Reply
Thread Tools View Mode
Old 18th Jul 2014, 16:54   #1
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
The Iron Turnip--7-13-polish the head of your turnip
This project is brought to you in collaboration with the following companies
Mod Zoo Munky PC Case badge designed by Cheapskate!
http://mnpctech.com/pc-case-badges-e...ase-badge.html
I have been threatening to do a salvage build for some time now. I've lost track of how many times I was asked why I was named "cheapskate." I swear! Do a few high-budget builds, and everyone forgets the cardboard bear.
Sadly, my stockpile of old denim that I had saved for "ghetto carbon fiber" disappeared when I wasn't looking, so I will resort to metals. I have a fair amount of stainless steel thingamabobs, and lots of aluminum. It's quite possible everything including the kitchen sink will be used, (as I have at least five of those at the moment.)
The plan this time around is just to use as much junk as possible. The first option will always come from my garage, or my attic, or the woods behind the subdivision.
There's going to be hammering too! I love to beat the sh*t out of stuff with hammers. This will be a very therapeutic project.
-I settled on this sucker for my primary container. I'm hoping to chop it down as much as possible. This is an old stainless steel soda syrup container. I'm sure anyone who follows me knows I pick up weird stuff from vacant houses. It's unbelievable what you find sometimes, and you have to wonder what they were smoking to steal/keep one of these.
-Wait, I kept it... What was I smoking?
-The first thing that had to happen was the heavy rubber end had to come off. I wanted something vaguely BOMB-like for the look, and that squared tail wasn't working. I had to sharpen the chisel anyway, so some heavy rubber chipping happened.
-I made a glorious mess. The pliers were because I found the rubber could be torn easier than it could be cut.
-I had to switch to a rasp closer to the metal.
-After an attack with the sander, I found metal. As soon as I saw that seam I was worried it would look like a thingy. I appropriated a few aluminum pans for possible re-cladding.
- I have to get inside somehow, so I chopped the top off. Here I've hack sawed a start just above the top weld seam. This promptly went outside as it was already smelling like a drag race.
For using the jig saw, I made the mistake of sitting on the tank to keep it steady. .01 seconds of ultrasonic vibrations to my nethers later, I decided that was a bad idea. I also had to explain that the exclamation I made wasn't because I had cut myself to everyone in earshot. I did NOT tell them why I suddenly did a Rob Halford impersonation, though.
-This shot should have captured the white smoke of burning rubber wafting out of the tank. It didn't.
-It looks like I can fit a 650W power supply barely. I might look into small form factor power instead.
-There was some flower arranging, only with computer parts. I decided the radiator I had laying around was too big, so that's the first item I didn't get to use salvage for.
-I resorted to a cardboard mockup of a 2 x 140 radiator. I think I'll center two 120mm fans on that.
-Say hello to restaurant heat shield. Apparently, If enough people drop a part because it's hot, the welds on the shield break, and someone throws it away. It said it was hot. You would think they would know better with that big warning on it. A small eternity after this pic was taken, I drilled through the stainless steel rivets to remove the sign. -Tough little b*stards!
-A little SMACKIN' with a ball-peen sledge, and it matches nicely. Big rubber doormats make a good anvil. I have a bit of microwave surround in the pic for possible use too.
-I drew up a fan hole and sawed. -and sawed. -and SAWED. Did I mention cutting the top off earlier dulled a NEW jig saw blade? I resorted to a hack saw since it was much quieter than ringing this big metal drum with a power tool.
-No, that's not a reference to my earlier junk oscillation.
-It took forever to dremel a start hole in the flat cuts. I had to use one of these horrible things: a hack saw blade holder. It's amazing how many times you can bend a blade without it breaking.
-Like this, I can have the radiator flush against the inside wall, and have more room for other stuff. Bending was done with a really big crescent wrench.
-Here's the other reason to use only 120mm fans: They fit the heat shield perfectly. With a little slap, she fit and stayed in place with a friction fit.
-That's where I'm at now. I have nothing lined up for hardware, and only a vague fuzzy feeling about where I'm going with the design. I gotta make stuff FIT first. Looks come after.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Last edited by Cheapskate; 14th Jul 2016 at 03:04. Reason: Hey, I can put stuff in this spot too!?
Cheapskate is offline   Reply With Quote
Old 18th Jul 2014, 17:04   #2
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
Now this I've gotta see. Nothing like a true ghetto/junk/recycling project to keep you going. Bonus is unlike with Glassgween, I'll actually have proof 4 years down the line that I was there from the beginning
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: Cheers Luv!
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 18th Jul 2014, 19:26   #3
B NEGATIVE
All Hail Kim Jong Magoo!
B NEGATIVE's Avatar
B NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming Saiyan
Da na na na Da na na na Da na na na SCRAPMAN!!!
B NEGATIVE is offline   Reply With Quote
Old 18th Jul 2014, 19:50   #4
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
And his sidekick GHETTO BOY!!!
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is online now   Reply With Quote
Old 18th Jul 2014, 20:15   #5
Meelobee
Hypermodder
Meelobee's Avatar
Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.
Tales of your personal sybian in the first post, this is gonna be fun
Meelobee is offline   Reply With Quote
Old 19th Jul 2014, 00:17   #6
supermonkey
Deal with it
supermonkey's Avatar
supermonkey is the Cheesecake. Relix smiles down upon them.supermonkey is the Cheesecake. Relix smiles down upon them.supermonkey is the Cheesecake. Relix smiles down upon them.supermonkey is the Cheesecake. Relix smiles down upon them.supermonkey is the Cheesecake. Relix smiles down upon them.supermonkey is the Cheesecake. Relix smiles down upon them.supermonkey is the Cheesecake. Relix smiles down upon them.supermonkey is the Cheesecake. Relix smiles down upon them.supermonkey is the Cheesecake. Relix smiles down upon them.supermonkey is the Cheesecake. Relix smiles down upon them.supermonkey is the Cheesecake. Relix smiles down upon them.
Originally Posted by Cheapskate View Post
For using the jig saw, I made the mistake pleasurable decision of sitting on the tank to keep it steady. .01 seconds of ultrasonic vibrations to my nethers later, I decided that was a bad the best, most sensual idea.
Fixed it for you.
__________________
But of bliss and of glad life there is little to be said, before it ends; as works fair and wonderful, while still they endure for eyes to see, are their own record, and only when they are in peril or broken for ever do they pass into song.
-J.R.R. Tolkien, The Silmarillion
supermonkey is offline   Reply With Quote
Old 19th Jul 2014, 00:57   #7
Cheapskate
Cheapskate's Avatar
I entertain you. You entertain me.
@ Meelobee - I shouldn't have googled that word.
@Nexxo -My sidekick for this ride will be Mr.Smashie, the demolition hammer.
@Maki -This could be a much shorter log, since the finish will be sub-standard.
__________________
Old 20th Jul 2014, 16:39   #8
AlderonnX
Multimodder
AlderonnX's Avatar
AlderonnX has yet to learn the way of the Dremel
Ah, this I gotta see
__________________
First Bit-tech build log http://forums.bit-tech.net/showthread.php?t=275359 Continuum
Also If you get a friend request from a Giant drinking a Mountain Dew on Facebook thats me...
AlderonnX is offline   Reply With Quote
Old 24th Jul 2014, 20:41   #9
Cheapskate
Cheapskate's Avatar
Thanks.
I forgot to mention I will not settle for wood, MDF, or cardboard. -That would be too easy. I'm also going to avoid using plain steel.
The current plan is to mount the fans to the tank, and have the rest as a slide out module. I would like to hack the tank down to at least 12", but it all depends on the parts fitting.
__________________
Old 25th Jul 2014, 06:33   #10
Hukkel
James' minion
Hukkel's Avatar
Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.
Seriously you always come up with the strangest ideas. Love it!
Hukkel is offline   Reply With Quote
Old 26th Jul 2014, 00:53   #11
KidMod-Southpaw
KidMod-Southpaw's Avatar
KidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming Saiyan
The interior layout, and, actually, the whole thing reminds me of a dirtied up Mac pro.
I look forward to more!
__________________
Project Logs: Refraction - Steampunk Flash Drive - Steel; Sleek; Slate
BitFenix Prodigy - Gigabyte Z87N - Intel 4670K - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - M4 128GB - WD Red 1TB X2 - H60 - Antec 650W - Dell U2312HM - Poker MX Red - Sennheiser HD 598
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 26th Jul 2014, 01:03   #12
Cheapskate
Cheapskate's Avatar
@Hukkel - PARTS? -or ideas.
@Kid - water cooled too. It should look like a gasoline-powered sex toy when I'm done, so yeah, totally Mac-like.
__________________
Old 26th Jul 2014, 07:12   #13
leonetu
Minimodder
leonetu has yet to learn the way of the Dremel
Strange - is always good in design. Subbed!
leonetu is offline   Reply With Quote
Old 27th Jul 2014, 17:29   #14
Cheapskate
Cheapskate's Avatar
Right? Boxes start to suck after a while.
__________________
Old 24th Aug 2014, 04:55   #15
Furball Zen
Shut up and Mod
Furball Zen's Avatar
Furball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run Crysis
I almost spit out my nilla wafers lol.
__________________
Life. Liberty. The pursuit of those who oppose it.
Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide
@furballzen ~ Admin at Xoxide Forums
Furball Zen is offline   Reply With Quote
Old 28th Aug 2014, 00:18   #16
Lystfiskern
What's a Dremel?
Lystfiskern has yet to learn the way of the Dremel
This thing just might get crazy weird folks...strap on!
Lystfiskern is offline   Reply With Quote
Old 29th Aug 2014, 13:13   #17
Bad Fenny
Modder
Bad Fenny's Avatar
Bad Fenny has yet to learn the way of the Dremel
Great build . . . my favorite recipe . . . take a bunch of cast off junk, add computer parts, ingenuity and creativty and you get a computer.
Cheers
Fen
Bad Fenny is offline   Reply With Quote
Old 29th Aug 2014, 15:11   #18
Jumeira_Johnny
16032 - High plains drifter
Jumeira_Johnny's Avatar
Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.Jumeira_Johnny is definitely a rep cheat.
I have a box of a variety of old pants. If you want me to, I can send it to you.
__________________
Dachshund of War™|TerrierX™|Macbook Pro|1967 Pontiac Catalina|360# Anvil|2 Burner Gas Forge|135 Amp MIG Welder
Jumeira_Johnny is offline   Reply With Quote
Old 29th Aug 2014, 15:39   #19
Meelobee
Hypermodder
Meelobee's Avatar
See I wasn't that far off with the Sybian
Old 30th Aug 2014, 01:32   #20
Cheapskate
Cheapskate's Avatar
Sorry about delays. I'm in home repair limbo.
@Meelobee -no
@Jumeira Johnny -No again.
@Bad Fenny -You forgot, "mix with hammer."
@Lystfiskern - No again!
@Furball - Rats. Almost doesn't count.
__________________
Reply
Tags
aardvarks and aasvogels, cheapskate, metal, salvage, stainless steel, water cooling
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
