Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 7th Jul 2014, 12:01   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
European Commission mandates PCMark for PC tenders
Minimum score required for consideration.
http://www.bit-tech.net/news/bits/20...dates-pcmark/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 7th Jul 2014, 13:36   #2
GrahamC
Modder
GrahamC has yet to learn the way of the Dremel
Seems like a sensible starting point when purchasing office computers.
GrahamC is offline   Reply With Quote
Old 7th Jul 2014, 14:14   #3
Corky42
I Mod, Therefore I Own
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
So no chance of the UK government using something like that then, not known for sensibility is the UK government when it comes to IT.
Corky42 is online now   Reply With Quote
Old 7th Jul 2014, 15:25   #4
RedFlames
...is volatile under pressure.
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
I'm curious to know what the 'minimum standard'/score is...
__________________
You wouldn't really die of anything, in the traditional sense. You would just stop being biology and start being physics.
RedFlames is offline   Reply With Quote
Old 7th Jul 2014, 15:29   #5
Anfield
I *am* a Dremel
Anfield's Avatar
Anfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming Saiyan
How is that going to work for the ever increasing number of PCs free of x86 / Windows?
Anfield is offline   Reply With Quote
Old 7th Jul 2014, 16:58   #6
PaulC2K
PC Master Race
PaulC2K's Avatar
PaulC2K is definitely a rep cheat.PaulC2K is definitely a rep cheat.PaulC2K is definitely a rep cheat.PaulC2K is definitely a rep cheat.PaulC2K is definitely a rep cheat.PaulC2K is definitely a rep cheat.PaulC2K is definitely a rep cheat.PaulC2K is definitely a rep cheat.PaulC2K is definitely a rep cheat.PaulC2K is definitely a rep cheat.PaulC2K is definitely a rep cheat.
It shouldnt really matter what OS you're going to use, the idea is that the system is being rated on its abilities for certain criteria, and by using that you'll be able to compare systems more effectively.
If you buy that machine and put a non Windows OS on there, it still should perform the sort of tasks you bought it for, better than the systems with a lower score.
But from what i understand of this, it isnt something that you'll see companies like Dell, H, Alienware, PCWorld or whatever being forced to display their scores, its for tender offers. So when a company is looking for 50 PCs to fill a new building, they'll get offers from these companies and they'll be required to include a score to highlight the systems capabilities.
I think it'd be a good idea from a consumer POV too, personally. Though i'd imagine most of us here buy ours from parts, it still makes sense.
Most people buy things based on the few things they've picked up on, they'd see a CPU speed and how much ram, and thats what they'll base it on. I mate of mine used to buy terrible digital cameras simply because it had a bigger megapixel number, and he'd assume it was great because it was higher than something lower which was twice the price.
Adding a score system for different purposes, can only help inform customers. Ultimately, they need to know what they're buying and adding a score wont solve that.
__________________
System Specs: i7 5820K | MSI 290X | X99-Gaming 5P | 16GB DDR4 3000 | SM951 512GB | 1250wt PSU | TJ07
Gaming Station: Obutto R3volution | 3x Dell U2913WM | 7680 x 1080
Peripherals: Saitek X-55 | Logitech G27, G15, G500s, G35
PaulC2K is offline   Reply With Quote
Old 7th Jul 2014, 17:07   #7
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
Wasn't the Win7-score ment to do the same thing? And how did that work out exactly?
Seriously. Instead of coming up with such bull**** they should simply hire IT-experts to purchase, setup and maintenance the IT-equipment.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 7th Jul 2014, 17:22   #8
XXAOSICXX
Hypermodder
XXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpit
For n00b customers buying PC games from retailers like Game, actually the system worked quite well. The boxed game would often state the minimum number required to play the game - and those consumers who did purchase their machine from PC World (spits) who had no idea what the graphics-doo-dah or see-pee-you-thingy was at least had a simple "my pc gets a 3 and this game needs a 2" comparison to make.
Us lot using Steam/Origin etc who know what we're doing had no use for it, but we are not the majority.
Because IT experts would never lie about what was needed, and from who, and definitely would never, ever take backhanders from suppliers for putting the business their way, right?
Someone with a better knowledge of a thing than someone with no knowledge of a thing always appears to be an expert when many really, really are not.
XXAOSICXX is offline   Reply With Quote
Old 7th Jul 2014, 20:01   #9
Deders
Deders's Avatar
Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.
Never really seen the point in PCmark Vantage or 8, it barely stresses anything, most new PC's or laptops should easily be able to perform al those tasks.
__________________
i7 6700K @4.6GHz - Asus Z170 Deluxe - Noctua NH-D15 - Gainward Phoenix 1080 GLH 8GB @2050 & 11000 - 16GB Gskill RipjawsV DDR4 @3200 - Corsair HX850i - Nanoxia Deep Silence One - Samsung 950 Pro NVMe - Samsung Spinpoint F3 1TB - WD RE4 2TB - WD Caviar Blue 640 - Dell U2913WM Ultrawide - Logitech G19 - Corsair M65 - Sony STR-DN1050 Receiver - Q Acoustics 2000i 5.1 speakers.
Deders is offline   Reply With Quote
Old 7th Jul 2014, 20:38   #10
oasked
Stuck in the Mud
oasked's Avatar
oasked is definitely a rep cheat.oasked is definitely a rep cheat.oasked is definitely a rep cheat.oasked is definitely a rep cheat.oasked is definitely a rep cheat.oasked is definitely a rep cheat.oasked is definitely a rep cheat.oasked is definitely a rep cheat.oasked is definitely a rep cheat.oasked is definitely a rep cheat.oasked is definitely a rep cheat.
Sounds like a good idea, it'd be great to use at a consumer level.
Just imagine the average consumer walking around PC world - ok that computer is 3.9, but this one has a rating of 4.9 so it's better and worth the extra money.
__________________
Intel Xeon X5650 @ Stock | 18GB DDR3 1333 | Gigabyte GA-EX58-UD5 | Crucial M500 480Gb | WD6401AALS
Gigabyte GTX980 | Lian-Li PC65 | Corsair CX600M | Dell 2408WFP
oasked is offline   Reply With Quote
Old 7th Jul 2014, 21:02   #11
Andy M
What's a Dremel?
Andy M has yet to learn the way of the Dremel
Well that's nice for Futuremark and the other benchmarking software authors in terms of revenue. How do DIGIT et al justify forcing PC manufacturers to pay a third-party for validation software? It's sensible to mandate a reasonable performance, but there could be suggestions of corruption there. Do any of the people who have made this rule have shares in the companies whose software they require computer manufacturers to use?
Andy M is offline   Reply With Quote
Old 7th Jul 2014, 21:21   #12
XXAOSICXX
Hypermodder
Forcing? If a manufacturer wants to bid for the government contract to sell them twenty-thousand PCs then they first have to run ONE of their proposed systems through PC Mark to verify the machines performance. Oh noes!
Old 8th Jul 2014, 08:42   #13
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.
It's a good idea. One of the good things about PC Mark is that it places a lot of emphasis on storage, so systems with SSDs always score highly. It should avoid the situation where the manufacturer packs in pricey top-tier CPUs into their systems to sway purchasing decisions, while the computers themselves are slow due to being held back by spinning rust drives.
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | XFX Radeon 7970 DD | 500GB Samsung 840 Evo | Samsung XL2270HD | KBT Race | Logitech G402
Mac: 13 inch MacBook Pro 2014 | 16GB RAM | Filco Minila Air | Magic Trackpad
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 | Arch Linux
r3loaded is offline   Reply With Quote
Old 8th Jul 2014, 09:07   #14
Deders
Deders's Avatar
The basic test doesn't touch storage
__________________
Old 8th Jul 2014, 09:12   #15
XXAOSICXX
Hypermodder
Pretttttttty sure the European Commission will be requiring potential suppliers to run more than the basic test!
Old 8th Jul 2014, 09:51   #16
Corky42
What is the basic test ? AFAIK PCMark gives an overall score based on the following.
Originally Posted by Article
PCMark is designed to give scores in a range of categories: home workloads, creative workloads, office workloads, storage performance, application performance, and battery life when used on mobile devices.
Reply
Tags
3dmark, benchmark, benchmarking, digit, european commission, european parliament, futuremark, government, nics, pcmark, pcmark 8, slti, ugap
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
