DockPort gets some serious traction, or Intel improves (and makes massively cheaper) Thunderbolt. Either way I'm happy. Laptops/tablets/phones need this. It will also make desktops a lot neater I'd love to have 34k screens with a USB3 hub coming (with power) from a single cable from the case, that would rock.
[-Stash-] is offline   Reply With Quote
Reply
Tags
amd, displayport, dockport, usb, usb 3.1, vesa
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
