Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 5th Jun 2014, 09:00   #1
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Sapphire Radeon R9 290 Vapor-X OC Review
http://www.bit-tech.net/hardware/gra...-x-oc-review/1
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 5th Jun 2014, 15:54   #2
PCBuilderSven
Multimodder
PCBuilderSven has yet to learn the way of the Dremel
Surely comparing this to the stock/asus 290 (and all the other radeons for that matter) is a bit unfair when they're tested with catalyst 13.12 and this with 14.4, you have no idea if the difference is due to it being a better card or due to driver optimization.
PCBuilderSven is offline   Reply With Quote
Old 6th Jun 2014, 03:57   #3
LordPyrinc
Legomaniac
LordPyrinc's Avatar
LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.
Thanks for the 1920x1080 numbers! Definitely makes it easier for me to compare apples to apples when I run my benchmarks on Valley. I'm not planning on upgrading anytime soon, but when I do, at least I can get a good idea of what to look at it in comparison to my current setup.
__________________
Intel i7-920 @ 2.66GHz - Corsair Vengeance 16GB DDR3 @ 1600MHz - Windows7 64bit
2 x 150GB WD VelociRaptor HDs (RAID 0) - 1TB WD 7200 rpm HD - 60GB OCZ SSD - 1TB WD External USB HD
2 x EVGA GeForce GTX 660Ti 2GB Superclocked (Dual SLI) - Razer BlackWidow Ultimate KB
Cooler Master HAF 922 - Thermaltake Smart M 850W - 27" Samsung S27B550 LED Display
LordPyrinc is offline   Reply With Quote
Old 6th Jun 2014, 09:47   #4
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
Most reviews say the card is over priced. With r290x when on daily deal a cheaper faster option. Unless you must have vapor x chamber.
rollo is online now   Reply With Quote
Old 6th Jun 2014, 10:16   #5
sandys
Mod Master
sandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpit
There haven't really been any big leaps in performance from the drivers, more so compatibility fixes, you can read the driver release notes for that info.
sandys is online now   Reply With Quote
Old 9th Jun 2014, 04:06   #6
Neogumbercules
Mod Master
Neogumbercules's Avatar
Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.
Something to keep in mind about Sapphire is that their warranty process is an absolute nightmare. If this thing goes bad on you after the retailer limited warranty expired (for Newegg that's 30 days) then you better be prepared for a long, costly, headache of a process dealing with a third party.
That's right. Sapphire DOES NOT service their warranty....directly. They will respond to your warranty request with a link to some nebulous company you've never heard of, a pat on the shoulder and a "good luck" email. You then have to send your card, at your own expense, to this organization and wait several weeks while they dig through a trash bin to send you back a refurbished POS card to replace the one you bought new. Everything I've researched about the company they use in the US has pretty much been all bad.
My advice, buy from a manufacturer that cares enough about their consumers to handle their own warranty.
Luckily the problem with my card was just a scare, and I was able to correct the issue myself, but I feel like I really dodged a bullet.
__________________
Corsair Obsidian 250D - Asus Maximus VI Impact - Intel Core i5 4670k - Radeon R9 290
Neogumbercules is offline   Reply With Quote
Old 11th Jun 2014, 19:01   #7
beef1e
What's a Dremel?
beef1e has yet to learn the way of the Dremel
Thanks for the heads up regarding Sapphire warranty, this is something that i would never have considered.
Do you know if they operate the same here in the UK?
beef1e is offline   Reply With Quote
Reply
Tags
r9 290
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
