Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th Aug 2014, 08:41   #1
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
Water-cooling the AMD Radeon R9 295X2
We strap a custom water-cooling system to AMD's R9 295X2.
http://www.bit-tech.net/hardware/201...eon-r9-295x2/1
Dogbert666 is offline   Reply With Quote
Old 6th Aug 2014, 17:34   #2
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
Would be interesting to see how using a bigger radiator (360, 480) affected temps and performance. Also with the reduced temps, could you overclock the card further?
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 6th Aug 2014, 23:46   #3
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
I have an issue with this water block and those like it, once the liquid is in it looks like it is full of rather ugly bubbles. I much prefer water blocks that look like they have a designed, set route for the liquid. I also have issues with 'full cover' water blocks that, well, aren't 'full cover' and leave great whacking amounts of exposed PCB and electronics for everyone to see. I know that isn't always the case but the few that aren't (like the one featured here) are only for the very most high end GPUs, as far as I have been able to see there is no 'full cover' water block that actually covers the whole card for things like the 760 or 770. If I am going to pay quite a lot of money to water cool the GPU then I would like the full card to be covered and not expose these areas that were quite happily covered by the after market air coolers, or even stock coolers.
OK, rant over. If anyone knows of water blocks that meet my requirements then please do let me know. Thanks.
__________________
SchizoFrog is offline   Reply With Quote
Old 7th Aug 2014, 14:32   #4
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
I think the 1650rpm fans actually did a fairly good job of shifting enough air to remove most if not all of any bottleneck imposed by the radiator - there wasn't any difference in temps even when I wound them down to 7V as a side test. Sadly the overclock wouldn't push any higher, but it's pretty significant as it stands. Obviously if this was an air-cooled card the differences would likely have been huge but AMD has certainly made sure throttling is kept to a minimum this time.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 12th Aug 2014, 13:13   #5
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
Aqua Computer Kryographics Vesuvius 295 X2 Acrylic Edition
What a name ! Had to read it several times
GuilleAcoustic is offline   Reply With Quote
Old 13th Aug 2014, 14:19   #6
iggy
Hypermodder
iggy's Avatar
iggy is definitely a rep cheat.iggy is definitely a rep cheat.iggy is definitely a rep cheat.iggy is definitely a rep cheat.iggy is definitely a rep cheat.iggy is definitely a rep cheat.iggy is definitely a rep cheat.iggy is definitely a rep cheat.iggy is definitely a rep cheat.iggy is definitely a rep cheat.iggy is definitely a rep cheat.
the difference between air and water is more the fact that you can keep this card running at full whack with all the safeties off, all the time, without it sounding like an Antonov An-225 taking off on your head. Try doing that with stock cooling.
__________________
"I think, therefore I think I am"
Zippy the pinhead
iggy is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
