Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th Aug 2014, 18:18   #1
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Corsair Carbide Series Air 240 available on Pre order for 69.95
http://www.bit-tech.net/news/hardwar...pre-orders-f/1
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 6th Aug 2014, 20:16   #2
Syphadeus
Minimodder
Syphadeus should be considered for presidentSyphadeus should be considered for presidentSyphadeus should be considered for presidentSyphadeus should be considered for presidentSyphadeus should be considered for presidentSyphadeus should be considered for presidentSyphadeus should be considered for presidentSyphadeus should be considered for presidentSyphadeus should be considered for presidentSyphadeus should be considered for presidentSyphadeus should be considered for president
Would that not be 'alluded' to?
Syphadeus is offline   Reply With Quote
Old 6th Aug 2014, 21:24   #3
Combatus
Moderator
Combatus's Avatar
It would indeed Naughty Antony speed-posting again
__________________
Old 7th Aug 2014, 12:39   #4
NetSphere
Multimodder
NetSphere is definitely a rep cheat.NetSphere is definitely a rep cheat.NetSphere is definitely a rep cheat.NetSphere is definitely a rep cheat.NetSphere is definitely a rep cheat.NetSphere is definitely a rep cheat.NetSphere is definitely a rep cheat.NetSphere is definitely a rep cheat.NetSphere is definitely a rep cheat.NetSphere is definitely a rep cheat.NetSphere is definitely a rep cheat.
If only they had released this at the same time as the 540. I would have bought it when downsizing.
__________________
Silverstone TJ08E - Ivy Bridge 3570k @ 4.0 GHz - Scythe Mugen 4 - Asus Maximus Gene4 - 2x4GB Corsair Vengeance LP 1.5V - 2GB ASUS GTX670 DIRECT CUII TOP - 256GB Samsung 830 Series - 850W Corsair HX850
NetSphere is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
