Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 14th Aug 2014, 10:58   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Intel demos DirectX 12 power savings
Mobile devices to benefit the most.
http://www.bit-tech.net/news/bits/20...el-dx12-demo/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 14th Aug 2014, 12:13   #2
Corky42
I Mod, Therefore I Own
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
So if DX12 is compatible with DX11 hardware does that mean when Microsoft makes it a Windows 9 exclusive we can all have a good old whine about it
Corky42 is online now   Reply With Quote
Old 14th Aug 2014, 12:15   #3
Margo Baggins
I'm good at Soldering
Moderator
Margo Baggins's Avatar
Margo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming Saiyan
Yes, and I personally can't wait for a good moan
__________________
My Imgur
Get a Geek Box
i7 3820 4.3ghz - 8GB 2133mhz - GTX 970
keyboards.
Margo Baggins is offline   Reply With Quote
Old 14th Aug 2014, 14:33   #4
SMIFFYDUDE
Supermodders on my D
SMIFFYDUDE's Avatar
SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.
The graph looks like it was drawn using MS Paint.
__________________
i7 6700K|Sabertooth Z170 S|16GB Crosair Dominator Platinum 3200MHz|KFA2 GTX 1080 HOF|Creative Sound Blaster ZxR|Super Flower Leadex Gold 850W|Raijintek Triton|Corsair 780T|HP LP2475w|Speedlink Medusa 5.1|CM Storm Inferno|Windows 10
Steam: SMIFFY
SMIFFYDUDE is offline   Reply With Quote
Old 15th Aug 2014, 04:00   #5
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
Over a Windows 95 wallpaper
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 15th Aug 2014, 04:40   #6
Skiddywinks
Hypermodder
Skiddywinks has yet to learn the way of the DremelSkiddywinks has yet to learn the way of the Dremel
...at unlocked framerates, the benchmark in use jumped from 19 frames per second to 33 frames per second for the same overall power draw - more than doubling the performance of the hardware.
Either I am just reading this wrong and being an idiot, or the math here is a bit off...
More than double the performance would be more than 38fps, surely?
Skiddywinks is offline   Reply With Quote
Old 15th Aug 2014, 06:09   #7
Gareth Halfacree
WIIGII!
bit-tech Staff
Originally Posted by Skiddywinks View Post
Either I am just reading this wrong and being an idiot, or the math here is a bit off... More than double the performance would be more than 38fps, surely?
No, it's not you: I had a brainfart, apparently. Should be "roughly," not "more than" - I'll go fix, ta!
__________________
Old 15th Aug 2014, 09:10   #8
Alecto
Multimodder
Alecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the Dremel
Well, if same hardware can achieve almost 100% higher frame rates solely due to software changes existing software (DX11 in this case) must be really really shitty piece of junk.
Alecto is offline   Reply With Quote
Old 15th Aug 2014, 10:59   #9
Corky42
That's a bit harsh, DX11 is almost 5 years old, things move on, developers and consumers demand better graphics as time goes by. Would you say a GTX 295 was a shitty piece of junk when compared to a GTX 780 ?
FYI I'm not saying having to wait 5 years for a new DX version is a good thing, it's just saying DX11 is rubbish because DX12 may improve things is a little disingenuous.
Old 15th Aug 2014, 14:03   #10
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
wow you're right.... it is almost 5 years. Feels like only 2 or 3, and even that is relatively long. But in another perspective - there are still way too many games that use DX9.
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Reply
Tags
api, direct3d, direct3d 12, directx, directx 12, intel, microsoft, surface pro 3
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
